Old Jun 10, 2011, 04:31 PM
daddyboy2 is offline
Find More Posts by daddyboy2
Joined Jun 2011
Turnigy 9X 9Ch Transmitter V2
Hi All , is anyone using this , I have just brought it and havent received it yet , so Im after a lipo batt back for the transmitter , can anyone help me on one that will fit .
cheers
Turnigy 9X 9Ch Transmitter w/ Module & 8ch Receiver (Mode 2) (v2)
anyone using this ?
daddyboy2 is offline Find More Posts by daddyboy2
Old Jun 10, 2011, 06:22 PM
t0wer is offline
Find More Posts by t0wer
Joined Mar 2011
http://www.hobbyking.com/hobbyking/s...idProduct=7346
or
http://www.hobbyking.com/hobbyking/s...dProduct=16529
both will work fine, but you have to use the connector on the battery holder that came with the radio.
t0wer is offline Find More Posts by t0wer
Old Jun 10, 2011, 10:16 PM
Kalikikopa is offline
Find More Posts by Kalikikopa
United States, HI, Kailua
Joined Jun 2010
cheers
anyone using this ?
I believe the two most active threads in this section are about the TH9X. I'm using the Flysky version with the ER9X firmware. I did have some problems when I bought new receivers and couldn't get them to bind. Fried my radio trying to get it to work. Ordered another one, and was able to fix the first one. Now I have 2. I was so pleased with this radio, that when I broke one, I bought another.
Kalikikopa is offline Find More Posts by Kalikikopa
Old Jun 10, 2011, 10:37 PM
John Kim is offline
Find More Posts by John Kim
Panorama City, CA
Joined Sep 2004
New TX battery for sale.
http://www.rcgroups.com/forums/showthread.php?t=1452605
John Kim is offline Find More Posts by John Kim
Reply With Quote  (Disabled)
Old Jun 11, 2011, 11:24 PM
Joined Jun 2011
do you know if they have good range , ? im going to use it in a rc power boat
Old Jul 21, 2011, 04:18 AM
Joined Jun 2011
the arieal on this tranmitter , does it need to be up or down if im running it to control a boat ?
Old Jul 21, 2011, 08:32 AM
Daedalus66 is offline
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
If you have a transmitter with the old metal telescoping antenna for FM and are using a 2.4 module, the FM antenna should be removed. If you mean which way should the 2.4 antenna be pointed, just avoid pointing it at the model as that gives minimum signal.
Daedalus66 is offline Find More Posts by Daedalus66
Old Jul 21, 2011, 11:11 PM
John Kim is offline
Panorama City, CA
Joined Sep 2004
You must tell us which radio you are using. FM or 2.4 module.
Old Jul 22, 2011, 10:53 AM
rob.thomson is offline
Find More Posts by rob.thomson
openrc*****s *****
rob.thomson's Avatar
United Kingdom, England, Guildford
Joined Sep 2010
Just incase thereis anyone out there looking to convert their radio to an internal frsky system, I found these - they look quite usefull!
http://www.rcplanet.com/ProductDetai...PA615&CartID=1
Rob
rob.thomson is offline Find More Posts by rob.thomson
Alert Turnigy 9X 9Ch Transmitter w/ Module & 8ch Receiver (Mode 2) (v2 Firmware) tallflyer Electric Plane Talk 32 May 24, 2014 11:12 PM
Discussion Turnigy 9X 9Ch Transmitter w/ Module & 8ch Receiver (Mode 2) (v2 Firmware) burhead27 Utah Flyers Organization 19 Mar 19, 2011 09:44 AM
Sold New Flysky th9x/ turnigy 9x mode 2 V2 transmitter,module and 8 channel receiver jgpncll Aircraft - General - Radio Equipment (FS/W) 1 Mar 10, 2011 07:46 PM
Discussion hobbyking Turnigy 9X 9Ch Transmitter (v2 Firmware) any experience? jitup Radios 1 Jun 09, 2010 05:54 PM
Sold Turnigy 9X 9Ch Transmitter (Mode 2) and 2 recievers FieldofDreamsFlyer Aircraft - General - Radio Equipment (FS/W) 2 May 19, 2009 12:31 AM
