Old Jun 28, 2011, 04:27 AM
sebbe is offline
Find More Posts by sebbe
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
Originally Posted by Flyextreme View Post
I'm using the Mega 16/35/1 which I beleive should have the same diam/lenth shaft.
Yes the gearbox comes with the pinion.
The 3650 flange fits perfect on mine.
If you can get the KPG27, the shaft is 6mm (32/6 spinner). The KPG25 is 5mm (32/5 spinner).
Bill
according to Bill, the 3650 fits perfect ...
OK, so it seems, you can use the 3500 and dremel up the hole to fit Megas, or you can use the 3650.
Bill, the mega motors have 10mm mount ring, and the 3650 flansche has a hole 10.6mm, is that ok, shouldnt the motor ring be the same size as the hole of the adapterflansche, this way the motor cant move in that direction at all, this makes the motor stay put in sideway no matter how much torqe the motor produce, if the hole on the flansche is a little bit bigger, then it is only the two M3 screws holding/center the motor on place..
Did you have to shorten the shaft on your mega 16/35/1 Bill ? It seems my shaft on the mega 16/40/1 is a little bit to long, and I dont like cutting shafts.
sebbe is offline Find More Posts by sebbe
Old Jun 28, 2011, 04:31 AM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
OK, so if I understand it all right, you are going to use the 3500 on your mega 16/40/1 , and dremel the hole up a bit.
But you have to cut a piece of the shaft away on your mega. otherwise its to long.
Old Jun 28, 2011, 10:16 AM
Flyextreme is offline
Find More Posts by Flyextreme
Sure it'll work
Flyextreme's Avatar
United States, CA, Redondo Beach
Joined Nov 2005
On my motor, acording to my measurements and dry fit, The shaft lenth is perfect. As a matter of fact, it's too perfect, so I will be taking a mm or so off the end of my shaft because even though it dosen't touch, I think it's too close to touching for my comfort. I have no idea if there's any variation between motors. I think if mine was even a 1/2mm longer it would bottom out.
I sent the 3600 back so I can't compare them now. I don't see any issues with my 16/35/1 fitting without mods. I have no idea about the 16/40/1.
I also have not even had a chance to start on any part of my X-plane yet.
Bill
Flyextreme is offline Find More Posts by Flyextreme
Old Jun 28, 2011, 10:26 AM
Dbox is offline
Find More Posts by Dbox
One Idiot is plenty...
Dbox's Avatar
United States, OR, Portland
Joined Jun 2005
Jacko,what's "MK-1 motor mount"?
It looks way too cool.
You did such a good build,I wish I could do the same work.
Yuri.
Dbox is offline Find More Posts by Dbox
Old Jun 28, 2011, 10:28 AM
Arcteryxxx is offline
Find More Posts by Arcteryxxx
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
Originally Posted by jackosmeister View Post
My vote is to go back flying for a month, then return to making kick ass toys for a few days, before taking another flying break for a few weeks...
MK2 motor mount trial fit, Mk1 was drilled for KPG25, KPG27 has different mount bolt spacing, doh, found some 125 thou T6 to make it from.
The small prop, 14.5x14, looks massive on the front, the 16x17 that is the end game prop is gonna be hugemongous!
Any chance I can buy the MK1 mount from you? I'm gonna use a KPG25...
Arcteryxxx is offline Find More Posts by Arcteryxxx
Old Jun 28, 2011, 10:30 AM
Dbox is offline
Dbox's Avatar
Joined Jun 2005
Sebbe,I will install You motor mount ,so You'll have more time to,not to work.Do You plan to use KPG27 ,or some other box?
Yuri.
Old Jun 28, 2011, 11:25 AM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
Yuri.
THANKS Yuri, Install the motor mount permanent, STRONG and beefy please. I will run serious powers
What material/thickness are you using ? is there an option, like carbon
Old Jun 28, 2011, 11:36 AM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
Oh YES...
I will run the KPG 27 + RFM spinner 32/6....
Thanks....
Old Jun 28, 2011, 02:00 PM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
Yuri, you dont happen to have just the white spinnerpart/top of the RFM 32/6..
This is the one I have:
http://shop.modellbau-freudenthaler....kir17lpfmp9q57
Is the white top removable ? well if you have one spare top, and dont mind give it a matching yellow or black paint, and send it with the plane, I can pay you extra for it, NP.
I hate the white colour..
Old Jun 28, 2011, 02:13 PM
Arcteryxxx's Avatar
Joined Feb 2010
I have a white 38/5 and the white tip is not removable... it is fastened to the spinner with a strip of CF and epoxy.
Old Jun 28, 2011, 02:31 PM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
Aha, Ok I learn all the time, guess I have to paint my own....
Old Jun 28, 2011, 03:02 PM
Thekid3418 is offline
Find More Posts by Thekid3418
The Kid
Thekid3418's Avatar
Detroit, MI
Joined Dec 2007
I think you'd be surprised. I have the same RFM 38/6 spinner, and the cone part come loose on one landing in long grass. Not even a jarring hit. I seem to remember this being a usual failure, as the carbon strip wouldn't bond well to the aluminum yoke of the spinner.
I applied JB Weld and it has stayed secured ever since. But i'm confident that with the proper coaxing you could get the spinner apart.
Kid
Thekid3418 is offline Find More Posts by Thekid3418
Old Jun 28, 2011, 03:17 PM
Arcteryxxx's Avatar
Joined Feb 2010
Then you have these: http://www.hyperflight.co.uk/product...for-6mm-shafts
Where the cone (plastic) is detachable, and where you can get other colors as spare parts:
"What colour cone is supplied & available?
All spinners are supplied with black cones, not white as shown in many of the illustrations. Extra cones are available in yellow, red, and orange, to match the Vladimir's Models standard gelcoat colours. Get them from the spares section."
Old Jun 28, 2011, 06:32 PM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
Yuri, Im going to bed now, late night here in Sweden..
Glue the motormount in for a KPG 27 gearbox, make it really strong, and if there is a choise of material, use the strongest you have and the one that will stick to epoxi best.
Good night...
Old Jun 28, 2011, 07:24 PM
Dbox is offline
Dbox's Avatar
Joined Jun 2005
Good night...
Can I use thesehttp://www.amazon.com/Diara-size-10-.../dp/B0002OI1NMfor Your motor mount?
Very strong and convenient ,You can get any size for same price
Yuri.
Discussion Blade MCP X - owner's thread rchelijc Micro Helis 13365 Jun 22, 2016 11:42 AM
Discussion MCP-X thread for people that dont have a MCP-x axelen Micro Helis 186 Apr 01, 2011 01:17 AM
Data mCP X (non chat) setup and tips owners thread Cable Guy Micro Helis 9 Mar 12, 2011 11:50 AM
Build Log Build Log - ARK X-500 series build thread cfrank2005 Electric Heli Talk 30 Jun 29, 2009 12:27 PM
RBC A-4 Skyhawk build thread X.X Willmsy Electric Ducted Fan Jet Talk 6 Nov 22, 2005 10:01 PM
