Old Jun 16, 2012, 10:45 PM
drice is offline
Find More Posts by drice
drice's Avatar
United States, CA, San Diego
Joined Jul 2004
Originally Posted by Kaw1000 View Post
No go so far, on the strapping tape...I took CA and put strapping tape on top of that, let it dry
and pulled very hard. It did not move at all. I then tried again and made tape longer...wrapped the long tail around screwdriver( like a T-Handle) and pulled as hard as I could with fuse between my legs....it did not budge.
Both tries the tap eventually came off of battery. The plastic wrap ripped off the first try.
this could only happen to me....errrr
Huh...well that sucks. Do you have a needle applicator that you could put some light oil in, like 3:1? I'm wondering if you drip a bit of oil down the sides of the battery and place it nose down for awhile, then try again with duct tape.
The concern I have is I don't know how lithium batteries respond to oil, but if everything else fails, you may have to try potentially less-safe options, although the oil may NOT be less safe, I just don't have a clue.
If you try it, be sure you don't put oil where the tape will go (duh), and don't hang it in a way that will allow the oil to wick to where the tape will go (double duh).
Perhaps others can chime in on whether this is completely stupid idea or not.
drice is offline Find More Posts by drice
Old Jun 16, 2012, 10:57 PM
Flyextreme is offline
Find More Posts by Flyextreme
Sure it'll work
Flyextreme's Avatar
United States, CA, Redondo Beach
Joined Nov 2005
I'm wondering if you could use a heatgun around the area you suspect it's wedged the tightest to sorta get that very hard fuse to loosen it's grip on the lipo. The inside of these fuses are kinda rough in places, so it can grip pretty good. If the edges of the lipo get warm, it should soften up some too.
Re-apply the tape, and heat all the way around....wiggle/pull.....heat...wiggle/pull........ It could take some time.......
Flyextreme is offline Find More Posts by Flyextreme
Old Jun 16, 2012, 11:07 PM
VooDoo Child is offline
Find More Posts by VooDoo Child
Drinks Day Old Expired Milk
VooDoo Child's Avatar
United States, OR, Portland
Joined Aug 2010
Originally Posted by Flyextreme View Post
I think I just may have something for you. Check your PMs.
Sounds like you might have a Killer Jacko mount......That would be Way Cool.
VooDoo Child is offline Find More Posts by VooDoo Child
Old Jun 17, 2012, 12:24 AM
GregG is offline
Find More Posts by GregG
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
Can you squeeze any part of the nose where the battery is? If there is any loose space, squeezing it should loosen the rest of it .....
GregG is offline Find More Posts by GregG
Old Jun 17, 2012, 01:05 AM
Sure it'll work
Flyextreme's Avatar
Joined Nov 2005
These fuses are virtually unsqueezable....very hard....not your everyday fuse lay-up
Old Jun 17, 2012, 02:24 AM
sykotic is offline
Find More Posts by sykotic
200mph +
sykotic's Avatar
New Zealand, Manawatu-Wanganui, Palmerston North
Joined Sep 2010
Can you remove the spinner, and motor bolts and give the shaft a push at the same time as a pull on the tape?
Will put your esc in danger depending on where you have it... Last ditch effort
sykotic is offline Find More Posts by sykotic
Old Jun 17, 2012, 04:25 AM
Kwahn is offline
Find More Posts by Kwahn
Germany
Joined Jul 2010
Is the ESC still connected?
Kwahn is offline Find More Posts by Kwahn
Old Jun 17, 2012, 11:03 AM
Kaw1000 is offline
Find More Posts by Kaw1000
They call me Crash!
Kaw1000's Avatar
Ohio
Joined Jun 2006
ESC is still connected....I don't think pushing the motor shaft will help at all as this thing is
really really suck in there.
I'm thinking of cutting the vent hole on top a little longer and trying to pry/push battery while pulling. There is no wiggling at all, it simply is not moving at all.
I can see where it actually contoured the fuse into the shape of the lipo.
Last resort is to cut the fuse on one side to give relief and then pull, epoxy fuse back together.
Kaw1000 is offline Find More Posts by Kaw1000
Old Jun 17, 2012, 11:49 AM
Sure it'll work
Flyextreme's Avatar
Joined Nov 2005
If the lipo was "warm/soft" when happened, getting it, and the fuse, pliable again with heat, just might work. Go slow, and give the heat time to migrate to the interior. At this point it's worth a shot before doing surgery.
Old Jun 17, 2012, 11:52 AM
Sure it'll work
Flyextreme's Avatar
Joined Nov 2005
Yes I do, and it's your's. No sense in letting it go to waste.
jacko, thanks again
Bill
Old Jun 17, 2012, 01:00 PM
Kaw1000 is offline
They call me Crash!
Kaw1000's Avatar
Ohio
Joined Jun 2006
I will try the heat thing...thanks for suggestion!
Old Jun 18, 2012, 05:56 PM
Joined Aug 2010
SUSA will have my RFM 14.5X14,2-Hyperion MG servos for the flaps (yes,i lost sleep,so changed my mind),and a few other Goodies here soon-that will be everything...Oh,and mount....Time to get to work on my first Warmish-Hot Liner ....I must say,i am pretty damn excited right now. Doug
Old Jun 18, 2012, 06:18 PM
Joined Aug 2010
NOW i do not know why,but when i look at that Kira sitting next to the X-Plane,this is all that comes to mind
Justin Timberlake - Sexy Back (4 min 36 sec)
Old Jun 18, 2012, 06:23 PM
johnnyrocco123 is offline
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
What cell and C rating are those Sky Lipos sitting next to it?
Are those the extremely rare 4S 40C?????
If so, I am jealous. You have no idea how long I have been trying to get those.
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Jun 18, 2012, 11:35 PM
BulletMaster is offline
Find More Posts by BulletMaster
Chillaxin dude!
BulletMaster's Avatar
Newcastle, NSW, Australia
Joined Apr 2003
looking good voodo!
BulletMaster is offline Find More Posts by BulletMaster
Discussion Blade MCP X - owner's thread rchelijc Micro Helis 13365 Jun 22, 2016 11:42 AM
Discussion MCP-X thread for people that dont have a MCP-x axelen Micro Helis 186 Apr 01, 2011 01:17 AM
Data mCP X (non chat) setup and tips owners thread Cable Guy Micro Helis 9 Mar 12, 2011 11:50 AM
Build Log Build Log - ARK X-500 series build thread cfrank2005 Electric Heli Talk 30 Jun 29, 2009 12:27 PM
RBC A-4 Skyhawk build thread X.X Willmsy Electric Ducted Fan Jet Talk 6 Nov 22, 2005 10:01 PM
