Old Jun 11, 2011, 02:10 PM
guerradr is offline
Find More Posts by guerradr
Joined Feb 2007
Problems programming the KKmulitcopter blackboard V5.5
Dear Community
I have problems flashing my KKmulitcopter Blackboard V5.5.
I use a USBasp Programmer in combination with eXtreme Burnver - AVR. The installation of the USB Driver (fischl.de) for the Programmer and the Flashing Software eXtreme Burner was no Problem on a WinXP Laptop.
I started according the Tutorial on the kkmulitcopter website "Programming the IC with eXtreme Burner". According to this Tutorial, one should read the Fuse Bits from the IC. This worked fine for me. After this I wrote the Fuse bits according Fuse Calc (AtMega 168PA) to the Chip. From this moment on the KKBoard stopped replying to the Software. I tried to erase the Chip via the Software Interface but there was always the same Error: "Power On Failed" and "Cannot Communicate with Target Chip!".
When the the eXtreme Burner Software tries to read or write something to the KKBoard the LED's on the USBasp and the KKBoard are blinking synchronously.
Can somebody please help me!
guerradr is offline Find More Posts by guerradr
Old Jun 11, 2011, 04:41 PM
n3m1s1s is offline
Find More Posts by n3m1s1s
UK, Buckinghamshire, High Wycombe
Joined Feb 2007
n3m1s1s is offline Find More Posts by n3m1s1s
Reply With Quote  (Disabled)
Old Jun 12, 2011, 04:17 AM
guerradr is offline
Joined Feb 2007
yes, I got the board from ebay (devpacific).
Is there any way to hard reset the IC on the board? Or is this only possible via the prog. USBasp?
The strange thing is that it initially worked and then after writing the Fuse bits to the IC it stopped working. But the LED's still blink when the Software tries to communicate with the KKBoard.
Do you think I should return the board? I still have 6 days to return the product.
Old Jun 12, 2011, 04:27 AM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
I would suggest owning a proper programmer for atmel chips if you plan to have hardware with them.
timecop is offline Find More Posts by timecop
Old Jun 12, 2011, 05:19 AM
Mike Barton is offline
Find More Posts by Mike Barton
United Kingdom
Joined Nov 2008
If it initially worked, and after programming it doesn't, chances are you have accidently either:
  1. Set it to use an external oscillator/crystal
    Fix: remove LED or R7 and temporarily solder external 8/16/20 Mhz xtal onto Xtal pins 7 & 8
  2. disabled Serial Programming
    Fix: not really
Buying a proper programmer saves mucho hassle ...
Mike Barton is offline Find More Posts by Mike Barton
Old Jun 12, 2011, 06:04 AM
guerradr is offline
Joined Feb 2007
Hi Mike
Thanks for your advice.
I will try your Fix No. 1. But what do you mean with no fix for No.2? Is there really no solution if I accidentally disabled Serial Programming?
What if I just exchange the Atmel Chip with a new one? Would that fix issue No.2?
Greets
Old Jun 12, 2011, 06:05 AM
timecop is offline
Joined Dec 2010
Sure it will.
Old Jun 12, 2011, 06:42 AM
United Kingdom
Joined Nov 2008
hi guerradr
try the crystal mod, if that doesn't work, then you'll have to change the chip....
Old Jun 15, 2011, 03:02 PM
guerradr is offline
Joined Feb 2007
Dear Mike
I found a good article to recover from a "locked out" AVR. (http://www.avrfreaks.net/index.php?n...topic&t=106325). I purchased myself a Atmel AVRISP mkII and I will try to get my board up and running again. I will post my results here.
Old Jun 15, 2011, 06:59 PM
bamm is offline
Find More Posts by bamm
bamm's Avatar
Planet Jupiter
Joined Jan 2005
I am having the same problem with my KK blackboard. I bought mine off eBay (discovered the ad here on RCG from Terriwang) Mine came with the USBASP 4.0 dongle. I installed all the software as Terriwang has included in his Zip file. I am using a program he included called "progisp"
I keep getting a message after I try to flash the board "CHIP ENABLE PROGRAM ERROR"
Also, what do you guys mean "propper programmer"? Is the USBasp dongle not good?
P.S. I have never tried using my board on my quadcopter yet. I have only tried flashing it. It has never been hooked up to an RC receiver nor ESC power.
bamm is offline Find More Posts by bamm
Old Jun 21, 2011, 03:01 PM
guerradr is offline
Joined Feb 2007
Hi bamm
I'm sorry to hear that I'm not the only one having this problem. I also have such an USBASP Programmer like you. This is also where the problems started.
With the term "propper programmer" they mean an original programmer from Atmel like:
STK600
AVRISP mkII
With this programmers you're also able to give the chip a reference clock, in case you disabled the internal one per fuses.
Well I will try to programm my board with an AVRISP mkII. It arrived this week, I will be able to check it out this weekend. I will keep you posted.
Greets
Old Jun 27, 2011, 06:20 AM
guerradr is offline
Joined Feb 2007
Dear Community
I solved my problem. I bought myself an original AVRISP mkII programmer from the atmel shop. I hooked up everything as described in the Tutorial "Programming the IC with AVR Studio 4". I set all the fuses accordigly and I did not see any wrong settings there.
The problem was generated from my USBASPV 4.0 (USBasp) which was unable to program the chip correctly.
Thanks for the support.
Old Jun 27, 2011, 08:25 AM
timecop is offline
Joined Dec 2010
Yep. Anyone who has trouble with cheapass USB-ASP knockoffs should just buy the real thing. In addition to perfectly working programmer, you will also be able to program at much faster speed, and it won't randomly break or refuse to work.
Old Jun 27, 2011, 10:15 AM
kristjane is online now
Find More Posts by kristjane
Have a nice day! Kristjan
kristjane's Avatar
Slovenia, Novo mesto, Šentjernej
Joined Jan 2006
I had same problem. Just changed ATMEGA168PA with new one and it started working. It takes less than 5min to replace it with new one.
kristjane is online now Find More Posts by kristjane
Old May 29, 2012, 11:15 AM
morlok is offline
Find More Posts by morlok
Joined May 2012
I had the same problem with a cheap usbasp bought on ebay, gave me the error "power on failed", the problem was that it was bad soldier the clock output pin (SCK). Now it works perfectly.
morlok is offline Find More Posts by morlok
Sold KK V.5.5 Blackboard Huskiemuskie FPV Equipment (FS/W) 0 Apr 02, 2011 09:35 AM
Sold KK V.5.5 Blackboard (NIB) Huskiemuskie Aircraft - Electric - Helis (FS/W) 2 Apr 02, 2011 09:19 AM
Discussion KK Controller V 5.5 Blackboard problems, please help me! staflaraf Multirotor Talk 9 Feb 26, 2011 11:14 AM
Discussion Jive +80LV Programming V5 02deuce Kontronik 8 Jan 14, 2009 12:26 PM
