Old Aug 02, 2011, 07:05 AM
earlwb is online now
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
One thought is to not run the spar all the way out to the tips and even taper the spar out on the ends. Then you can bring the two wing sides together to glue them together etc.
Like on these two planes here with rounded wingtips.
earlwb is online now Find More Posts by earlwb
Old Aug 03, 2011, 09:29 PM
villapilote is offline
Find More Posts by villapilote
Wilson, NC
Joined Aug 2009
I stand the wing on end on a blank sheet of paper and trace the outline of the wing end. I then free-hand a trace inside this trace that is smaller by the thickness of the wing Coroplast. I then cut out the trace and cut it out of 2MM Coroplast. I glue it into the inside of the wing end using silicone automotive adhesive sealant after roughing up the inside surface with sandpaper. I have done it on 2 planes, but most of my planes are open at the ends. I run the flutes vertical.
villapilote is offline Find More Posts by villapilote
Old Aug 03, 2011, 09:32 PM
Wilson, NC
Joined Aug 2009
I stand the wing on end on a blank sheet of paper and trace the outline of the wing end. I then free-hand a trace inside this trace that is smaller by the thickness of the wing Coroplast. I then cut out the trace and cut it out of 2MM Coroplast. I glue it into the inside of the wing end using silicone automotive adhesive sealant after roughing up the inside surface with sandpaper. I have done it on 2 planes, but most of my planes are open at the ends. I run the flutes in the Coroplast vertical.
Old Oct 01, 2011, 05:20 PM
n3m1s1s is offline
Find More Posts by n3m1s1s
UK, Buckinghamshire, High Wycombe
Joined Feb 2007
for flat wings kf foil type run a bbq wood skewer from front to back for each layer a couple mm in from the outside edge if that makes sence? makes tips stronger too
n3m1s1s is offline Find More Posts by n3m1s1s
Reply With Quote  (Disabled)
Old Oct 13, 2011, 12:22 PM
jib is offline
jib
Find More Posts by jib
jib
Chief Mechanic for my son
Covington, WA
Joined Oct 2008
I agree with Ernie about keeping it simple too, but the easy way to plug it is with a thin piece of foam.
jib is offline Find More Posts by jib
Old Nov 18, 2011, 04:02 PM
burlesontom is offline
Find More Posts by burlesontom
Joined Nov 2011
I set my wing on a scrap piece of coro and traced the shape. I cut that peice loose. Then I marked what looked like 4mm inside the line. I cut that out and had to trim just a little but got it fit inside the wing and used thick C.A. to hold it in place.
I doubt it made any difference but I am anal.
burlesontom is offline Find More Posts by burlesontom
Question SPAD's and electric motors VonStalhein SPAD - Simple Plastic Airplane Designs 8 Apr 08, 2011 07:46 PM
Discussion What type of covering/plastic is used on the ultra micro eflight 300? yzguy Foamies (Scratchbuilt) 4 Mar 15, 2011 08:10 AM
Discussion best method for attaching wingtips SPARTMAN Flying Wings 20 May 11, 2006 02:26 PM
What's the easiest way? Please help!!!! Shane Sizemore Foamies (Kits) 1 Mar 04, 2004 04:28 PM
Covering - What the easiest color? danawatson Electric Plane Talk 6 Feb 19, 2004 08:46 AM
