Old Sep 24, 2012, 11:36 PM
VooDoo Child is offline
Find More Posts by VooDoo Child
Drinks Day Old Expired Milk
VooDoo Child's Avatar
United States, OR, Portland
Joined Aug 2010
Originally Posted by decones View Post
what's your setup?
I'm impressed that your motor didn't fried with all that motor ON
BTW - nice flying
I do not go any more then 1 to 3 seconds .
VooDoo Child is offline Find More Posts by VooDoo Child
Old Sep 24, 2012, 11:41 PM
Joined Aug 2010
Originally Posted by Arcteryxxx View Post
Wow! The bug at 5:22 scared me
Incredible flying, Doug!
Can you tell me your total motor-on time and how much capacity you draw from the battery?
I just fly off the timer,i know if i land around the timer-i will have around 12 to 17% left in the pack.The flight from that vid,all parts came down at nice temps,i am not worried one bit....wish i could give you more info,but i am not a Fun Jet Data Guy
Old Sep 24, 2012, 11:45 PM
Joined Aug 2010
Originally Posted by Dbox View Post
Have to admit ,that Your hotlining beats mine,hands down.
You one sick pilot VC.
Great video .
Thank You.
I want to eXplane what 5S would do with Your flying,-You would not be able to hold throttle switch for that long.And if You would,You would not be able to control the plane Teaser
Yuri.
So what are you really trying to say ? i think i can adapt to 5 cells with only major issues
Old Sep 25, 2012, 12:17 AM
decones is offline
Find More Posts by decones
making my own planes...
decones's Avatar
Curitiba - Brazil
Joined Oct 2007
You went way far from recommended 3.6v/cell keeping only 12-17%,
It feels to me that your pack will puff soon...
That's only my opinion based on what I saw,
I would never cross 30%.
decones is offline Find More Posts by decones
Old Sep 25, 2012, 12:55 AM
Dbox is offline
Find More Posts by Dbox
One Idiot is plenty...
Dbox's Avatar
Joined Jun 2005
What happen when You adding one cell is-
You actually hold throttle switch less for the same power You got use to.
You using motor less.
AMPS go up slightly higher but controller takes it ,cause again,You using it less .
Batteries are cooler for same reason.
With Your 14.5x14 prop it is simple shame not to go for 5S.
BUT ,what kills the whole enchilada is-
that You getting high ,like on drags and start to hold throttle longer and longer
forgetting that now it is 5S that You flying.
Yuri.
P.S. I think I mentioned this before ,my radio programmed timer,sowing me
throttle holding time 0.3 sec in some motor runs. 16x17 slim 5S 2100mha.
Dbox is offline Find More Posts by Dbox
Old Sep 25, 2012, 05:15 AM
Arcteryxxx is offline
Find More Posts by Arcteryxxx
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
Well.... I do believe that decisions based upon quality data will beat the "happy-go-lucky" approach 99 out of 100 times. But the data only has value if you know how to interpret them.
Just sayin.....
Arcteryxxx is offline Find More Posts by Arcteryxxx
Old Sep 25, 2012, 06:51 AM
Rolf D. is offline
Find More Posts by Rolf D.
What is Highspeed ?
Rolf D.'s Avatar
Germany, BY, Bergen
Joined Feb 2011
Nice Video
cool flying BUT:
the time throttle closed are very short by whole flying, so the ESC and Motor are every few seconds in peak.
Do you measure temperature ?? sometimes ???
if I was you I would measure directly after flying - otherwise day will come you have a smoker at your bird maybe
Rolf D. is offline Find More Posts by Rolf D.
Old Sep 25, 2012, 08:10 AM
Joined Aug 2010
Sounds like I should convert my X to wind up rubber band power
Old Sep 25, 2012, 10:55 AM
Chuchuf is offline
Find More Posts by Chuchuf
Carboweave, Ask For It By Name
United States, GA, Atlanta
Joined Aug 2009
53 back works for me,the tail gets a bit slippery for my taste if i go any more,but i have alot of surface movement,would not be good for playing Wanna-B-Pylon Racer But i am working on a mode for Pylon Style as i have put the GM 11X22 Folder on my X a couple times,and will try a pair of Sawtooths for 's and Giggles....The 16-35-1 5.2 on 4S with F5D Folder is kind of fun....It makes it a Pylon-Liner.
I'm currently running 48 but think I'll try a bit further back. The plane flys great except it doesn't track through turns the way I would like it to.
I need to spend a session trimming this plane.
Thanks for the CG Doug.......
Terry
Chuchuf is offline Find More Posts by Chuchuf
Old Sep 25, 2012, 11:06 AM
Joined Aug 2010
Terry
For sure,go try around 54 back,it will hook the turns a lot nicer.....but will also speed up your landing first couple turns I would not hit it as hard as you normally would,the rearward cg makes the elevator respond a lot more.
Old Sep 25, 2012, 11:20 AM
Chuchuf is offline
Joined Aug 2009
Damn.....small steps grass hopper....lol
Man I hate to loose how slow I can land the X without Flaps right now. It's unreal and slower than my Enigmy with flaps!!
Yes I'm pretty familiar with the effects on a plane of moving the CG aft.
Used to race F1 and QM in my younger days.
Could absolutely get into F5D or F5B now, if there were any races near.
Terry
Old Sep 29, 2012, 12:09 AM
wollins is offline
Find More Posts by wollins
"RC ADDICT" in Toronto!
wollins's Avatar
Toronto Canada
Joined Aug 2004
Doug, are the sawtooths available commercially now or is it because you're "special"?
Colin
wollins is offline Find More Posts by wollins
Old Sep 29, 2012, 01:03 AM
Peter M is offline
Find More Posts by Peter M
Peter M's Avatar
Newcastle, New South Wales, Australia
Joined Sep 2007
I think the answers are "Yes" and most definitely "Yes"
The sawtooths can be bought here: http://www.bigbruceracing.com/
Peter M is offline Find More Posts by Peter M
Old Sep 29, 2012, 02:34 AM
Kwahn is offline
Find More Posts by Kwahn
Germany
Joined Jul 2010
I also fly the mega 16/35/1 w/ 5,2:1 GB in my Excite with the other nose. 14,5x14 on 4s is indeed a rather safe setup, especially with small batteries. In my experience with logging temperatures the 15x16 on 4s should be limited to about 40 seconds to achieve 80 degrees C at the motor and with 5s + 15x16 it takes just 22 seconds of total motor on time to get there, 3,3 kW peak power.
Kwahn is offline Find More Posts by Kwahn
Old Sep 29, 2012, 08:21 AM
Chuchuf is offline
Joined Aug 2009
Moved the CG back about 3mm and I like the way the plane flys a LOT better. Much better tracking. When I roll inverted power off it doesn't take any down to fly inverted. Small change but a huge difference!!
But slowing it down for landing is another story. It just floats forever. Gonna have to work on getting my flaps functioning again.
Terry
Discussion Blade MCP X - owner's thread rchelijc Micro Helis 13298 Dec 08, 2015 12:08 PM
Discussion MCP-X thread for people that dont have a MCP-x axelen Micro Helis 186 Apr 01, 2011 02:17 AM
Data mCP X (non chat) setup and tips owners thread Cable Guy Micro Helis 9 Mar 12, 2011 12:50 PM
Build Log Build Log - ARK X-500 series build thread cfrank2005 Electric Heli Talk 30 Jun 29, 2009 01:27 PM
RBC A-4 Skyhawk build thread X.X Willmsy Electric Ducted Fan Jet Talk 6 Nov 22, 2005 11:01 PM
