Old Jun 23, 2011, 07:44 PM
TheNiceGuy is offline
Find More Posts by TheNiceGuy
Expat
Japan
Joined Apr 2010
If you keep doing that you'll get your haircut via the prop.
Looks good, you have 2 rate gyros on that? I've never used gyros.
TheNiceGuy is offline Find More Posts by TheNiceGuy
Old Jun 24, 2011, 08:49 AM
Gary Mortimer is offline
Find More Posts by Gary Mortimer
Gaftopher
Gary Mortimer's Avatar
Nottingham Road South Africa/Bedford UK
Joined Feb 2007
I am using a CopterControl board.
Right now I am looking at depron and thinking of starting on a ball. Its made me look closer at the original. I can see now that the lower surfaces do move and seem to be 90 degrees out of phase with the upper ones.
Will look closer at the white development one and see if that looks the same.
They appear to move opposite to the upper surfaces and I wonder if thats helping to get rid of yaw induced by the motor.
The early one has tabs on the bottom which I assumed did that.
Looking at the white one, it does not even look like 90 degrees more like 60. Has anyone seen any better stills??
Gary Mortimer is offline Find More Posts by Gary Mortimer
Old Jun 24, 2011, 11:07 AM
Gaftopher
Joined Feb 2007
Well based on if you don't start you will never know have been playing with paper this afternoon and am close to starting cutting
Its going to be very simple and might just yaw away. I also think its going to be close to impossible to know which way its going.
I shall update here when I have more, anyone else trying to build one this weekend??
Old Jun 24, 2011, 02:14 PM
Gaftopher
Joined Feb 2007
Ok so its a couple of hours later
If it lifts off the deck I shall bother adding more hoops, otherwise I will just cry into a beer.
Old Jun 24, 2011, 05:25 PM
Brandano is offline
Find More Posts by Brandano
if it is not controllable, try rising up the battery pack. The CG should be ahead of the vanes.
Brandano is offline Find More Posts by Brandano
Old Jun 24, 2011, 09:48 PM
Expat
Japan
Joined Apr 2010
Wow nice work!
Won't that horizontal hoop get in the way of airflow? Or is this part of your evil master plan?
Old Jun 25, 2011, 03:25 AM
Gaftopher
Joined Feb 2007
I could pretend it is but really its just waste from the internal cut that fitted and I tacked it on to help hold it together when sticking it.
@Brandano I will move the battery up I knew making that slot there was a mistake but I will move receiver and rotate the battery and that will move the CG up a bit.
Just looking at it, it looks short coupled now something I did'nt see when sketching it out. Another reason I am a fan of just making things and trying until it works. So I may end up moving the motor up a touch.
I will add the skirt if you will, the band wrapped around below the equator in the other one. Not sure if thats there as an annular wing for forward flight or duct.
The IMU is mm south of the physical centre point. On the POGO I just put it where the cables reached from the servos and I think that was a cludge. It looks like as its parked in the centre now I am getting sensed reactions much faster now.
So more bodging today and I might get it flying nicely. Or just goto the pub!
Old Jun 25, 2011, 09:26 AM
Azarr is offline
Find More Posts by Azarr
RIP Azarr - "Old age is not for sissies"
Azarr's Avatar
Dayton Intl, Ohio, United States
Joined Jan 2000
Wouldn't you want the CG low for this project? In the drone video the ball doesn't hardly change attitude during forward flight. It might tilt slightly forward.
Just found this thread.
Great minds think alike I have the KK single copter board on order, is that what you are using?
I'm following your progress with interest. By the time I get ready for mine, you should have this perfected what's the diameter of the ball you're using? I'm thinking ~ 15" would be a good size. I actually have one of the small HiMax counter rotating motors that I bought on a whim and have never used. That might be a solution to any torque problem.
Azar
Azarr is offline Find More Posts by Azarr
Old Jun 25, 2011, 03:44 PM
Expat
Japan
Joined Apr 2010
I'm guessing teh tighter the CoG to the thrust vector (dont know the 'official' aeronautic terminology) the more responsive it will be? So a higher CoG will say reverse direction much faster and smoother than a lower CoG which would bob and lag?
Old Jun 25, 2011, 03:46 PM
Brandano is offline
Wouldn't you want the CG low for this project? ...
No, it's an illusion. This is not an helicopter and the rotor head does not teeter. this means that the vector of thrust always goes through the CG when trimmed, irrespective of what the asset is. Even if the plane tilts, there's nothing straightening it up, except pilot inputs.
Old Jun 26, 2011, 01:03 AM
underthefloor is offline
Find More Posts by underthefloor
Permanently Banned
Stumptown
Joined May 2008
Wouldn't a CG closer to the center of pressure make the aircraft tend not to roll when moving?
underthefloor is offline Find More Posts by underthefloor
Old Jun 26, 2011, 09:34 AM
Brandano is offline
underthefloor: Yes, if you consider the CG and the center of pressure having them close would reduce the tendency to tilt when the plane is hovering. Actually, having the COG below the center of pressure/center of drag would provide a righting moment, at the cost of making conventional flight impossible. But it's irrelevant how close or far is the COG from the position of the motor, and this is a common error a lot of people seem to fall for. it's more important to put a greater distance between the COG and the control surfaces.
Old Jun 26, 2011, 10:20 AM
Gaftopher
Joined Feb 2007
I think I am learning that Brandano....
Will try and make a video of how it flies so far, its not pretty. Yaw is the issue.
Just considering tacking on a bit of a skirt first to see if that improves things.
I don't have the design smarts that you chaps have, just the suck it and see analysis plan ;-)
Certainly know some of the things I will be doing in version two already!
Once again anyone got better images of the original Japanese one??
Old Jun 26, 2011, 11:16 AM
Expat
Japan
Joined Apr 2010
Good work Gary. Post videos of the failures if you can as it will help me in making mine.
I would have started this last week but got sidetracked with my new GoPro and FPV gear!
I'll try to get more specs on this end of the original for you if possible.
In the mean time, you may have seen these videos:
New japanese military Unmanned Aerial Vehicle (UAV) (2 min 31 sec)
I noticed at 1:35 he makes it reverse on the floor. I can see he's using a reversable motor. If you blow up the video, there's some half-decent stills.
FLYING BALL (1 min 5 sec)
謎の偵察飛行物体 防衛技術シンポジウム2010 (3 min 23 sec)
Old Jun 26, 2011, 02:04 PM
Gaftopher
Joined Feb 2007
Ah I had no seen those, thanks Nice Guy
Heres my playing, its not pretty
First crack at a ball drone (2 min 5 sec)
I do believe there is an easier way.
Its impossible to watch those videos without thinking about the carpet.
Mini-HowTo RC Controlled AR.Drone w/o WiFi! nosaari Multirotor Talk 117 Dec 07, 2014 04:04 AM
Discussion New AR Drone (i-drone) light mod bungle68 Multirotor Talk 3 Apr 13, 2011 05:30 PM
Discussion AR Parrot Drone For Sale Matt Gunn Atlanta Area RC 4 Mar 16, 2011 07:41 AM
Found Parrot AR. DRONE iceman77 Aircraft - Electric - Helis (FS/W) 3 Mar 15, 2011 01:51 PM
Discussion Piloting Drone From iDevice BUT takeoff/landing from a computer chope1 Multirotor Talk 0 Mar 07, 2011 10:12 AM
