Old Jun 12, 2011, 06:39 AM
slebetman is offline
Find More Posts by slebetman
slebetman's Avatar
Malaysia, Selangor, Kajang
Joined Jun 2009
Here are a few color schemes I'm considering. All photoshopped from the last photo I took of the bipe.
slebetman is offline Find More Posts by slebetman
Old Jun 12, 2011, 07:06 AM
sbfaisal is offline
Find More Posts by sbfaisal
Joined Oct 2010
looking great, what power system u r thinking to use on it.
keep up the good work
sbfaisal is offline Find More Posts by sbfaisal
Old Jun 12, 2011, 07:22 AM
EZglider is offline
Find More Posts by EZglider
It's Just Foam!!!
EZglider's Avatar
Canton,Ga
Joined Apr 2010
Personal vote: Go with either #1 or #4. Like them BOTH on this plane. Maybe try black edges on the blue patterns on #1 would make it a clear winner to me. Looking Good!
EZglider is offline Find More Posts by EZglider
Old Jun 12, 2011, 07:43 AM
Aero Andy is offline
Find More Posts by Aero Andy
ExPat
Aero Andy's Avatar
Spain, Murcia, Mazarrón
Joined Apr 2010
I vote for #1 or #2.
Andy
Aero Andy is offline Find More Posts by Aero Andy
Old Jun 12, 2011, 08:14 AM
dz1sfb is offline
Find More Posts by dz1sfb
Ken's CAD Models
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
An attractive, seemingly well thought out model. Been wanting to build a nice aerobatic (not 3D) bipe. Will be considering this one.
My vote is cast for #2. It has a touch of originality. Awesome job on the photoshopping work on all of them.
Any thoughts about landing gear?
Ken
dz1sfb is offline Find More Posts by dz1sfb
Latest blog entry: Mini H Quad Project
Old Jun 12, 2011, 08:18 AM
slebetman's Avatar
Joined Jun 2009
I'm going with this motor: AX 1806N 2100kv.
It's what I used on the prototype. On 2s with a 6 inch prop it draws just under 10A generating roughly 250g of thrust. That's why my target weight is 200g. It also gives me the option to move up to 3s which would draw roughly 15A generating more than 300g of thrust.
Old Jun 12, 2011, 08:21 AM
slebetman's Avatar
Joined Jun 2009
Here's another color scheme that I've found that looks really nice.
Old Jun 12, 2011, 08:26 AM
slebetman's Avatar
Joined Jun 2009
I'm still figuring that one out. I'm planning on making the wings removable (hence the split cabane struts). Now I find myself having to figure out how to take out the wings with the landing gear in the way.
One method that I've been thinking is to make the wheels removable. Sandwich the wires/rods between sheets of depron and make a slot that would fit in the fuse and you should be able to just slide the wheels in and out.
Old Jun 12, 2011, 09:14 AM
tymbrewolf is offline
Find More Posts by tymbrewolf
Joined Feb 2007
I like that motor with a 2s gws 7035...
tymbrewolf is offline Find More Posts by tymbrewolf
Old Jun 12, 2011, 01:19 PM
slebetman's Avatar
Joined Jun 2009
OK, made the wheels tonight. Used coat hangar wire for the struts sandwiched between pieces of 6mm depron.
Cut a slot on the bottom of the fuse for the landing gear to slide in. 6mm depron walls are epoxied in place. I had to use epoxy because I needed the alignment to be perfect for a tight fit and I didn't have much access to the internals of the fuse. Now we wait for the epoxy to cure in 12 hours.
Need to go to bed now. Got to wake up early for work tomorrow.
Old Jun 12, 2011, 06:46 PM
soulreaper is offline
Find More Posts by soulreaper
Joined Nov 2005
Slebetman, nice work!!!!. Thank you so much for sharing your plans and build pictures with us. I have already downloaded the plans, and I have most of the raw materials on hand.
soulreaper is offline Find More Posts by soulreaper
Old Jun 13, 2011, 01:56 AM
slebetman's Avatar
Joined Jun 2009
The plans are about 95% complete at the moment. You can, if you want to, start a build with the current plans (like I did) but you'll have to read my build carefully to see how I did the missing pieces.
I'll update the plans soon now that my build is mostly done.
Talking about plans.. I noticed some people prefer to print just half of everything: half a wing, half a fuse etc. Partly this is to save paper but some people also find it easier to cut just half a template and flip it over to mirror it for better symmetry. Anyone interested in that version of the plan? It would take me roughly 10 minutes to do.
Old Jun 13, 2011, 07:22 AM
silentsurfer is offline
Find More Posts by silentsurfer
tree scavenger
USA, OH, Cincinnati
Joined Sep 2006
Originally Posted by slebetman
...about plans...some people prefer to print just half....Anyone interested in that version of the plan? ...take me roughly 10 minutes to do.
Absolutely!
Tiled, in 'Letter' Pls !?
...thinking of trying one in epp, here, soon,, maybe,,,
nice gear rig, tried a similar method on my mini cub, employing a tight, slide in fit, wasnt road tested tho,,
Lookin Good!
silentsurfer is offline Find More Posts by silentsurfer
Old Jun 14, 2011, 01:19 AM
slebetman's Avatar
Joined Jun 2009
OK got her painted. Decided to go with the classic sunburst color scheme. Tried to do the curved version but gave up because it was too hard to mask.
I use regular spray can lacquer from the hardware store. As long as you keep the can an arm's length away while spraying and slowly count to 10 between spraying each successive layer it shouldn't eat up too much foam. In fact, on parts of foam with the skin still on (ie. not sanded) it shouldn't eat depron at all.
Build Log Shorts Skyvan 24 inch - test flight video gklein Scratchbuilt Indoor and Micro Models 65 May 01, 2011 10:51 AM
Found Cowl from HobbyKing Pitts-EP 42 inch ARF djmoose Aircraft - Electric - Airplanes (FS/W) 2 Apr 04, 2011 11:28 PM
Wanted WTB Herr 24" Pitts plans swapinthedark Aircraft - Electric - Airplanes (FS/W) 1 Mar 30, 2010 02:02 PM
Wanted WTB plans for the Herr 24" Pitts bipe. swapinthedark Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Mar 29, 2010 10:00 PM
Discussion 24, 30, or 35 inch shoestring kit or plans? paulatgis Sport Planes 4 Nov 01, 2009 06:32 PM
