Old Oct 10, 2012, 09:50 AM
drice is offline
Find More Posts by drice
drice's Avatar
United States, CA, San Diego
Joined Jul 2004
Originally Posted by VooDoo Child View Post
It was a bit more,like a minute and 15 of WOT...
What's your current draw at WOT?
drice is offline Find More Posts by drice
Old Oct 10, 2012, 09:58 AM
VooDoo Child is offline
Find More Posts by VooDoo Child
Drinks Day Old Expired Milk
VooDoo Child's Avatar
United States, OR, Portland
Joined Aug 2010
I did not have a chance to check the log,as I had to get my butt to Tijuana Flats for Taco Tuesday and Corona's. ....I will Plug it in when I get home tonight.I will tell you this,It came down cooler then in Hotliner mode...Very cool having a plane that surves a duel purpose with a 2 minute prop change.
VooDoo Child is offline Find More Posts by VooDoo Child
Old Oct 10, 2012, 10:13 AM
Joined Aug 2010
Originally Posted by moparmyway View Post
I stand corrected ...............................................
and WOW !!!!!!!!!
I am speechless
Just so you know,that is 4S in that video....on 5S it can only take 30second runs with a glide,then back for another couple runs..if you go 31seconds,bad things happen
Old Oct 11, 2012, 07:07 PM
Joined Aug 2010
Sawtooth log
Old Oct 11, 2012, 10:37 PM
drice is offline
drice's Avatar
Joined Jul 2004
I'm no expert but the temperature plot concerns me. It confirms what many have been hinting at, which is that you are definitely HOT-lining. Your ESC is past the boiling point of water, and well above most ratings, which stop at +85C. You're running over +100C near the end.
I dig watching the videos, but you're pulling a LOT of power with not enough break time to let things cool down.
Just my opinion.
Old Oct 11, 2012, 11:17 PM
SB7 is offline
SB7
Find More Posts by SB7
SB7
I am actually really slow
Brisbane
Joined Jun 2008
Eveything looks really good except for the temp. I have a hard time believing its getting that hot. Maybe the logs are giving false readings
SB7 is offline Find More Posts by SB7
Old Oct 12, 2012, 01:01 AM
Charger is offline
Find More Posts by Charger
I B Chargin'
Charger's Avatar
Arizona
Joined Aug 2003
I dig watching the videos.
drice............you left me hanging with your last video. The rolling circle scene was a tease! I would love to see high speed, low altitude rolling circles. Any chance for some more vid from you?
Sorry for bailing out on this fun stuff..........but I have a house that was absolutely falling apart, and I needed a year to do a lot of work on it. A few more months and I'll be back to raising heck!! Been following this thread all along though.............The Best!!!!!!!!!!!!
Charger is offline Find More Posts by Charger
Old Oct 12, 2012, 02:52 AM
sebbe is offline
Find More Posts by sebbe
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
Icelog is not something I trust, we know that it can show wrong value on Amps and wattage, dont know about temp ?
sebbe is offline Find More Posts by sebbe
Old Oct 12, 2012, 03:30 AM
moparmyway is offline
Find More Posts by moparmyway
Why the dirt on the wings?
moparmyway's Avatar
New York
Joined Jan 2009
sebbe,
I have my Eagle Tree hooked up before my ICE, both recording at the same time.
Everything is basically identical !
I have 26 ICE esc's, and every one of them are putting out repeatable and reliable numbers. They were all compared to several Eagle Tree recorders and my arsenal of Fluke test equipment, nuthin but the best .................... I have no quams about taking a firm stance on saying to anyone ......... trust your ICE.
I know ICE was questioned early on, but as of late, they are accurate and reliable. Things do change !
moparmyway is offline Find More Posts by moparmyway
Old Oct 12, 2012, 04:16 AM
SB7 is offline
SB7
SB7
Brisbane
Joined Jun 2008
So... his 100A esc is boiling itself when it's only pulling 100A... for only a minute? Pretty sure doug is running decent cooling aswell. Sounds odd to me.
Old Oct 12, 2012, 05:49 AM
Mreyello is offline
Find More Posts by Mreyello
Mreyello's Avatar
Deutschland, RP, Niederzissen
Joined Dec 2011
For me also the rpm is quite low,the sawtooth i know usually go to 10500-11000 at about 1 kw.
Doug,
As you like to test a lot of different stuff i would recommend to use a different logging system, the Unilog for example offers some nice options like airspeed, altitude ,climbrate, additional temp sensors ....
You can also use the limiter to keep your runtime in the limits,as you know, sometimes just a couple of seconds can be too much!
Data-analysis with logview is pretty nice, you can compare different setups by showing the graphs of different logs in one picture.
Regards
Yello
Mreyello is offline Find More Posts by Mreyello
Old Oct 12, 2012, 05:55 AM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
mopar, you are surely tru with your statement, but my ICE 100 is exactly 22% off on current, my friends is 10% off, compared to a 1500 dollar equipment... I dont know about other ICE ecs:s and if they have improved i calibration, maybee they have, just saying how mine and my friend are off,,, BUT just the amps,,, I havent checked the temps...
Old Oct 12, 2012, 06:37 AM
Chuchuf is offline
Find More Posts by Chuchuf
Carboweave, Ask For It By Name
Chuchuf's Avatar
United States, GA, Atlanta
Joined Aug 2009
I have checked the Ice logs on many units HV and non HV pretty extensively against a clamp on and they are genereally 7-10% higher on Amp's.
Terry
Chuchuf is offline Find More Posts by Chuchuf
Old Oct 12, 2012, 07:01 AM
moparmyway's Avatar
New York
Joined Jan 2009
Temps and rpm have never been questioned due to relatively dead on info as compared to auxilary test equip.
Amps have been questioned as well as voltage in the past.
With the new firmware upgrades, maybe the older ICE can be better ?
All I know is that when ICE first came out, I was getting 15-20% higher amps and started running Eagle Tree and ICE together, saw the difference !!
Now, on exact same ICE controller, amps and voltage are so close, there is no difference ............................ only different thing : Firmware !
I dont know, it seems to me that when used to see difference between ICE and Eagle Tree in the beginning, then I post up Eagle Tree 150 vs ICE, (no matter what ICE) there is 35 RPM difference, no difference in volts and 2 or 3 amps difference @ 125 amps ........................................ to me, thats the same thing !!!!
I have to credit Castle in their Firmware upgrades (Gryphon tried telling me it was the Firmware, but I said " doesnt make sense" ,,,,,,,,,,,,,,,,,,,,,, but it still has changed) .................. too many Molson XXX after work today, and its only 08:00 !!!!
Old Oct 12, 2012, 07:02 AM
Joined Aug 2010
There is no doubt the temp readings are OFF,going buy the finger check,it comes down cooler then when I do the Hotliner thing....all temps feel good after a 60sec run.
Discussion Blade MCP X - owner's thread rchelijc Micro Helis 13396 Today 01:06 PM
Discussion MCP-X thread for people that dont have a MCP-x axelen Micro Helis 186 Apr 01, 2011 01:17 AM
Data mCP X (non chat) setup and tips owners thread Cable Guy Micro Helis 9 Mar 12, 2011 11:50 AM
Build Log Build Log - ARK X-500 series build thread cfrank2005 Electric Heli Talk 30 Jun 29, 2009 12:27 PM
RBC A-4 Skyhawk build thread X.X Willmsy Electric Ducted Fan Jet Talk 6 Nov 22, 2005 10:01 PM
