Old Apr 20, 2012, 03:00 AM
la528it is offline
Find More Posts by la528it
la528it's Avatar
United States, UT, Salt Lake City
Joined Dec 2007
Originally Posted by sykotic View Post
I know nothing about the current spektrum stuff, I sold most of mine, but sbritton is correct, I don't see why you couldn't use the 6 channel 6255 and still have full control over all surfaces/mixing.
No rudder remember
Not exactly... the crappy spektrum radios do not allow you to program functions to arbitrary servos... the nicer ones do. It's why people cat fly full house electric gliders on dx7 even with 7ch rx...
As for ar6xxx or ar9xxx, the ar9xxx has TWO receivers built into the rx. I do not think this is true of the ar6xxx. You onlu need two ind receivers, no need for 3 (i.e. do not need satellite with ar9xxx). I left spektrum a while back, so I'm not sure about how many receivers are built into ar6xxxx rx.
la528it is offline Find More Posts by la528it
Old Apr 20, 2012, 03:03 AM
sykotic is offline
Find More Posts by sykotic
200mph +
sykotic's Avatar
New Zealand, Manawatu-Wanganui, Palmerston North
Joined Sep 2010
That would teach me for talking about what I don't know Sorry for the bad info.
sykotic is offline Find More Posts by sykotic
Old Apr 20, 2012, 03:07 AM
Flyextreme is offline
Find More Posts by Flyextreme
Sure it'll work
Flyextreme's Avatar
United States, CA, Redondo Beach
Joined Nov 2005
Well, with a "normal" radio, it woulda worked So you were sorta right
Flyextreme is offline Find More Posts by Flyextreme
Old Apr 20, 2012, 03:10 AM
jackosmeister is online now
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
Weird how you guys find 0 degrees incidence not right. Mine was setup to within 0.05 degrees, and flew with not a click of trim?
jackosmeister is online now Find More Posts by jackosmeister
Old Apr 20, 2012, 03:20 AM
Sure it'll work
Flyextreme's Avatar
Joined Nov 2005
0.05 just might be enough. All I know right now is it requires alot more up trim than I would like. Once I get there, I will put it on the meter and see where it's at.
Old Apr 20, 2012, 05:32 AM
GryphonRCU is offline
Find More Posts by GryphonRCU
GryphonRCU's Avatar
United States, CA, SF
Joined Mar 2008
Originally Posted by sebbe View Post
OK, thanks.... I have not decided yet, (as usual ),,, but maybee I want it more like 1500-1600kv,,, to fit my 7x13 folder propp on 5s lipo... I have to play a bit more with neucalc and see what kv I want..
It isnt possible to change the shaft also, like from 3.17mm to 6mm ?
MEGA 16/30 and longer all come standard with 5mm shaft and bearings.
When ordering 3.17mm, or 4mm shaft the output shaft gets ground down without any extra charge. (2 week delay for 4mm).
If 5mm standard shaft will not do for your application/gear box....”Maybe” Dan would consider grinding a larger shaft down to 5mm for the guts of the motor and leaving you 6-8mm diameter for the output shaft.
If it was me, I would expect higher cost and some delay.
If changing the shaft/rotor, then you can decide if you would want regular or E rotor.
Regular or 100K bearings or Boca ABEC 7 Ceramic Hybrid bearings.
Better consider bolt pattern and anything else carefully.
***Lets take this off the thread so it does not clutter up these pages.
Gryphon
GryphonRCU is offline Find More Posts by GryphonRCU
Old Apr 20, 2012, 05:33 AM
sebbe is offline
Find More Posts by sebbe
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
If a plane needs 1.5mm uptrim, then the incidence must be off... Of course its better to adjust that angle if its not right..
sebbe is offline Find More Posts by sebbe
Old Apr 20, 2012, 05:51 AM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
OK, thanks Gryphon, I will first have to decide what KV and shaft I do need to have, then I will PM you, and we can see what to do...
Old Apr 20, 2012, 12:00 PM
Charger is offline
Find More Posts by Charger
I B Chargin'
Charger's Avatar
Arizona
Joined Aug 2003
Originally Posted by Dbox View Post
Guys,dont make a big deal out of elevator linkage ,there is nothing complicated.
I am using MPJet clevises and they are really up to task.Small enough to fit inside tail.
And convenient to use carbon pushrod as well as a metal one.
Hyperion D-09 fast servo on the tail works well for my plane.
Yuri
Are these the micros or standard
http://icare-rc.com/hardware.htm
Charger is offline Find More Posts by Charger
Old Apr 20, 2012, 12:16 PM
Dbox is offline
Find More Posts by Dbox
One Idiot is plenty...
Dbox's Avatar
United States, OR, Portland
Joined Jun 2005
I am using 1mm clevises.
I sent You 2 pairs.Dont have brass horns though.
Yuri
Dbox is offline Find More Posts by Dbox
Old Apr 20, 2012, 12:27 PM
Charger is offline
I B Chargin'
Charger's Avatar
Arizona
Joined Aug 2003
Yuri
Thanks Yuri!!!
Old Apr 20, 2012, 01:18 PM
King Kong is offline
Find More Posts by King Kong
King Kong's Avatar
los alamitos ca
Joined Jun 2001
Why is everything so hard to find??? Does anyone know where I can find a kpg27? I see that icare has the 25 which is convenient because that's where i'm going to get my motor and clevises, but I see that if I want the ability to run a twisted rfm spinner soaring usa only offers it with the 6mm shaft which means I need the 27 over the 25.
BTW Yuri, the plane is absolutely amazing! pics to come.
King Kong is offline Find More Posts by King Kong
Old Apr 20, 2012, 01:54 PM
Sure it'll work
Flyextreme's Avatar
Joined Nov 2005
I will try and find the site where I got mine when I get home....they should be back in stock by now....maybe.
Old Apr 20, 2012, 01:56 PM
Dbox is offline
Dbox's Avatar
Joined Jun 2005
They have 4 in stock.http://www.espritmodel.com/kontronik...g25-kpg27.aspx
For 16/35/1 and 4S will be a decent gear.
Thanx for the compliment Frank.
Yuri.
Old Apr 20, 2012, 02:23 PM
Dbox is offline
Dbox's Avatar
Joined Jun 2005
BTW 4S 2600mha fits really well.
Yuri.
Discussion Blade MCP X - owner's thread rchelijc Micro Helis 13400 Today 12:15 AM
Discussion MCP-X thread for people that dont have a MCP-x axelen Micro Helis 186 Apr 01, 2011 01:17 AM
Data mCP X (non chat) setup and tips owners thread Cable Guy Micro Helis 9 Mar 12, 2011 11:50 AM
Build Log Build Log - ARK X-500 series build thread cfrank2005 Electric Heli Talk 30 Jun 29, 2009 12:27 PM
RBC A-4 Skyhawk build thread X.X Willmsy Electric Ducted Fan Jet Talk 6 Nov 22, 2005 10:01 PM
