Old Jun 26, 2011, 08:35 AM
epwierman is offline
Find More Posts by epwierman
epwierman's Avatar
Joined Aug 2004
Yuri, are the linkages above rigged as you recommend? Also, what is the max servo height for a flush fit?
epwierman is offline Find More Posts by epwierman
Old Jun 26, 2011, 11:13 AM
Flyextreme is offline
Find More Posts by Flyextreme
Sure it'll work
Flyextreme's Avatar
United States, CA, Redondo Beach
Joined Nov 2005
Originally Posted by jackosmeister View Post
Yell out if anyone wants the A9 programming file, setup to Yuri's throw recommendations.
I would like the file. I still haven't changed my firmware (still on 1.07). I know I should do it, but do I "need" to go to 1.08 for the file to work proper?
Have you done your aentenna exit yet?
Bill
Flyextreme is offline Find More Posts by Flyextreme
Old Jun 26, 2011, 03:47 PM
jackosmeister is online now
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
Dunno if it'll work on 1.07, im using 1.08(0)
Full length ailerons on B (reduced aileron rates), crow on throttle (always on), throttle is on H, camber on LH slider, D is an up timer.
Rename .txt to .set
Sebbe - yup 4S and 14.5x14 for the maiden.
epwierman - Mines all closed up now, but DS09's will fit flush to the wing skin on flaps, And I dunno what you'd fit flush in the aileron cutouts, D47's are about all I can think of. Mine is double carbon which might make some difference, but the wing is VERY thin
Light speed is too slow!, gonna have to go right to ludicrous speed!
http://www.youtube.com/watch?v=ebAkXuOk9rg
jackosmeister is online now Find More Posts by jackosmeister
Old Jun 26, 2011, 04:08 PM
Sure it'll work
Flyextreme's Avatar
Joined Nov 2005
I really need to go to 1.08 anyway.
I compared the X-plane wing with the Viper wing and they are about the same thickness. The X-plane wing is still twice as thick as my 53" Blast (Excite) wing...but still pretty thin none the less. The Excite is probably the thinest wing I have seen...uber thin.
Bill
Old Jun 26, 2011, 04:34 PM
Auckland NZ
Joined Aug 2007
Wow, that excite wing must be crazy thin for the span, does it bend??! The stiletto which is ~39" is twice the thickness of the the X's wing!
I doubt there is a single proper F5D airframe in NZ
Old Jun 26, 2011, 05:02 PM
Sure it'll work
Flyextreme's Avatar
Joined Nov 2005
It's super way thin. Servo area is raised to meet the edge of the servo...a little like the RW4. The wing is very stiff/strong.
I will try and get pix comparing the wings. Yes, it's crazy thin.
EDIT: Not very good luck getting good pix. Upon closer inspection, the Excite wing at the root is about 30-35% thinner, and about 40-45% thinner in the middle of each side...still much, much thinner...practically half as thick.
Bill
Old Jun 27, 2011, 11:16 AM
sebbe is offline
Find More Posts by sebbe
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
Yuri, I hope not you are working to much ....
Im still eating
and
eating
sebbe is offline Find More Posts by sebbe
Old Jun 27, 2011, 01:51 PM
Dbox is offline
Find More Posts by Dbox
One Idiot is plenty...
Dbox's Avatar
United States, OR, Portland
Joined Jun 2005
I was flying all weekend,finally we got weather.
Now back to my misery.....
Will ship her at the end of the week.
Yuri.
Dbox is offline Find More Posts by Dbox
Old Jun 27, 2011, 02:24 PM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
Yuri.
Old Jun 28, 2011, 01:29 AM
Auckland NZ
Joined Aug 2007
Yuri.
My vote is to go back flying for a month, then return to making kick ass toys for a few days, before taking another flying break for a few weeks...
MK2 motor mount trial fit, Mk1 was drilled for KPG25, KPG27 has different mount bolt spacing, doh, found some 125 thou T6 to make it from.
The small prop, 14.5x14, looks massive on the front, the 16x17 that is the end game prop is gonna be hugemongous!
Old Jun 28, 2011, 01:45 AM
Sure it'll work
Flyextreme's Avatar
Joined Nov 2005
Very nice work jacko
Bill
Old Jun 28, 2011, 02:23 AM
Arcteryxxx is offline
Find More Posts by Arcteryxxx
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
This is a work of ART!!!!!!
Arcteryxxx is offline Find More Posts by Arcteryxxx
Old Jun 28, 2011, 02:37 AM
Auckland NZ
Joined Aug 2007
Haha, Yuri's x-plane is a work of art.
The motor mount just stops the power system from escaping out the arts nose..
Old Jun 28, 2011, 03:04 AM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
It seems Ive run into some problems, that shouldnt be there..
I have 2 megamotors, the 16/40/1 and the 16/25/1.5S
I did recieve my adapterflansche that should be the one for my KPG27 and my megas..according to the seller the FUN400/480 flansche is the RIGHT one.. OK ,,,,BUT ??? it doesent fit, look at my picture, the inner hole on the flansche is to small. megas have 10mm and the flansche has 9.5mm...
I send this pictures to the guy I did order from i Germany, explaing my situation, Then I recieved an email, and he says: the one he did sent, it is the right one for mega motors, you just have to dremel the hole up to fitt the megas.
Could someone please sort this mess up, I cant the last order, it has allready been paid for. But it wasnt so expensive..
I remember reading here that the" 3650 - Kontronik Adapterflansch SPEED480 Kurz" should be a perfect fit for a mega motor.. Im confused, but according to the first seller this it totally wrong adapter..
So just to be sure I did another new order yesterday from another place, I did order this two:
* 3600 - Kontronik Adapterflansch SPEED480
and
* 3650 - Kontronik Adapterflansch SPEED480 Kurz
Ive told the seller that I have order these two above, and he says, its wrong, wont fit,, hmm ??
Confused..
Old Jun 28, 2011, 03:14 AM
Auckland NZ
Joined Aug 2007
Right here sebbe -
http://www.rcgroups.com/forums/showp...05&postcount=5
http://www.rcgroups.com/forums/showp...2&postcount=22
Discussion Blade MCP X - owner's thread rchelijc Micro Helis 13393 Yesterday 11:29 PM
Discussion MCP-X thread for people that dont have a MCP-x axelen Micro Helis 186 Apr 01, 2011 01:17 AM
Data mCP X (non chat) setup and tips owners thread Cable Guy Micro Helis 9 Mar 12, 2011 11:50 AM
Build Log Build Log - ARK X-500 series build thread cfrank2005 Electric Heli Talk 30 Jun 29, 2009 12:27 PM
RBC A-4 Skyhawk build thread X.X Willmsy Electric Ducted Fan Jet Talk 6 Nov 22, 2005 10:01 PM
