Old Jun 26, 2012, 02:07 AM
BulletMaster is online now
Find More Posts by BulletMaster
Chillaxin dude!
BulletMaster's Avatar
Newcastle, NSW, Australia
Joined Apr 2003
wouldn't suggest 4S NiMh anyway.. especially not with 2,4 gear.. 5S minimum NiMh I believe, if you absolutely MUST use NiMh..
BulletMaster is online now Find More Posts by BulletMaster
Old Jun 26, 2012, 09:30 AM
Lenny970 is offline
Find More Posts by Lenny970
Lenny970's Avatar
Greeley, Colorado, USA
Joined Feb 2000
Originally Posted by jackosmeister View Post
No ones gonna answer that for you man. Its risky.
The only way to find out is too test the snot out of it, and use the A9 telemetry to tell you whats up. Nimh suck, and how well they perform is depends on bunch of stuff, including age.
It will probably work just fine.
A few years ago, when weight was more critical in F5B models, we used to use small packs like that.
They perform fine as long you treat them right. In fact, I still use a 4-cell nimh pack, though a bit larger in size.
Give the pack a slow forming charge, then several charge/discharge cycles to measure the mah capacity. It can take 5 or more cycles to come up to capacity.
Then, charge before the flight and verify voltage with a loaded voltmeter.
If the pack it not used regularly, you will need to repeat the forming/charge/discharge routine to "wake it up" again.
Good luck,
Lenny
Lenny970 is offline Find More Posts by Lenny970
Old Jun 26, 2012, 10:41 AM
johnnyrocco123 is offline
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
Good luck,
Lenny
What Amp rate would be a good slow forming charge Lenny?
It's a 250mah pack, I was thinking 1C, but I guess that is not slow.
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Jun 26, 2012, 02:58 PM
Lenny970 is offline
Lenny970's Avatar
Joined Feb 2000
No, that's not a slow charge rate.
Forming charge should theoretically be done at about 1/10C, or 25ma for 10-14 hours for this pack.
Lenny
Old Jun 26, 2012, 03:12 PM
drice is offline
Find More Posts by drice
drice's Avatar
United States, CA, San Diego
Joined Jul 2004
1/10C would be 25mA, or .025A.
Just saying...
drice is offline Find More Posts by drice
Old Jun 26, 2012, 04:40 PM
You down with EPP?
Houston, Tx
Joined May 2009
Just saying...
Yeah, I don't have a charger that will snail charge.
Old Jun 26, 2012, 08:18 PM
Lenny970 is offline
Lenny970's Avatar
Joined Feb 2000
Just saying...
Don,
I just wanted to see if anyone was paying attention.
Correction made.
Lenny
Old Jun 26, 2012, 09:07 PM
GregG is offline
Find More Posts by GregG
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
How thick can the wing servos be?
GregG is offline Find More Posts by GregG
Old Jun 26, 2012, 11:24 PM
jackosmeister is online now
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
9mm
jackosmeister is online now Find More Posts by jackosmeister
Old Jun 27, 2012, 12:09 AM
Dbox is offline
Find More Posts by Dbox
One Idiot is plenty...
Dbox's Avatar
United States, OR, Portland
Joined Jun 2005
Greg,the best ones are Hyperion D09 AMD and Airtronic 802.
Easy fit,precise ,slop free, digital,affordable
Non digital -Dymond D-60
Will finish Your plane at the end of the week.
Yuri.
Dbox is offline Find More Posts by Dbox
Old Jun 27, 2012, 09:24 AM
GregG is offline
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
Yuri.
Old Jun 27, 2012, 02:01 PM
VooDoo Child is offline
Find More Posts by VooDoo Child
Drinks Day Old Expired Milk
VooDoo Child's Avatar
Joined Aug 2010
Does the X wing not have a rear spar ? I am working on the wing,and looking at pics from Jacko and Lenny,and i amazed at how far back they have the servo wiring exiting.
VooDoo Child is offline Find More Posts by VooDoo Child
Old Jun 27, 2012, 04:01 PM
Dbox is offline
Dbox's Avatar
Joined Jun 2005
There is a rear spar.
It splits right at the middle of the wing.
Yuri.
Old Jun 27, 2012, 04:36 PM
Joined Aug 2010
Yuri.
Darn,that means i have to pay attention when doing this hole
Old Jun 27, 2012, 04:57 PM
sykotic is offline
Find More Posts by sykotic
200mph +
sykotic's Avatar
New Zealand, Manawatu-Wanganui, Palmerston North
Joined Sep 2010
Not really, the drag/rear spar does not go through the middle of the wing section.
If you put the hole in the middle of the wing center you should be fine.
sykotic is offline Find More Posts by sykotic
Discussion Blade MCP X - owner's thread rchelijc Micro Helis 13419 Jul 31, 2016 03:58 PM
Discussion MCP-X thread for people that dont have a MCP-x axelen Micro Helis 186 Apr 01, 2011 01:17 AM
Data mCP X (non chat) setup and tips owners thread Cable Guy Micro Helis 9 Mar 12, 2011 11:50 AM
Build Log Build Log - ARK X-500 series build thread cfrank2005 Electric Heli Talk 30 Jun 29, 2009 12:27 PM
RBC A-4 Skyhawk build thread X.X Willmsy Electric Ducted Fan Jet Talk 6 Nov 22, 2005 10:01 PM
