Taiwan
Joined Aug 2011
Kelly it sounds great to me,looking forward to the new info. we have a VTOL contest game here on 2nd Oct.2011,I wish I could finish this ball drone by end of this month and go for the game. the drone reminds me the twincopter project I've done last year, it's hard but it's fun. have a nice day Sam
PICT0128PICT0172 |
Shameless plug for my blog coming,
If you trawl through this page there are lots of multirotor videos http://www.suasnews.com/category/multirotor/ These might be the videos you were thinking of The Floss Weekly interview
CopterControl does not have a mag |
Joined May 2010
Japanese ball physics
Hello Sam,
Here are three rough sketches I made, please excuse my poor penmanship as my right hand is still very sore, but I think you’ll get the idea. Plate number one, shows three rockets, the first rocket has standard size fins with the center gravity head of the center pressure, the second rocket has fins that are approximately twice as large, and you'll notice that the center of pressure moves aft. Of course the center gravity would move at the little aft too since the larger fins has some mass, but I'm just trying to illustrate the concept of the center pressure. The third rocket has equal amount of fin area ahead of center gravity as well as aft and it is completely unstable, in some respects this resembles the current configuration of the Japanese sphere. Plate number two, shows four aircraft with varying configurations of horizontal and vertical tail volume's. The first two aircraft illustrate how the center pressure moves aft with an increase in tail volume, thus increasing stability. The lower two aircraft show various configurations of vertical and horizontal fin area. You will notice the center pressure moves ahead of the center of gravity and the craft becomes unstable, once again this represents in some respects the configuration of the Japanese sphere. Plate number three, shows two spheres, the first one representing the Japanese sphere, and the second one representing what I think would work best for you. On the first sphere, please notice that the center of pressure and the center gravity nearly coincide, this represents a marginally stable if not unstable aircraft without the use of a very sophisticated flight controller. Let's take a look at the second sphere. Please notice that the second sphere has only two small Yaw control vanes. These two small Yaw control vanes would be connected to the flight controllers Yaw Gyro. To make the craft Yaw to the left or right on its axis you would use the upper two small Yaw control vanes to initiate this movement, after this movement has been achieved, the Yaw vanes would return to a vertical or neutral position. This would represent the least drag above the center gravity Down below you'll notice 4 pitch and roll control vanes. Next please notice that the pitch and roll vanes are offset to compensate for all of the Yaw while the craft is in a stable hover. This off-set would be controlled from the transmitter trim only. Once again the lower pitch and roll vanes would hold this Yaw off-set at all times and it was set by you from the trim tap, this would take a transmitter mix to facilitate this offset. This offset would not be controlled by the Yaw Gyro, it is simply a fixed set trim that you set one time and forget about. The lower 4 control vanes are for pitch and roll and each has its own Servo. Each Servo would be connected to the flight controller Gyro's for pitch and roll control. The idea with this craft is to have the very minimum amount of control surface area ahead of the center of gravity, just like in the drawings I showed you about the rocket stability and airplane stability, you want to see the CG ahead of the CP. Please note that the skirts are directly below and slightly inside the very tips of the propeller where the air velocity is at the maximum. Please notice that the skirts are parallel to the airflow, that is, they are not offset any way. That way the angle of attack of these skirt plates are set to zero. It's very important that the skirts be the within the air stream of the propeller, you want to a surround the skirts with a blast of air from the propeller on both sides of the skirts. Please note that the small Yaw control vanes at the top are also within the air stream of the propeller, as close to the tips as possible. The velocity of air is the highest just slightly inside and below the tip of the propeller. The optimum size for the Yaw control vanes in my opinion would be quite long and narrow, that way they require very little deflection through a very low angle. This creates less movement of the center of pressure. Keep in mind, you always want G. before P., center gravity before center of pressure. Just remember when you say the alphabet the letter G. comes before the letter P. I hope that was clear enough, please let me know if I can add some more details. Please note, when you open up these photos Sam, if you double-click on the images they will upload to you a very large version of the photograph for you to look at in detail. Kelly
| Thread Tools | |
| Mini-HowTo RC Controlled AR.Drone w/o WiFi! | nosaari | Multirotor Talk | 113 | May 13, 2011 02:26 PM |
| Discussion New AR Drone (i-drone) light mod | bungle68 | Multirotor Talk | 3 | Apr 13, 2011 05:30 PM |
| Discussion AR Parrot Drone For Sale | webdr | Atlanta Area RC | 4 | Mar 16, 2011 07:41 AM |
| Found Parrot AR. DRONE | iceman77 | Aircraft - Electric - Helis (FS/W) | 3 | Mar 15, 2011 01:51 PM |
| Discussion Piloting Drone From iDevice BUT takeoff/landing from a computer | chope1 | Multirotor Talk | 0 | Mar 07, 2011 10:12 AM |
