Old Sep 08, 2011, 12:16 PM
Flyextreme is offline
Find More Posts by Flyextreme
Sure it'll work
Flyextreme's Avatar
United States, CA, Redondo Beach
Joined Nov 2005
Originally Posted by wollins View Post
In order to get the esc so tight up against the motor do you guys also cut/shorten the motor wires?
Colin
Here's one example.....
Flyextreme is offline Find More Posts by Flyextreme
Old Sep 08, 2011, 02:11 PM
wollins is offline
Find More Posts by wollins
"RC ADDICT" in Toronto!
wollins's Avatar
Toronto Canada
Joined Aug 2004
I know Bill ... I was referring to that very pic in my question. Did you cut the wires in this example?
If not ... should one ever cut the motor wires in order to get it closer? (I think I read somewhere that's it's a "no no" to cut motor wires? )
Colin
wollins is offline Find More Posts by wollins
Old Sep 08, 2011, 02:47 PM
jackosmeister is online now
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
Cutting motor wires is not a good idea, each strand is individually insulated (that browny/red coating on em), so if you cut them youll have to remove the insulation from every single strand to be able to resolder them. It has been done, but I wouldnt
Cutting esc wires is fine BTW.
jackosmeister is online now Find More Posts by jackosmeister
Old Sep 08, 2011, 03:33 PM
MagnusEl is offline
Find More Posts by MagnusEl
MagnusEl's Avatar
Sweden, Gävleborg County
Joined Jan 2004
On some motors the wire can be tinned a few centimeters, remove the shrink tube and you will see if they are. If not, just put new shrink tube on. If so, they can be cut a little, but I dont recomend it.
Every micro ohms count, right?...
MagnusEl is offline Find More Posts by MagnusEl
Old Sep 08, 2011, 03:41 PM
Sure it'll work
Flyextreme's Avatar
Joined Nov 2005
Colin
As mentioned... Cut esc wires only. Simply test fit "before" cutting. A "few" brave souls have soldered the motor leads directly to to esc...I'm not that adventurous.
Bill
Old Sep 08, 2011, 06:19 PM
wollins is offline
wollins's Avatar
Toronto Canada
Joined Aug 2004
Originally Posted by Flyextreme View Post
A "few" brave souls have soldered the motor leads directly to to esc...Bill
Really? I had gotten the impression that it was standard procedure to do it that way with hotliners and pylons ... I guess because I've always seen the motor/esc so close and everthing is covered in heat shrink.
So ... I'm assuming that you would use bullet connectors to connect the motor to the esc as in any "regular" (non "high performance") installation?
Colin
P.S. Good thing I asked ... I was about to do just that! (solder motor leads directly to the esc)
Old Sep 08, 2011, 06:27 PM
mumblety-peg is offline
Find More Posts by mumblety-peg
mumblety-peg's Avatar
USA, CA, Martinez
Joined Feb 2001
The motor leads are rather stiff... no? Wouldn't that lack of flexibility lead to the possibility of mechanical stress on the solder joint?
mumblety-peg is offline Find More Posts by mumblety-peg
Old Sep 08, 2011, 06:31 PM
Sure it'll work
Flyextreme's Avatar
Joined Nov 2005
Colin, No, I mean directly to the esc board/poles (no esc leads at all). This is done by a few, but not recommended.
Old Sep 08, 2011, 08:00 PM
wollins is offline
wollins's Avatar
Toronto Canada
Joined Aug 2004
Ok so just to confirm ... the preferred method IS to solder the motor leads directly onto the "shortened" esc leads, correct?
Colin
Old Sep 08, 2011, 08:13 PM
Sure it'll work
Flyextreme's Avatar
Joined Nov 2005
Colin
Yes Sir.
Sorry for any confusion.
Bill
Old Sep 08, 2011, 08:17 PM
Sure it'll work
Flyextreme's Avatar
Joined Nov 2005
I agree, it seems losing the "flex" wouldn't be good. But for those few that do it...there's likely a solution for that also.
Old Sep 09, 2011, 05:14 PM
Dbox is offline
Find More Posts by Dbox
One Idiot is plenty...
Dbox's Avatar
United States, OR, Portland
Joined Jun 2005
Originally Posted by Arcteryxxx View Post
Picked up mine from the post office an hour ago. Plane is perfect
Great packing job, Yuri!
Uff......such a relieve .
Thanx for update.
Yuri.
Dbox is offline Find More Posts by Dbox
Old Sep 12, 2011, 12:58 AM
Sure it'll work
Flyextreme's Avatar
Joined Nov 2005
Well, I got flights number #3 & 4 in with the X-Plane. I pretty uneventfull launches, and great flying.
One of my other planes (2M Weasel) didn't fair so well
Knowing I had to get right back on the horse, I flew the "X" once more after making a big hole in the ground with this one.
Bill
Old Sep 12, 2011, 01:29 AM
Arcteryxxx is offline
Find More Posts by Arcteryxxx
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
Ouch! That hurts.
Sorry for your loss.
Arcteryxxx is offline Find More Posts by Arcteryxxx
Old Sep 12, 2011, 03:54 AM
sebbe is offline
Find More Posts by sebbe
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
ouchhh Bill, Sorry man, what happend ?
sebbe is offline Find More Posts by sebbe
Discussion Blade MCP X - owner's thread rchelijc Micro Helis 13365 Jun 22, 2016 11:42 AM
Discussion MCP-X thread for people that dont have a MCP-x axelen Micro Helis 186 Apr 01, 2011 01:17 AM
Data mCP X (non chat) setup and tips owners thread Cable Guy Micro Helis 9 Mar 12, 2011 11:50 AM
Build Log Build Log - ARK X-500 series build thread cfrank2005 Electric Heli Talk 30 Jun 29, 2009 12:27 PM
RBC A-4 Skyhawk build thread X.X Willmsy Electric Ducted Fan Jet Talk 6 Nov 22, 2005 10:01 PM
