![]() Lehners rocks. Yuri. |
From memory, it is most accurate around 60 amps according to Bernie. You will find a margin of error above that but what % I don't know? It's to be used more as a comparative tool when you start to change parameters like props and batteries. I would figure out the error factor on your clamp meter and go from there. Voltage and RPM are highly accurate so watts are a little subjective.
Latest blog entry: My creative replacement Quad body for...
My beater Hotliner setup for 3 weeks has been a Scorpion SII-3026-1190, RFM 15x16 , ice 100 heat sink with the heatsink removed, and kapton taped together. It has survived 34 flights, 69 climbs on 3s @ 244 amps peak. It has PLENTY of cooling air. Max temp with heatsink removed is 149 degrees, 20+ degrees cooler then with the heatsink attached. I will add that the motor gets fairly hot at this power level but nothing over 160 degrees.
Today's final flight was the same setup but with RFM 17x18. amp increase was 7% for first climb then LVC... lipo took a crap
![]() The NZ-US post link seems like a good one, ive sent a 2m model to california in less than 4 days post office to doorstep. Hmmmmm.... http://www.reisenauer.de/artikeldetails.php5?aid=1211
| Thread Tools | |
| Discussion Blade MCP X - owner's thread | rchelijc | Micro Helis | 12005 | Yesterday 10:13 PM |
| Discussion MCP-X thread for people that dont have a MCP-x | axelen | Micro Helis | 186 | Apr 01, 2011 01:17 AM |
| Data mCP X (non chat) setup and tips owners thread | Cable Guy | Micro Helis | 9 | Mar 12, 2011 11:50 AM |
| Build Log Build Log - ARK X-500 series build thread | cfrank2005 | Electric Heli Talk | 30 | Jun 29, 2009 12:27 PM |
| RBC A-4 Skyhawk build thread X.X | Willmsy | Electric Ducted Fan Jet Talk | 6 | Nov 22, 2005 10:01 PM |
