Old Apr 04, 2012, 02:56 PM
billpa is offline
Find More Posts by billpa
billpa's Avatar
Joined Nov 2003
I sent a message to it through sub-ether radio.
billpa is offline Find More Posts by billpa
Site Sponsor
Old Jun 19, 2012, 11:10 AM
rrosas is offline
Find More Posts by rrosas
Joined Mar 2012
Saving G-Sensor data
I have a 3 Axis G-Force MicroSensor (GFORCE-LOW) connected to a eLogger V4. Both products were purchased less than two months ago and updated with lastest versions.
I can see the G-Force reading using the Eagle Tree Software in Live Mode, and play them back after downloading from the logger.
After saving the recorder file or session to a .CDR, In the recorder file only
Milliseconds IsEvent EventError EventData Altitude Airspeed ServoCurrent*100 Throttle PackVolt*100
Amps*100 Temp1*10 Temp2*10 Temp3*10 RPM GPSLat GPSLon GPSAlt
GPSSpeed GPSCourse GPSDist GPSUTC NumSats GPSFlags SpektrumHolds SpektrumLostFrames SpektrumAFades SpektrumBFades SpektrumLeftFades SpektrumRightFades GPSUTC-ASCII HDOP*10
titles appear, but no G Force readings.
After opening the previously saved recorded CDR file the G-Force paramaters are lost and no data is displayed.
How can I save the G-Force parameters?
Thanks!
rrosas is offline Find More Posts by rrosas
Old Jun 19, 2012, 10:27 PM
billpa is offline
billpa's Avatar
Joined Nov 2003
HI rrosas,
Can you let me know which version of our software you are running (under "help, about")? Thanks.
Site Sponsor
Old Jun 20, 2012, 09:56 AM
rrosas is offline
Joined Mar 2012
Hi Bill,
I'm using eLogger Application 10.04.
Also did try with the beta 10.38 but had the same results. (with their matching firmware versions 1.15 and 1.21 respectively)
It is probably an issue where the software is not saving all the parameters.
Yesterday I created a plane model instead of a car model.
Now the file is recorded as an .FDR instead of a .CDR
The .FDR from the plane model now includes the GForceX*100 GForceY*100 GForceZ*100 parameters!
Apart from the labeling and speed calculation, what is the difference between a plane and a car model?
If I'm using a car, what difference would it make if a plane model is selected?
Thanks!
Old Feb 29, 2016, 04:27 PM
PDN2000 is offline
Find More Posts by PDN2000
Spain, Community of Madrid, Madrid
Joined Jun 2014
Hello,
I am having the same problem explained by rrosas. It seems that no solution has been put in the forum. Does it exist? Bill can you help us? I am using the latest software version.
Thanks!
PDN2000 is offline Find More Posts by PDN2000
Old Jun 30, 2016, 09:57 AM
Scirocco14 is offline
Find More Posts by Scirocco14
Scirocco14's Avatar
Asheville, NC
Joined Mar 2009
Sorry for bumping an old thread.
I'd like to record g's and speed on my RC on-road carpet racecar. Does the software provide mph from the data log of g's? This will help me determine the effects of gearing and motor timing on speed, acceleration and laptimes.
Anybody know?
Thanks!
Mark
Scirocco14 is offline Find More Posts by Scirocco14
Discussion ScaleAndTile3 - Placeholder for 25 December 2007 Release segraves Foamies (Scratchbuilt) 2 Dec 02, 2007 10:38 AM
