Jacko, great building, Ive just order mine from Yuri
![]() By the way, I also did find a 32mm spinner.... 1-7952 , ROBBE ALUMINIUMSPINNER 32 MM Just order one from sweden, Im sure you can find it in many places, I have the same spinner on my Turn Left, its very well made and very good precision.. You can see it here: http://shop.conrad.se/websale7/ROBBE...6a917%2fmd5%7d sebbe.. |
Jacko, how much amps is the 16-35-1, KPG27 5.2, 16x17 RFM, ICE100 on 5S ?
I read in the Viper manual: 16/35/1 mit 5,2:1 KPG Getriebe Kontronik Jazz FAI 18 RFM 16x17S Prop 4S Lipo ab 3200 mAh ab 30 C Strom: 240A = ca. 2,4KW ???? I dont understand their numbers.. I think Yuri said: 200 amps with 16-35-1, KPG27 5.2, 16x17 RFM slimm, on 5S . or have I mixed up something... |
Sebbe,I am starting Your X-Plane next week
![]() You'll have her in beginning of July. Thank You for Your order. I do have same motor set in mine,but running on 5S . ICE logger shoved 200Amps .3860Watts. Will wait to see what's Jacko's set will do. Great job on exist hole BTW,I am all ways afraid to make mine ![]() Yuri. |
OK Yuri, Now I have made my design ready for you:
You can see, I want it bright yellow, and the rest is carbon, the number on right side wing is: 68, the chess pattern on left side should be fade out. * I want the wing to ONLY have small short ailerons, NO flaps, im going for top speed with 5s and small speed propp(5x5)... The text on top righside wing should say: MADE BY YURI VIRCHENKO, but all in Russian, yes i understand a little russin, my Grandma was fron russia Im just unsure if the line going front on fuse should also go threw the wing ? I know you are a master of seeing these, Its up to you to decide.. Just ask if you want to change anything, to the better Im not the best artist... and most important, will this work for you ? Sebbe. |
OK, Yuri, new top view design, The white inside the plane is natural carbon....
Buttom view= no change, same as before in picture above.. I hope this is OK ? (even though I may change my design/colour again before you have to know, this is the latest I want )Sebbe is confused, again ..
| Thread Tools | |
| Discussion Blade MCP X - owner's thread | rchelijc | Micro Helis | 12008 | May 20, 2013 05:00 PM |
| Discussion MCP-X thread for people that dont have a MCP-x | axelen | Micro Helis | 186 | Apr 01, 2011 01:17 AM |
| Data mCP X (non chat) setup and tips owners thread | Cable Guy | Micro Helis | 9 | Mar 12, 2011 11:50 AM |
| Build Log Build Log - ARK X-500 series build thread | cfrank2005 | Electric Heli Talk | 30 | Jun 29, 2009 12:27 PM |
| RBC A-4 Skyhawk build thread X.X | Willmsy | Electric Ducted Fan Jet Talk | 6 | Nov 22, 2005 10:01 PM |
