Old Aug 25, 2011, 02:40 AM
jackosmeister is online now
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
Ready for take 2 tommorrow. New PC is up and running, edits HD videos like weapon!
Ill see if I can get some better footage
jackosmeister is online now Find More Posts by jackosmeister
Old Aug 25, 2011, 03:09 AM
Flyextreme is offline
Find More Posts by Flyextreme
Sure it'll work
Flyextreme's Avatar
United States, CA, Redondo Beach
Joined Nov 2005
Originally Posted by Dbox View Post
Bill,I have not these them yet ,but found that Neu FAI 5S 2100mha batt is just PERFECT
for X-plane.
You certainly can go ahead with 1800mha for drop in replacement of Your 4S.to avoid plane re balancing .
Yuri
I think I settled it. I will get one of each an see which way I like it.
Bill
Flyextreme is offline Find More Posts by Flyextreme
Old Aug 25, 2011, 06:22 AM
sebbe is offline
Find More Posts by sebbe
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
sebbe is offline Find More Posts by sebbe
Old Aug 25, 2011, 05:31 PM
jjmouris is offline
Find More Posts by jjmouris
Needs to do 52 legs !!
jjmouris's Avatar
Verenigd Koninkrijk, Fareham
Joined Aug 2008
Originally Posted by sebbe View Post
Arcteryxxx ,, I have those spinner to, did order them a while ago, but I didnt thougt they where made for highpower applications, maybee they are ?
The cranked yoke makes the spinners take less power then straight ones, have you read somewhere about these spinners to be ok with this kind of power ?
Your X looks very sharp
I am sorry to say that i would agree with this. I have not tried the Hyperflight spinners but they clearly say these parts are not suited to high power applications and i think they mean it.
We have seen plenty of failures of the RFM offset yokes. Those are also a lot thicker then the strait ones but this is not what makes a yoke strong. As with metal all you need is a weak spot and the rest will just tear away like it was not even there.
This spinner system does not have the threaded bolts like the RFM system. That is a good thing!!! But i am not convinced that this will mean the yoke will stay in one piece
Add to this that this Rasa 15x18 prop seems to have pritty chunky blades with more mass then an RFM 15x16 or 16x17 slim. So you are stressing the yoke even more.
So with the setup Arcteryxxx is suggesting, i would say probably not a good idea. Fine on 5S but when you move to 6S......... BANG!!!! and the whole plane is gone.
jjmouris is offline Find More Posts by jjmouris
Old Aug 25, 2011, 05:41 PM
Arcteryxxx is offline
Find More Posts by Arcteryxxx
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
Hi Joe!
Is this from experience with that exact spinner or an assumption? (this is supposed to take more than the previous version, and they have added "Power" to the name...)
Might be the right time to send some Q by eMail to the vendor....
Which spinner would you suggest, btw?
Arcteryxxx is offline Find More Posts by Arcteryxxx
Old Aug 25, 2011, 05:54 PM
Kwahn is offline
Find More Posts by Kwahn
Germany
Joined Jul 2010
I use an RFM 30mm spinner in my Excite, as I was not aware of any other options. It is an old style straight yoke. If the hyperflight ones are strong enough they seem like a nicer choice.
Kwahn is offline Find More Posts by Kwahn
Old Aug 25, 2011, 06:02 PM
Arcteryxxx's Avatar
Joined Feb 2010
*Mail sent to Hyperflight Customer Service*
Old Aug 25, 2011, 06:03 PM
jjmouris is offline
jjmouris's Avatar
Joined Aug 2008
Originally Posted by Arcteryxxx View Post
Hi Joe!
No experiance with those.
Indeed i would ask Vladimir for more information.
My recommendation? HM Spinner 32mm yoke/spinner. Blades fold less nice but who cares?!
http://www.rcgroups.com/forums/showt...ght=hm+spinner
Old Aug 25, 2011, 11:04 PM
Auckland NZ
Joined Aug 2007
16x17 goes fast
Not massive jump from the 14.5x14, but definetly faster.
Have become used to the way she leaps now, ready for 5S, was starting to get into the groove with it this arvo, Barrrp woosh Baarp woosh
Bit of a tweak to the programming and its much nicer to land now, its seriously a pussycat when it needs to be, flick the switch and it becomes a lion with a rocket up its bum. Loving the X!
10kg bungee launch from shoulder height is walk in the park, flicks off the end at a decent pace, no obvious torque rolling once the go switch is flicked.
Got some more video to look through later, was filmed at 60fps, will see if it makes a difference.
Old Aug 26, 2011, 12:24 AM
Dbox is offline
Find More Posts by Dbox
One Idiot is plenty...
Dbox's Avatar
United States, OR, Portland
Joined Jun 2005
5S5S5S
Yuri.
Dbox is offline Find More Posts by Dbox
Old Aug 26, 2011, 02:48 AM
Auckland NZ
Joined Aug 2007
Dooooo it, get a perm
Instant Kiwi ad by DDB (0 min 30 sec)
New video it uploading... Fast Dot
Old Aug 26, 2011, 03:38 AM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
http://www.hyperflight.co.uk/product...ead-this-first
Frequently Asked Questions
Does the cranked hub put any extra stress on the blades?
Yes, there is some evidence that the cranked nature of these spinners DOES increase the stress on the blades. To be on the safe side we recommend that the max safe RPM of the blades is reduced by 25% below the manufacturer's normal recommendation.
I wouldnt put serious power threw them..
Old Aug 26, 2011, 03:40 AM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
When you release her, does she pull straight, or a bit up with the nose ?
Old Aug 26, 2011, 04:07 AM
Auckland NZ
Joined Aug 2007
Goes like a bolt out of a cross bow, unfortunatly forgot to turn the camera on till halfway through the flight.
If you thinking about bungee launching your X, just do it, get a decent bungee (hosemonster) and simply pull it back. Its totally pain free, not scary or dodgy. The models dont get a chance to get upset or in funky orientations, no matter where the hook is, as they go from 0-100mph in well under a second.
Old Aug 26, 2011, 04:22 AM
Peter M is offline
Find More Posts by Peter M
Peter M's Avatar
Newcastle, New South Wales, Australia
Joined Sep 2007
Hey Jacko,
Can you post a photo of your tow hook on your X Plane please?
Is it just glued to the outside with no other changes?
Peter
Peter M is offline Find More Posts by Peter M
Discussion Blade MCP X - owner's thread rchelijc Micro Helis 13415 Yesterday 02:39 PM
Discussion MCP-X thread for people that dont have a MCP-x axelen Micro Helis 186 Apr 01, 2011 01:17 AM
Data mCP X (non chat) setup and tips owners thread Cable Guy Micro Helis 9 Mar 12, 2011 11:50 AM
Build Log Build Log - ARK X-500 series build thread cfrank2005 Electric Heli Talk 30 Jun 29, 2009 12:27 PM
RBC A-4 Skyhawk build thread X.X Willmsy Electric Ducted Fan Jet Talk 6 Nov 22, 2005 10:01 PM
