Old Jul 02, 2011, 11:16 AM
Arcteryxxx is offline
Find More Posts by Arcteryxxx
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
Hmmmmm...
Anyway: all my MEGAs run great on low setting. (16/25/2EC, 16/40/1.5SEC and 22/35/1.5ER)
Arcteryxxx is offline Find More Posts by Arcteryxxx
Old Jul 02, 2011, 11:49 AM
sebbe is offline
Find More Posts by sebbe
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
Originally Posted by Arcteryxxx View Post
Hmmmmm...
yes the timing have options: low, standard and high, OK , but I was talking about PWM frequency, there are no "low" option,,there is : outrunnermode, 12, 16 and 24Khz
I will try 12Khz first.. maybee thats what you meant by "Low" ?
sebbe is offline Find More Posts by sebbe
Old Jul 02, 2011, 12:01 PM
matjon is offline
Find More Posts by matjon
matjon's Avatar
Sverige
Joined Oct 2007
Sebbe: my ICE 75 has 8Khz, ICE 100 should have it too.
matjon is offline Find More Posts by matjon
Old Jul 02, 2011, 03:07 PM
Flyextreme is offline
Find More Posts by Flyextreme
Sure it'll work
Flyextreme's Avatar
United States, CA, Redondo Beach
Joined Nov 2005
Jacko, any pix on how you did your BODA???
Bill
Flyextreme is offline Find More Posts by Flyextreme
Old Jul 02, 2011, 03:58 PM
jackosmeister is offline
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
Havent done it yet
Am waiting for the mega to arrive so I can see hows its all gonna balance first. X-plane is gonna be fast enough without excess "speed" holes
Just gonna drill a hole big enough for the base with the little plastic bush on the boda to stick through, I dont think orientation of it matters that much with it ( I range tested the hell out of the all carbon typhoon, in the worst possible conditions ( Tx pointed at ground, BODA totally sheilded by the plane) at a soccer feilds length away I couldnt get it drop out )
May make up a stratair style sharkfin, just cos it looks cool
jackosmeister is offline Find More Posts by jackosmeister
Old Jul 02, 2011, 04:40 PM
Arcteryxxx's Avatar
Joined Feb 2010
Jacko: Which type rx?
Old Jul 02, 2011, 04:43 PM
Auckland NZ
Joined Aug 2007
Optima 7, but the 6 is just as capable performance wise.
Old Jul 02, 2011, 05:03 PM
la528it is offline
Find More Posts by la528it
la528it's Avatar
United States, UT, Salt Lake City
Joined Dec 2007
Timing -OK
PWM -8
Brake -Hard
Start - use ramp if you want to. I don't
Do use a brake ramp, and while I was using ramp for some time now, today I found a good reason not to. Ater any hard landing, you should make sure everything is still in tip top shape. I do this by testing all control surfaces prior to following launch, and blipping the motor. Today, everything passes. I launched the plane and 25 feet up, it did a perfect hammerhead and was pointed straight at the ground. I recovered (honestly this was my best piloting to date, and hopefully forever after), but I did not have speed and had to go down the runway before turning around to land. It tip stalled something nasty at the other end of the runway due to low speed and tailwind. Still managed a perfect landing though. I thought maybe the radio cut out or an aileron servo died on me, but no, it was the motor mount that broke free. Lucky for me, no twisted wires/esc fire, but the moral here is that blipping the motor on the ground was not a strenuous enough test with ramp. In fact, I'm almost certain that the firewall broke free once it approached full power. So if I ramp, from here on out, I will let the motor fully unload during flight check, or I'll simply take ramp off. For what it's worth, this was a leaner 5300kv on 5.2 running 3s... The pack is the most amazing lipo I have ever dealt with: gen's ace 55c.... Guaranteed to mess up all your old setups with it's ridiculous lack of voltage sag.
Thanks for reading!
la528it is offline Find More Posts by la528it
Old Jul 02, 2011, 05:32 PM
Auckland NZ
Joined Aug 2007
Haha, I know the feeling la528it. Screw those guys who can do 200mph passes inverted off 2" off the strip. Its landing a plane that has returned to kit form in the air that makes ya worthy!
This is the boda install on the hyperDX, carbon fuse, simple as. Typhoon setup was identical, with the boda facing upwards/right though. Using a fillet of UHU por (similar to goop but thinner) to secure the boda in the hole. UHU por is also the shizzle for attaching servo covers BTW, its nice and clean, sticks really well, but can be removed without busting the wing.
Old Jul 02, 2011, 05:59 PM
la528it is offline
la528it's Avatar
Joined Dec 2007
No, for servo covers there is only one option: 3M Scotch ATG Adhesive 924 Transfer Tape
It is thinned goop in a micron thin double-sided tape. Leaves no residue, and keeps covers tacked on firmly in excess of 200mph
BTWE: last I checked stratair was selling those fins at half price... may be easier to buy a few from them rather than making you own
Old Jul 02, 2011, 06:15 PM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
ok, will check it out when it arrives, thanks, In the manual Ive downloaded from CC it doesnt say 8Khz ? strange..
Old Jul 02, 2011, 06:47 PM
Arcteryxxx's Avatar
Joined Feb 2010
La528: Which lipo was that?
Old Jul 02, 2011, 09:51 PM
la528it is offline
la528it's Avatar
Joined Dec 2007
Gens ace 3s 55c insanely cheap, and it never gets hot. These things are amazing, it's worth it even if it lasts only 10 flights, but as cold as it lands, I suspect there are many more to come
Old Jul 02, 2011, 10:12 PM
Auckland NZ
Joined Aug 2007
I think I just ordered some of fins from stratair... not entirely sure...
Old Jul 02, 2011, 10:39 PM
Arcteryxxx's Avatar
Joined Feb 2010
I use 25C and 30C 5S2200 with my NEU1115. Totally awe!!!!
Discussion Blade MCP X - owner's thread rchelijc Micro Helis 13419 Jul 31, 2016 03:58 PM
Discussion MCP-X thread for people that dont have a MCP-x axelen Micro Helis 186 Apr 01, 2011 01:17 AM
Data mCP X (non chat) setup and tips owners thread Cable Guy Micro Helis 9 Mar 12, 2011 11:50 AM
Build Log Build Log - ARK X-500 series build thread cfrank2005 Electric Heli Talk 30 Jun 29, 2009 12:27 PM
RBC A-4 Skyhawk build thread X.X Willmsy Electric Ducted Fan Jet Talk 6 Nov 22, 2005 10:01 PM
