Enjoying the discussion a lot.
I had a chance to see the original drone at public seminar here. The developer, Fumiyuki Sato introduced and demonstrated it. It was flying amazingly stable.
He wanted to develop a ball shaped drone which can roll on the ground and fly. He spent 16 months and 7 experiments for now. Current model has CPU managed control with 3 gyros but it seems he can hover stably without it (up to recent experiments.) That session was very informative and fun. He built it with readily available materials (total cost of current unit is USD 1,400 including styrene board and pet bottle.) Satoru |
Taiwan
Joined Aug 2011
Thanks for sharing with nice video and pictures,we all respect Sato-san for his fantastic invent of the BALL DRONE,it takes a real aerodynamics expert to build the craft,he is a GENIUS Hondouni aligadougozaimasu Konbanwa Sam |
Hello Sam-san,
Glad to hear you like the video. I was impressed Sato-san has been working on this project under not well funded environment, achieving objectives step by step. He could not hover stably until 3rd experiments. Ball shaped drone is achieved at 4th build. I wish he can accomplish further. This person's video covers whole session on previous day (it was 3 day event.) He introduced how he came up the idea, history of development and future vision with many videos.
I admire your effort! Subarashiidesu. Around 8:10 in the first of 2 video, Sato-san showed crash scene at the first flight, showing styrene outer frame damage. Yours are built more robust! Arigatougozaimasu. Satoru |
United States, IL, Park Ridge
Joined Apr 2010
Hi !
With pleasure I was following this thread. Slowly starting to build my own flying ball. Latest video is clearly showing than shape of ball is kind of airfoil. On the video You can see him showing CG of the single panel and is GLIDING ability. Regards Tom
Hi Tom,
Yes, he was emphasizing how CofG is important. - He explained the drone is a airplane in a ball, not a helicopter. - He built #5 experiment (non powered) for glide test. See from 13:50 of the first session video.. It shows how he tried to place airplane to fit in a ball, and how he tested. - He demonstrated 1, Circle shaped paper will not fly. 2, Adding weight and set CG to 20% flies well. 3, Opened holes in the front half of the ball can move CG further back (to 40%). (your video) He mentioned he added additional wing surrounding the bottom of ball to move the CG to desired 50% (center of the ball). It is not a copter. Amazing.. Satoru Quote:
Joined May 2010
Kelly |
Joined Oct 2003
sorry for that, let's refer to post 169 video by Sam, when he give a input on pitch, the mixing will move the top 2 vanes ( 1 servo) and bottom 4 vanes ( 4 servo). I want to know how to achieve this by just using 2 v-tail mixer? In your earlier sketch your pitch only can move top sevro and 2 bottom servo instead of 4 bottom servo. Thanks in advance Regards Ivan |
Joined May 2010
I would like to direct you to Sam's other thread where he combined the Japanese Ball Drone with a Crazy Ball. This device utilized the same canarderon control system and the spoiler system, if you're interested in building either one of these craft this is an excellent resource. I would suggest you read this entire thread, I cover a number of details about the control mechanism that may be useful to you. Japanese/Crazy Ball Drone Thread: http://www.rcgroups.com/forums/showthread.php?t=1516652 Ivan, please watch this video of Sam's craft mentioned above, I knew this questions about how to configure the control surfaces would surface someday, so I thought it would be good to have Sam give us a video of his fine work showing his ingenious adaption of the control mechanism. Please note that when Sam gives a pitch command, two upper vanes moved to the right, and two lower vanes moved to the left. Please note only two vanes on the bottom and two vanes on the top move for each axis of control. The same thing applies for the roll axis, two lower vanes move in the opposite direction of the upper two vanes. The lower four vanes can all spiral left or right for Yaw control because there is a Servo for each vane, that's why you see in my wiring schematic a Y adapter, this Y adapter keeps the upper control servos from receiving the Yaw command, you don't want the upper servos to get the Yaw command since you only have one Servo for each axis, pitch and roll, since the servos are interlinking the control vanes there would be no way for them to move into a spiral configuration. Sam chose to use six servos due to the limitations of the switching BEC. Eight servos could be used, but this would necessitate adding another BEC, and two Servo reversing adapters (to reverse just the yaw axis for both pitch and roll) for the upper control vanes. It is not worth the extra weight and effort to have eight servos.
Please review the thread regarding the Japanese/Crazy Ball Drone. I think this will be very helpful for you and the other readers that are planning to copy a drone. Did I answer your question? Kelly |
Joined Oct 2003
hi Kelly,
I have no problem understanding the Japan/crazy ball setup. this is because the upper vanes and lower vanes are in line, I can do the mixing with just two v-tail mixer without any problem. and for the japan flying ball, the upper and lower vanes are offbset by 45 degree. thus all 4 bottom vanes need to move together when you are give either pitch, roll or yaw commend. I dun think it can be done by just using 2 v-tail mixer. maybe Sam is using a miro controller for the mixing. Regards ivan |
Joined May 2010
Don't worry about the 45 degree off-set between the upper and lower vanes. That make no difference at all. It works exactly as in the Crazy Ball video I just attached. No micro processor either. No tricks, it all very simple. Just ignore the 45 degree off-set.
You can use a KK board but you'll need to set it up as an airplane and then mix the yaw axis back into the pitch and roll with your v-tail mixers for just the lower 4 servos. Sam, used 3 separate gyro. 1 heading hold, 2 rate gyros. Did I answer your questions? Kelly |
| Thread Tools | |
| Mini-HowTo RC Controlled AR.Drone w/o WiFi! | nosaari | Multirotor Talk | 113 | May 13, 2011 02:26 PM |
| Discussion New AR Drone (i-drone) light mod | bungle68 | Multirotor Talk | 3 | Apr 13, 2011 05:30 PM |
| Discussion AR Parrot Drone For Sale | webdr | Atlanta Area RC | 4 | Mar 16, 2011 07:41 AM |
| Found Parrot AR. DRONE | iceman77 | Aircraft - Electric - Helis (FS/W) | 3 | Mar 15, 2011 01:51 PM |
| Discussion Piloting Drone From iDevice BUT takeoff/landing from a computer | chope1 | Multirotor Talk | 0 | Mar 07, 2011 10:12 AM |
