Old Aug 26, 2003, 01:49 PM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
How to solder a Deans Ultra connector
This is buried in another thread. For benefit of those not participating there, I'm posting a new thread.
http://www.ezonemag.com/~awilletts/deansultra.mpg
Feedback appreciated - I had the wires reversed last time!
New lighting, removed music (copyright), etc.
..a
Old Aug 26, 2003, 01:55 PM
gregg f is online now
Find More Posts by gregg f
Purple power
gregg f's Avatar
shadow hills,ca
Joined Apr 2000
looks good Andy
gregg f is online now Find More Posts by gregg f
Old Aug 26, 2003, 02:34 PM
Flybyguy is offline
Find More Posts by Flybyguy
Go Giants!
Flybyguy's Avatar
San Mateo, California, United States
Joined Jun 2002
Thank you! I was struggling with soldering the connectors earlier (took a break because the iron slipped back and burned a finger just behind the nail). Now I will give it another go, hopefully more successfully!
Brian
Flybyguy is offline Find More Posts by Flybyguy
Old Aug 26, 2003, 02:52 PM
Pierre Audette is offline
Find More Posts by Pierre Audette
RPV builder & operator
Pierre Audette's Avatar
Canada, QC, Gatineau
Joined Jan 2001
Another little trick to helps minimize damage is to plug the connector into its mating end. Helps maintain alignment and reduce potential distortion of the plastic and movement of the contacts.
Pierre Audette is offline Find More Posts by Pierre Audette
Old Aug 26, 2003, 03:27 PM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
This can actually cause distortion, according to some. I have never experienced that problem, and there's not enough heat or time the way I show it being done for any deformation to be a problem..
..a
Old Aug 26, 2003, 04:15 PM
Joined Jan 2001
Why, because of the pressure from the mating contacts?
Happy|Harry is offline
Find More Posts by Happy|Harry
veni,vidi, roto volubilis
Happy|Harry's Avatar
Aberdeen, Scotland
Joined Jul 2003
Nice one andy
phil
Happy|Harry is offline Find More Posts by Happy|Harry
Old Aug 26, 2003, 05:24 PM
RMihara is offline
Find More Posts by RMihara
Aerial Shutterbug
RMihara's Avatar
Joined Nov 2001
Very nice Andy.
I must admit when I saw the part where you clamped the connector down I was expecting to see it go zinging across the workbench...not that it's ever happened to me
Using a hot iron with a big tip really makes the difference in soldering large conductors and contacts and in the case of the Ultras, makes all the difference in the world in getting a good clean connection.
Distortion of the plastic housing is a problem if you keep an iron on the contact too long during soldering. Sometimes, when mated, the connectors have an unbalanced stress (one contact is pushed in just a wee bit more than the other) and during soldering, could shift because of this.
Ensuring you heat up the conductor first then the contact as in Andy's video will help to minimize this problem. Now if you heat up the conductor too much, your heatshrink will be pre-shrunk!
Regards,
Roger
RMihara is offline Find More Posts by RMihara
Old Aug 26, 2003, 06:04 PM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
The point to my video is to show 'how quick and simple' it is. I should do another showing them being unplugged, right?
.a.
Old Aug 26, 2003, 07:08 PM
RMihara is offline
Aerial Shutterbug
RMihara's Avatar
Joined Nov 2001
Actually now that you mention it, I saw a fellow flyer recently who drilled a small hole between each conductor and installed small pulling loops with 20 lb monofilament. Pretty idea!
Roger
Old Nov 06, 2003, 04:52 AM
plane stupid is offline
Find More Posts by plane stupid
space for sale
plane stupid's Avatar
Detroit City, Michigan, United States
Joined Sep 2003
I have a Q what can you use to heat up the heat shrink i have no clue
plane stupid is offline Find More Posts by plane stupid
Old Nov 06, 2003, 05:49 AM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Heat gun - same as used to shrink covering.
If you don't have one, you can hold a lighter a couple of inches below, but I suggest you practice a lot first so you don't burn the shrink or connector!
..a
Old Nov 06, 2003, 05:53 AM
Fantam is offline
Find More Posts by Fantam
Go Leafs Go!
Fantam's Avatar
Georgetown,ON,Canada
Joined Jan 2002
Just use a match or butane lighter. Hold it a couple of inches below the heat shrink and keep it moving.
Fantam is offline Find More Posts by Fantam
Old Nov 06, 2003, 09:44 AM
Jeff Meyers is offline
Find More Posts by Jeff Meyers
Jeff Meyers's Avatar
Fayetteville, GA
Joined Oct 2000
Very good video Andy. I have a 40 watt soldering iron from Radio Shack....what tip and iron are you using?
I've been using a soldering gun to do my Sermos connectors...
I may go pick up a few packs of Deans to see how I like them. My only beef with Sermos has to do with the fact that I can't get 12 gauge wire in the contacts. Consquently...you have to snip a little wire so they fit in the contact. This creates a little more resistance....
On the other hand....the Sermos connectors daisy chain without harness adapters.....with the Deans...you would have to make adapters to series two packs right? This would also create more resistance....
There's no free lunch here...
Jeff Meyers is offline Find More Posts by Jeff Meyers
Old Nov 06, 2003, 09:51 AM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
I'm not trying to change the world. I just have no problem soldering (or unplugging) these connectors. I've measured the resistance of all types except the 4mm gold pins, and was happy I had chosen the Ultras.
I use a 40W Weller iron. My old RadioShack one died, so I picked up a new Weller @ Home Depot for $15. Has a larger chisel tip than the previous RadioShack one..
..a
Discussion How Many Amps can a Deans Ultra Connector handle ??? Tracon Power Systems 9 Nov 01, 2006 05:25 PM
How to solder deans connectors... newflyer Electric Plane Talk 20 Jul 11, 2004 12:57 PM
Deans Ultra connector source ? rszanti Power Systems 9 Jun 20, 2003 12:04 PM
What is the max. amps for he1100 cells? How about deans ultra connectors? aeropenguin Power Systems 31 Mar 01, 2003 11:44 PM
Please help...trying to solder Deans Ultra plugs Lennier Power Systems 4 Sep 06, 2001 11:29 PM
