Old Aug 26, 2011, 04:32 AM
Arcteryxxx is offline
Find More Posts by Arcteryxxx
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
Jacko: could you please post pictures and explain the installation of the hook? I saw a glimpse and it looked very different than the trimmed wing skids I use on my heavy Strykers
Arcteryxxx is offline Find More Posts by Arcteryxxx
Old Aug 26, 2011, 04:48 AM
jackosmeister is online now
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
Hook is made out of 63 thou t6-7075 ali, cant remember the exact dimensions but its 75mm long
I cut a thin channel, not all the way through the fuse, just enough for it to bond nicely. Give the hook and the channel a clean up with acetone, stick it in with 24 hour epoxy, then run a couple of peices of carbon tow soaked in epoxy along each side of hook to help build a little glue gusset between the fuse and the hook.
Ive tested them to 15 kg's with no sign of failure, no bad habits when landing on em either, seem to be 100% so far.
On the X, the kapton tape is there to help the blades slide up the hook if they need to (and to see if they actually contact in flight!) Neither the blades, or the tape, have any contact marks on em so I doubt they even touch in practice, forces flick the blades out too quick.
Its hard to make out against the X's carbon, but its identical to the way the wasp's hook is mounted.
jackosmeister is online now Find More Posts by jackosmeister
Old Aug 26, 2011, 05:10 AM
Auckland NZ
Joined Aug 2007
The Fast Dot - Yuri's Models X-Plane. (3 min 45 sec)
Old Aug 26, 2011, 05:36 AM
Arcteryxxx's Avatar
Joined Feb 2010
Awesome!
Old Aug 26, 2011, 07:44 AM
sebbe is offline
Find More Posts by sebbe
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
Great.....
Jacko, did you put your own lube/oil in gearbox, or did you just leave it as it came.. ?
sebbe is offline Find More Posts by sebbe
Old Aug 26, 2011, 08:20 AM
MrMagic is offline
Find More Posts by MrMagic
>8-)
MrMagic's Avatar
Derby, UK
Joined Feb 2007
Nice one Jacko, would like to see the launch! Really tempted to PM Yuri now...
MrMagic is offline Find More Posts by MrMagic
Old Aug 26, 2011, 11:10 AM
Arcteryxxx's Avatar
Joined Feb 2010
Just gotta share the pictures I received from Yuri yesterday......
Old Aug 26, 2011, 04:24 PM
Auckland NZ
Joined Aug 2007
Originally Posted by sebbe View Post
Great.....
Kluber Isoflex.
Old Aug 26, 2011, 04:25 PM
Auckland NZ
Joined Aug 2007
The crazy thing is the X's fly even better than they look! And that one looks looks wicked!
daniel lö is offline
Find More Posts by daniel lö
Sverige, Hallands Län, Varberg
Joined Jul 2006
STOP! Please do not fly your x plane before checking this.
First of all yes i have a xplane i bought the second one that went to sweden from mattias.
This is a aileron only plane.
I was installing the servos when i discovered this :S
The balsa is cracked on both ailerons. I don't think that this is a shipping damage. I thinke this it the whipers that pushed the skin apart.
I hade no ide how long this crack goes in to the wing.
I can just move the ailerons 5mm up before the can't go anymore and when i hold down the skines they are down to mabye 3mm up.
daniel lö is offline Find More Posts by daniel lö
Old Aug 26, 2011, 04:32 PM
Auckland NZ
Joined Aug 2007
^CA fixes it, one of my flaps was similar. No biggy, 2 seconds to fix.
Its not the wipers it more likely the hinges were a bit stiff so the skin flexes around the balsa while setting them up, once you have them setup, and the hinge is a bit "used" and frees up, its not an issue.
Old Aug 26, 2011, 04:33 PM
Arcteryxxx's Avatar
Joined Feb 2010
Got any medium CA? That's what comes to my mind....
Old Aug 26, 2011, 04:35 PM
Arcteryxxx's Avatar
Joined Feb 2010
Blazing Skies! Inspired by your colors, Jacko....
Old Aug 26, 2011, 04:40 PM
Dbox is online now
Find More Posts by Dbox
One Idiot is plenty...
Dbox's Avatar
United States, OR, Portland
Joined Jun 2005
I'll be more then happy to replace the wing if You want.
If damage starts from the both end tips,it does look to me as a shipping damage./For some reason only Europe is not treating boxes well/
According to You picture,damage dont go further inside.
Thin CA or wing replacement will fix that
Yuri.
Dbox is online now Find More Posts by Dbox
Old Aug 26, 2011, 04:49 PM
Auckland NZ
Joined Aug 2007
Hahaha, new wing, or 10 seconds with some CA
Daniel, that balsa isnt load bearing, dont worry about it too much.
Discussion Blade MCP X - owner's thread rchelijc Micro Helis 13413 Yesterday 10:33 PM
Discussion MCP-X thread for people that dont have a MCP-x axelen Micro Helis 186 Apr 01, 2011 01:17 AM
Data mCP X (non chat) setup and tips owners thread Cable Guy Micro Helis 9 Mar 12, 2011 11:50 AM
Build Log Build Log - ARK X-500 series build thread cfrank2005 Electric Heli Talk 30 Jun 29, 2009 12:27 PM
RBC A-4 Skyhawk build thread X.X Willmsy Electric Ducted Fan Jet Talk 6 Nov 22, 2005 10:01 PM
