Old Aug 06, 2011, 12:46 AM
200mph club.
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
Running a hot covering iron around the edges melts the foam backing sticks em together. Its brilliant, easy as!
jackosmeister is offline Find More Posts by jackosmeister
Old Aug 06, 2011, 10:15 AM
la528it's Avatar
City of Angels
Joined Dec 2007
I like to use a trim iron. Bob mentioned that butane pencil torches work awesome too...
la528it is offline Find More Posts by la528it
Old Aug 06, 2011, 12:39 PM
One Idiot is plenty...
Dbox's Avatar
Planet Earth
Joined Jun 2005
Just Like this
Yuri.
Dbox is offline Find More Posts by Dbox
Old Aug 06, 2011, 01:56 PM
Sure it'll work
Flyextreme's Avatar
United States, CA, Torrance
Joined Nov 2005
Is that how you Bar-B-Que chicken in the winter?
Flyextreme is offline Find More Posts by Flyextreme
Old Aug 06, 2011, 03:43 PM
Sure it'll work
Flyextreme's Avatar
Joined Nov 2005
Finally!!!! I got started on my X-Plane!!!
Jacko, I know this is your build thread, but I am posting pix of my progress to hopefully help keep me from loosing momentum. And maybe to see if I can get done before you.
I think/hope now that I have actually started, that I will have it done by this weekend.
So, all I got at this point is...
Gearbox/pinion assembled
Motor mount installed...Thanks again jacko.
And, if it counts...blades on the spinner I'll take what I can get
ESC and control horn fab. next.
Old Aug 06, 2011, 04:19 PM
Dbox's Avatar
Planet Earth
Joined Jun 2005
Looks like new
Clean job.
Yuri.
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
Question: I'm going to run a 5S setup in my (soon to be delivered) X-plane. I've got two setups to choose from, both with a KPG25 5.2:1 gearbox:
Alternative #1: NEU 1115/1Y (2800kv)
Alternative #2: ARC 28-58-1 (3180kv)
ESC: CC P125, modified by Joe.
Props in consideration: RFM 15x16 and RFM 16x17slim
What do you Dudes think?
Yuri: please post a picture - can't wait......
Arcteryxxx is offline Find More Posts by Arcteryxxx
Old Aug 06, 2011, 11:31 PM
200mph club.
Auckland NZ
Joined Aug 2007
All good Flyextreme, didnt intend it too be just my plane, yours does look nice and clean in white!
I ran out of solder to finish mine.. Doh. Need to go "organise" some more, its hard to find the leaded stuff in the shops, the non lead stuff sucks ass.
Weighed my X last night, 1204grams, can probably get it under 1200 with some trimming of ESC/Batt wiring, which needs to be done anyway. Feels like it would DS with the best of em!
And here I was thinking I thought of something new
Old Aug 06, 2011, 11:43 PM
GryphonRCU's Avatar
United States, CA, SF
Joined Mar 2008
Arctery,
As you know this is not my area of specialty, but I know of 2 reports from guys snapping ARC 28-58-1 shafts in EDF at 2500W level.
Fans were balanced.
Good luck
Gryphon
GryphonRCU is offline Find More Posts by GryphonRCU
Old Aug 07, 2011, 03:37 AM
Sure it'll work
Flyextreme's Avatar
Joined Nov 2005
I managed to get a bit more done. Fabricating the control horns was a pain and seemed to take forever to get done. Might have beed a tad easier with the right tools and if I had somewhere besides the dinning room table to work.
So, control horns made and installed.
Esc/motor soldered.
Push rods assembled.
Pretty much servos, RX, balancing, fine tunning, etc is all that's left to do. The worst of it is done...hopefully.
Old Aug 07, 2011, 08:18 AM
Arcteryxxx's Avatar
Joined Feb 2010
Originally Posted by GryphonRCU View Post
Arctery,
Fans were balanced.
Good luck
Gryphon
Thanks! Haven't found much info on the 28-58-1...
I think the kv is about right for my setup on 5S, and with the GB "protecting" the shaft from vibration even better than a balanced fan, the shaft will hopefully sustain 3kW....*prayers*
Old Aug 07, 2011, 09:01 AM
rimripper's Avatar
Alberta,Canada
Joined Nov 2009
Archery,I've also been looking at the X plane,it looks very nice!!!what kind of speeds are you looking for with your set-up?
rimripper is offline Find More Posts by rimripper
Old Aug 07, 2011, 09:14 AM
Arcteryxxx's Avatar
Joined Feb 2010
Hi, Rim!
It's more of a vertical rocket thing than horizontal WOT. Haven't given top speed a thought, resting assured that speed will be sufficient
But: it would be interesting to put in some extra cells and use one of Markus' 8.5*20 props....
Old Aug 07, 2011, 10:34 AM
Dbox's Avatar
Planet Earth
Joined Jun 2005
Esc/motor soldered.
Your dinning table works great.
It is hard to do a better job then You did.
Yuri.
Old Aug 07, 2011, 11:54 AM
rimripper's Avatar
Alberta,Canada
Joined Nov 2009
I'm thinking winter project for my self,it feels like it's blowing in today!!
Discussion Blade MCP X - owner's thread rchelijc Micro Helis 12010 May 23, 2013 07:12 PM
Discussion MCP-X thread for people that dont have a MCP-x axelen Micro Helis 186 Apr 01, 2011 01:17 AM
Data mCP X (non chat) setup and tips owners thread Cable Guy Micro Helis 9 Mar 12, 2011 11:50 AM
Build Log Build Log - ARK X-500 series build thread cfrank2005 Electric Heli Talk 30 Jun 29, 2009 12:27 PM
RBC A-4 Skyhawk build thread X.X Willmsy Electric Ducted Fan Jet Talk 6 Nov 22, 2005 10:01 PM
