Old Oct 16, 2011, 05:50 PM
GryphonRCU is offline
Find More Posts by GryphonRCU
GryphonRCU's Avatar
United States, CA, SF
Joined Mar 2008
Guys,
Will a 6S fit?
Gryphon
GryphonRCU is offline Find More Posts by GryphonRCU
Old Oct 16, 2011, 05:56 PM
jackosmeister is online now
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
Something around 1600-1800 mah may fit. Would require a careful build to make enough room though, and power on time wouldnt be long (but you would need much anyway )
jackosmeister is online now Find More Posts by jackosmeister
Old Oct 16, 2011, 05:58 PM
GryphonRCU's Avatar
Joined Mar 2008
Hopefully maximum possible "C" rating and top quality.
Gryphon
Old Oct 16, 2011, 06:07 PM
Dbox is offline
Find More Posts by Dbox
One Idiot is plenty...
Dbox's Avatar
United States, OR, Portland
Joined Jun 2005
Amazing sizes,weight and price,oh....and C rating
http://www.neumotors.com/store/index.html
Yuri.
Dbox is offline Find More Posts by Dbox
Old Oct 16, 2011, 07:36 PM
GryphonRCU's Avatar
Joined Mar 2008
I didn't see a small cell 6S on that exact page, but I'm fairly sure NEU makes a lot more packs than listed there.
Gryphon
Old Oct 16, 2011, 09:13 PM
Highfly! is offline
Find More Posts by Highfly!
Highfly!'s Avatar
United States, CA, Cameron Park
Joined May 2007
Yuri, always pushing boundaries! I like the 6S idea
Will start looking for a pack. I don't remember if Steve has any. Only concern may be the ESC as it will be operating on the edge.
Highfly! is offline Find More Posts by Highfly!
Old Oct 17, 2011, 12:41 AM
henke is online now
Find More Posts by henke
310mph Kolibri T25 Swist
henke's Avatar
Sverige, Kronobergs Lšn, Ljungby
Joined Jan 2001
http://www.hobbyking.com/hobbyking/s...Lipo_Pack.html
On the other hand... anyone trying to convert their input to maximum output rather then just increasing the input wattage? Thinking the use of a 22/20 rather then a 16/40 would be much better at the same weight. We tried alot of pylon setups over here pushing the 16/XX motors to alot of power(everything from pylonracers to funjets)... switching to a 22/20 increases the prop rpm by ALOT at the same input.
pretty good performance with a 7x4 prop :-)
http://www.youtube.com/user/HABElect...15/shchVnZkY6s
henke is online now Find More Posts by henke
Old Oct 17, 2011, 02:47 AM
GryphonRCU's Avatar
Joined Mar 2008
henke,
I thought this airframe needs 28mm, because 36mm diameter will not fit.
__________________________
22/30/X is much heavier than 16/40
16/40 out performs 22/30 because a none "E" 22/X motor is like a detuned 36mm motor.
22/30E has superior performance to 16/40
{ "E" in 28mm motor means something else than "E" in 36mm motor }
__________________
I'm not so sure 22/20E can outperform 16/40 .... prove it!!
(you also said by a lot. )
Make it all static data so no errors are introduced.
Edit:
***Take a stab at 16/35 if you think you can demonstrate that the 22/20E can outperform it by a lot.
Gryphon
Old Oct 17, 2011, 03:07 AM
Auckland NZ
Joined Aug 2007
Nah 36mm wont really fit. Would have to lop off a big chunk of the nose, which would result in CG issues.
Old Oct 17, 2011, 03:20 AM
henke is online now
henke's Avatar
Joined Jan 2001
Then I was informed wrong by someone :-)
http://www.rcgroups.com/forums/showp...63&postcount=2
(Neu is even 39mm)
Old Oct 17, 2011, 03:44 AM
Auckland NZ
Joined Aug 2007
Yup that was early in the build
Physically it'll fit if you cut the nose down, but CG, and batteries would likely be a very big issue
Old Oct 17, 2011, 03:58 AM
henke is online now
henke's Avatar
Joined Jan 2001
Maybe trade 50gram battery for 50grams of motor to gain efficiancy. 22/30 is 220grams due to the MEGA website. Good for CG and lower input power calls for smaller batteries.
Just suggestions as none are flying F5B useing 28mm motors these days.
Old Oct 17, 2011, 04:24 AM
Auckland NZ
Joined Aug 2007
None are flying 51" planes in F5B either Remember, its the size of an F5D racer.
28mm works well, I seriously dont think there'd be much to gain in loosing lipo room for the sake of a bigger, possibly more efficient, motor.
Have you got any data comparing 28mm megas to 36's ?
Old Oct 17, 2011, 04:44 AM
henke is online now
henke's Avatar
Joined Jan 2001
28mm works well,
Yes ofcause it does. Still intresting to improve things even though they seem pretty good from the beginning.
I guess that's why Yuri seem to be drawing on even faster designs, not because the X is bad but because there are always improvements to be made.
Old Oct 17, 2011, 01:04 PM
Arcteryxxx is offline
Find More Posts by Arcteryxxx
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
Hyperion Europe refused to help. Looks as if I'll be sending some servos over the pond tomorrow
So much for Hyperion customer service!
Arcteryxxx is offline Find More Posts by Arcteryxxx
Discussion Blade MCP X - owner's thread rchelijc Micro Helis 13302 Yesterday 09:47 PM
Discussion MCP-X thread for people that dont have a MCP-x axelen Micro Helis 186 Apr 01, 2011 01:17 AM
Data mCP X (non chat) setup and tips owners thread Cable Guy Micro Helis 9 Mar 12, 2011 11:50 AM
Build Log Build Log - ARK X-500 series build thread cfrank2005 Electric Heli Talk 30 Jun 29, 2009 12:27 PM
RBC A-4 Skyhawk build thread X.X Willmsy Electric Ducted Fan Jet Talk 6 Nov 22, 2005 10:01 PM
