Old Jul 10, 2012, 11:05 AM
stanordave is offline
Find More Posts by stanordave
stanordave's Avatar
Joined Jan 2006
the Neu 1115/1Y on 5s with a 5x5 (not necessarily the best choice prop) gives me 1800W and 104A static. I run this with the ice lite 100 in my Viper w/no problems.
a 4.75x4.75 on 4s is around 85A static
stanordave is offline Find More Posts by stanordave
Old Jul 11, 2012, 08:55 AM
VooDoo Child is offline
Find More Posts by VooDoo Child
Drinks Day Old Expired Milk
VooDoo Child's Avatar
United States, OR, Portland
Joined Aug 2010
Is Loctite 648 the compound used for the pinion gear on the motor? I fired up the X-Plane last night,and it pulled like a Mac Truck tell half throttle,then just made a nasty screening sound,and no longer pulled......sad face.
VooDoo Child is offline Find More Posts by VooDoo Child
Old Jul 11, 2012, 01:05 PM
GregG is online now
Find More Posts by GregG
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
I used to use Loctite green "Sleeve Retainer", but that was years ago. Don't know exactly what they're using now.
GregG is online now Find More Posts by GregG
Old Jul 11, 2012, 01:50 PM
Dbox is online now
Find More Posts by Dbox
One Idiot is plenty...
Dbox's Avatar
Joined Jun 2005
http://www.rcgroups.com/forums/showp...postcount=1999
Dbox is online now Find More Posts by Dbox
Old Jul 11, 2012, 07:24 PM
Joined Aug 2010
Thanks Guys,but please disregard my posts about the pinion gear I am not sure what happened,but i figured i would fire it up again for a second after Sykotic and Sebbe thought it could also be the ESC,and take a 2 second vid (but last night on the first runup,to me,the way the motor sounded like it reved up and screeched,but stopped pulling,i for sure thought it was the gear).....Well,i went to half throttle like i did last night and all was fine,then went to full figuring it would do the same as last night.....I was wrong,all was good and it almost spun the whole fuselage out of my hand ....glad i have a fast grip (i know i left the door wide open on that,but be mature )....So in closing,i have no idea what the heck happened last night and what was wrong,and ALL you guys are Flipping Crazy for playing with these set-ups.....I just can not wrap my head around what those 3kw setups feel like in your hands Just Awesome,i can not wait to fly this,but i do feel a bit bad for my launcher
Old Jul 12, 2012, 05:16 AM
GryphonRCU is offline
Find More Posts by GryphonRCU
GryphonRCU's Avatar
United States, CA, SF
Joined Mar 2008
Guys,
I've been curious to see if any 16/45 can give a KV range similar to the 16/35/1
From a bit of dirty calculation, it seemed worthwhile to look into the following:
16/45/1.5RD 3.2mm
16/45/1.5RDE 3.2mm
I should soon have actual resistance, and KV values for them (from MEGA) to compare to 16/35/1 3.2mm including weight differences.
45/35= 1.28 , hopefully 28% bigger guts can be of some use.....and hoping for decent % lower resistance as well.
1/2 inch longer motor may be harder to fit.
Any thoughts?
Gryphon
GryphonRCU is offline Find More Posts by GryphonRCU
Old Jul 12, 2012, 08:28 AM
sebbe is offline
Find More Posts by sebbe
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
Gryphon,
16/45/1,5R ,,, 2102kv 60 A
would this 16/45/1.5RD be a D winding of the motor above ?
How would the max amps be then, I see at megas site the 1 winding are 80A and the 1.5 windings are 60A, would this 16/45/1.5RD also be 60 A
Sebbe
sebbe is offline Find More Posts by sebbe
Old Jul 12, 2012, 08:33 AM
Chuchuf is online now
Find More Posts by Chuchuf
Carboweave, Ask For It By Name
Chuchuf's Avatar
United States, GA, Atlanta
Joined Aug 2009
If you need loctite 638 or 648 you can get it here
http://www.mcmaster.com/#loctite-648/=idggpz
Terry
Chuchuf is online now Find More Posts by Chuchuf
Old Jul 12, 2012, 10:13 AM
Dbox is online now
Dbox's Avatar
Joined Jun 2005
Any thoughts?
Gryphon
There is at least good 1 inch spare room behind KPG27+MEGA 16/35/1 +CC125
in the fuse before battery in my X-Plane.
You better get these motors in stock,so we can try them.
Thank You Gryphon.
Yuri.
Old Jul 12, 2012, 05:32 PM
Joined Aug 2010
Video that goes with this post since i do not need it to figure out the problem,figured some of you might get a laugh at the NOOB DORK that fired up his first power combo like this,and has no clue what it feels like,and did not expect it to make power past half throttle....but had a tight grip and safety goggles just in case PS,I AM HOOKED,and sorry for the word,but this pulled harder then a white trash girl pulls her kid through Walmart (but nothing like what you guys are used to) http://www.youtube.com/watch?v=3Srw_...1&feature=plcp
Old Jul 12, 2012, 07:20 PM
Dbox is online now
Dbox's Avatar
Joined Jun 2005
Sorry do disappoint You Doug,but that how it suppose to sound
X-plane motor test (0 min 26 sec)
Yuri.
Old Jul 12, 2012, 07:31 PM
Joined Aug 2010
IM WORKING ON IT ! I will get there one day I got a kick out of watching you re-grip that fuselage a couple times,and use the forearm.....that is just crazy power.
Old Jul 12, 2012, 08:56 PM
Peter M is offline
Find More Posts by Peter M
Peter M's Avatar
Newcastle, New South Wales, Australia
Joined Sep 2007
Doug,
Suggest you don't expect your Kira to handle as much abuse as a 16/35/1 for example as they have a smaller stator and rotor due to the space taken by the fan.
Just saying, that's all....
Peter M is offline Find More Posts by Peter M
Old Jul 12, 2012, 09:59 PM
la528it is offline
Find More Posts by la528it
la528it's Avatar
United States, UT, Salt Lake City
Joined Dec 2007
Yuri.
Yuri, how many layers of tape did you use to secure the camera to the chair and not have it fly off?
la528it is offline Find More Posts by la528it
Old Jul 12, 2012, 11:11 PM
Peter M is offline
Peter M's Avatar
Joined Sep 2007
Finally another X Plane ready for maiden!
Just need it to stop raining for half an hour so I can sneak up to the field......
Discussion Blade MCP X - owner's thread rchelijc Micro Helis 13419 Jul 31, 2016 03:58 PM
Discussion MCP-X thread for people that dont have a MCP-x axelen Micro Helis 186 Apr 01, 2011 01:17 AM
Data mCP X (non chat) setup and tips owners thread Cable Guy Micro Helis 9 Mar 12, 2011 11:50 AM
Build Log Build Log - ARK X-500 series build thread cfrank2005 Electric Heli Talk 30 Jun 29, 2009 12:27 PM
RBC A-4 Skyhawk build thread X.X Willmsy Electric Ducted Fan Jet Talk 6 Nov 22, 2005 10:01 PM
