Old Jun 10, 2011, 09:23 AM
wolfewinde is offline
Find More Posts by wolfewinde
My Co-Pilots Rock!!
wolfewinde's Avatar
United States, FL, Clearwater
Joined May 2011
Hobby Lobby 50" Tiger Moth
Just FINALLY getting around to trying to build this airplane. Anyone still flying one of these?
Wolfe
wolfewinde is offline Find More Posts by wolfewinde
Old Jun 10, 2011, 02:05 PM
Tim Wolff is offline
Find More Posts by Tim Wolff
Gravity is a harsh mistress.
Tim Wolff's Avatar
United States, MI, Temperance
Joined Sep 2002
Here's some links. I think mine is posted in there somewhere.
The "shorts bunching" maiden flights that seem to be reported by some seem to be the result of folks that don't know how to properly balance an airplane. I was really wound tight for my first flight trying to prepare for the worst and this plane is a pussycat in the air. The tracking and handling on take-off was also a pleasant surprise. You do have to mind the nose after touchdown. I once scraped the bottom of the cowl almost all the way down the asphalt runway once.
http://www.rcgroups.com/forums/showthread.php?t=493901\
http://www.wattflyer.com/forums/showthread.php?t=7342
http://www.rcgroups.com/forums/showt...hlight=Pacific
http://www.rcgroups.com/forums/showt...t=246851&pp=15
http://winnerrc.com/Arfairplane/TM30...th30Detail.htm
Tim Wolff is offline Find More Posts by Tim Wolff
Old Jun 10, 2011, 06:07 PM
My Co-Pilots Rock!!
wolfewinde's Avatar
Joined May 2011
Thanks for the threads. Does anyone still make this airplane?
Old Jun 10, 2011, 09:12 PM
Tim Wolff's Avatar
Joined Sep 2002
Powerline Hobbies has it listed on their site. Same place I got mine. It is the glow version though. Give Gene a call over there if you are still looking for one.
http://www.powerlinehobbies.com/singleoutput.php?id=233
I still have one on backorder with Hobby Lobby from when they were closed out last year. I don't know the actual status or if they are attempting to get more. I almost bought the 72" version then too. I'm thankful I didn't because of the new Maxford 105" Tiger Moth
http://www.maxfordusa.com/105tigermotharf.aspx
Oh crud! On sale too! Must resist
Old Jun 11, 2011, 04:34 PM
JRuggiero is offline
Find More Posts by JRuggiero
Blacksburg, VA 24060 USA
Joined Feb 2000
Tim Wolff
"I once scraped the bottom of the cowl almost all the way down the asphalt runway once."
I recommend a tiny cheater nosewheel, discreetly let into the bottom of the cowling. I'm installing one on the bottom of the hull of a non-scale flying boat that will also have interchangeable tail-dragger wheels.
Jim R.
JRuggiero is offline Find More Posts by JRuggiero
Old Jun 13, 2011, 01:02 AM
My Co-Pilots Rock!!
wolfewinde's Avatar
Joined May 2011
Mine is built and ready to maiden. Does anyone know where you are supposed to set the CG???
Old Jun 13, 2011, 07:25 AM
Tim Wolff's Avatar
Joined Sep 2002
I'm flying mine with the CG about 4" back from the LE of the center top wing with the stab level. CG checked with my fingers.
Start at 3 3/4" back and go from there. Working the CG back is a lot easier than working it forward.
Old Jun 14, 2011, 05:53 AM
My Co-Pilots Rock!!
wolfewinde's Avatar
Joined May 2011
Thanks, Tim
I will follow your advice.
Wolfe
Old Jun 14, 2011, 07:55 AM
Tim Wolff's Avatar
Joined Sep 2002
FWIW. I also put a bit of washout in all four wing panels. 1/8"-3/16" get the job done.
Also keep an eye on the screws that mount the cabane struts to the fuselage. The wood screws called for in the instructions kept backing out (or maybe they were actually tearing out) on me. I installed 2-56 tee nuts inside the fuselage and used machine screws. I wound up replacing all the strut mounting bolt/nut assemblies with 2-56 tee nuts and machine screws since I had to order 4 for the cabane struts, ordering 16 didn't cost much more.
Old Jun 14, 2011, 09:16 AM
My Co-Pilots Rock!!
wolfewinde's Avatar
Joined May 2011
Thanks for the info, Tim.
I already replaced the strut and carbane bolts with a locknut version. I did not think to check the washout, though - will do that before I maiden her. I really don't want to crash this one, so not in a hurry for the maiden. Should be sometime this week though. Waiting for pretty calm winds for the first flight.
Wolfe
Old Jun 20, 2011, 09:25 AM
My Co-Pilots Rock!!
wolfewinde's Avatar
Joined May 2011
Well I got in the Maiden Flight on this bird this morning. I could tell when she lifted off she was a touch tail heavy and wanted to go right. So I took her to about 200 ft and trimmed her out. Man I was nervous about this maiden and when she went up tail heavy I was REALLY nervous.
All went well, though. got her trimmed out and just flew some easy eights to get used to her. She is a lot faster than I was expecting. Landing was pretty smooth - just a small bounce and she rolled out fine on the grass.
Looking forward to when I can get relaxed and really enjoy this plane. She is stunning in the air. Just very thankful she came home in one piece today.
Question - Do I need to worry about the pull-pull wires loosening up while she is in flight?
Wolfe
Sold Hobby Lobby 50" Tiger Moth NIB Wing&aPrayer Aircraft - Electric - Airplanes (FS/W) 5 Sep 09, 2010 11:34 PM
Found Hobby Lobby 50" Tiger Moth fred_n Aircraft - Electric - Airplanes (FS/W) 1 Oct 02, 2009 09:49 PM
Discussion 50" Tiger Moth by Hobby Lobby, CG diver don Scale ARF/RTF 5 Aug 06, 2009 03:44 PM
For Sale Hobby Lobby Tiger Moth 50" goflyhighrc Aircraft - Electric - Airplanes (FS/W) 0 Jun 07, 2009 05:50 PM
For Sale Tiger Moth - 50" from Hobby Lobby - REDUCED Solid Hit Aircraft - Electric - Airplanes (FS/W) 6 Mar 18, 2007 07:46 AM
