Old Jan 17, 2012, 02:38 PM
VTOLicious is offline
Find More Posts by VTOLicious
VTOLicious's Avatar
Austria
Joined Oct 2007
gyroscopic effect
Originally Posted by Dzl View Post
More images, videos and info on this blog:
http://dzlsevilgeniuslair.blogspot.com/
Hey Dzl! Nice work, nice blog!
As expected it has a tendency to wobble. This is caused by the gyroscopic force of the propeller. I have designed the firmware so that i can offset the angle between the IMU thrust vectoring vanes. This should allow me to compensate for these forces
In theory the offset between action an reaction is 90... whats your conclusion?
Im playing around with a similar vehicle. I dont use any offset by now, but considering testing it. Might make life of the flight controller easier
On a earlier, completely manual controlled tailsitter, Ive used 45 offset - worked well, pic attached.
SDP-VTOL V1.2 - Testflight (0 min 53 sec)
Rgds Michael
VTOLicious is offline Find More Posts by VTOLicious
Old Jan 17, 2012, 05:04 PM
Brandano is online now
Find More Posts by Brandano
Well, actually the 90 degrees thing is not a hard rule. There is a component of the tilting force that gets offset by 90 degrees, and the volume of this component is proportional to the speed and mass of the prop. A very light prop or one that turns slowly won't show as much offset
Brandano is online now Find More Posts by Brandano
Old Feb 06, 2012, 05:59 PM
Dzl is offline
Dzl
Find More Posts by Dzl
Dzl
Joined Apr 2006
Well i expected something like 45 degrees as well but ended up with 10. I have my device hovering stabilized by the auto pilot. By changing the angle i can get it to wobble both clockwice and counter clockwice. When the rotation is 10 degrees it's stable. I guess it completely depends on what ratio you have between the forces from the control surfaces and the gyro forces from the propeller.
Anyway really nice construction! And flying without IMU pretty ninja too (know how it is)
Dzl is offline Find More Posts by Dzl
Old Feb 17, 2012, 11:06 AM
ericchhoa is offline
Find More Posts by ericchhoa
Joined Feb 2012
hi Gary, for your flying ball project--your CC board was set at heli mode or airplane mode? thank you. eric
ericchhoa is offline Find More Posts by ericchhoa
Old Feb 17, 2012, 11:12 AM
sirbow2 is online now
Find More Posts by sirbow2
Emress
Joined Nov 2011
im not sure but here : http://dl.dropbox.com/u/2248531/www/...bot/index.html it says: "I am using helicopter style controls so a special mix of
throttle, aileron, rudder and elevator stick is needed for
each control surface.
My EVO-9 transmitter is able to do this mixing internally
so the servos can be directly connected to the receiver.
Later versions of the H-bot will use an onboard micro
controller to do the mixing. Gyros, accelerometers and
other sensory will then be incorperated into the mix as
well."
http://dl.dropbox.com/u/2248531/www/.../hbot/smix.gif
sirbow2 is online now Find More Posts by sirbow2
Old Feb 18, 2012, 07:55 AM
Joined Feb 2012
Sirbow2,
Many thanks.
Old Mar 19, 2012, 10:33 AM
natzjiem is offline
Find More Posts by natzjiem
Joined Mar 2012
hello everybody, i am so glad to found this topic because my senior project is doing flying sphere ball . i follow this thread, read and do my sphere.
this is my sphere
and i can figure out sam's wiring configuration to use 6 servos for pitch and roll
but my sphere is not stable when i hover.
i am not good at English, sry for my English skill
Nat
natzjiem is offline Find More Posts by natzjiem
Old Mar 20, 2012, 06:52 PM
Sonofagun is offline
Find More Posts by Sonofagun
J. Titors gr8 grandson...
Sonofagun's Avatar
Charlotte,NC
Joined May 2005
Your english is fine...however sometimes a video is worth a thousand words.
Sonofagun is offline Find More Posts by Sonofagun
Old Mar 21, 2012, 09:10 AM
TheNiceGuy is offline
Find More Posts by TheNiceGuy
Expat
Japan
Joined Apr 2010
And your pictures are too small. About 10 words.
TheNiceGuy is offline Find More Posts by TheNiceGuy
Old Mar 23, 2012, 01:34 PM
natzjiem is offline
Joined Mar 2012
[I
thank you for your comment, i will post vdo later.
Old Mar 28, 2012, 08:51 PM
Innerbreed is offline
Find More Posts by Innerbreed
DotCoDotUk
Innerbreed's Avatar
Joined Mar 2012
Hi guys, i will start a thread on this when i get more time but for now i have my sphere to show you. Yes some of you have already seen the Japanese flying Sphere 'well who wouldnt want one. i asked myself that and decided "well i do" so im building one.
Here are the CAD designs still in process, supplied by a good friend DialFonZo.
The Material will be cut from 3mm PVC Foam board, (light but strong), and will be powered using a Thunder Power 2100mAh 3-Cell 11.1V LiPo Battery with a Turnigy Park 300 Brushless Outrunner 1600kv motor.
It will pose x3 HK401 Heading Hold AVCS Gyros, and (at the moment) x6 Hs-65hb servos.
The Sphere will be 12" in diameter.
Jonny Poole
www.innerbreed.co.uk
Innerbreed is offline Find More Posts by Innerbreed
Old Mar 28, 2012, 11:29 PM
takiss is offline
Find More Posts by takiss
Patras, Greece
Joined May 2007
Hi Innerbreed.
This is the best first post ever!
I will follow your design and build. always thinking to build one, but plans were missing.
Takis
takiss is offline Find More Posts by takiss
Old Apr 02, 2012, 08:00 AM
Expat
Japan
Joined Apr 2010
Great idea Jonny. If you get it working, you could sell kits. I think these would sell well. There is nothing this safe and versatile on the market right now. The closest thing is something like a quad with a epp prop guard, still dangerous, and expensive. Shipping would not be bad on a fully assembled model either.
Old Apr 25, 2012, 08:38 AM
DotCoDotUk
Innerbreed's Avatar
Joined Mar 2012
project thread.
http://www.rcgroups.com/forums/showt...6#post21430963
Old Apr 26, 2012, 05:46 AM
u.abhi19 is offline
Find More Posts by u.abhi19
Joined Oct 2011
hi guys , can any1 tell me what is the role of those spoilers ? and also im trying to build this sphere .. can i use this stabilization system http://www.store.revolectrix.com/Pro...-Pilot-II-L-C2 .. or can u suggest something else ?
thank you
u.abhi19 is offline Find More Posts by u.abhi19
Mini-HowTo RC Controlled AR.Drone w/o WiFi! nosaari Multirotor Talk 117 Dec 07, 2014 04:04 AM
Discussion New AR Drone (i-drone) light mod bungle68 Multirotor Talk 3 Apr 13, 2011 05:30 PM
Discussion AR Parrot Drone For Sale Matt Gunn Atlanta Area RC 4 Mar 16, 2011 07:41 AM
Found Parrot AR. DRONE iceman77 Aircraft - Electric - Helis (FS/W) 3 Mar 15, 2011 01:51 PM
Discussion Piloting Drone From iDevice BUT takeoff/landing from a computer chope1 Multirotor Talk 0 Mar 07, 2011 10:12 AM
