Old Jun 28, 2011, 11:20 PM
200mph club.
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
Originally Posted by Arcteryxxx View Post
Any chance I can buy the MK1 mount from you? I'm gonna use a KPG25...
Pm me your address and Ill send one your way. Its a Mk2 KPG25, I didnt like Mk1 (thinner with smaller cooling holes)
Its oversize by about a mm, so you'll need to tweak it too fit your fuse. I Recommend roughening up the edges to get the glue to bite better. I file slots around the circumference, seems to work well.
Yuri, you crack me up
jackosmeister is online now Find More Posts by jackosmeister
Old Jun 29, 2011, 12:20 AM
200mph club.
Auckland NZ
Joined Aug 2007
Horns dimensions im using for those that asked. Not flight tested, or gauranteed to fit your wing
Will likely require some tweaking to the aft lower edges to clear epoxy around the spar.
zip is the sketchup file so it can be Gcoded and CNC'd for the lazy..
Old Jun 29, 2011, 12:29 AM
Highfly!'s Avatar
United States, CA, Cameron Park
Joined May 2007
Who is selling those MK2 mounts?
Highfly! is offline Find More Posts by Highfly!
Old Jun 29, 2011, 12:36 AM
200mph club.
Auckland NZ
Joined Aug 2007
Not for sale, freebies, dont really wanna go into mass production either!
But I can make another if you want, just cant gaurantee when, as I make them in downtime at work instead of twiddling thumbs (at least its keeps the boss thinking im busy )
Old Jun 29, 2011, 12:49 AM
Highfly!'s Avatar
Joined May 2007
Ready when you are if you have the time. I am about to mount the KPG25 to my Hacker B40 and may need a new mount.
Thanks for the Sketchup files! I belong with the lazy CNC guys...
Old Jun 29, 2011, 12:57 AM
Highfly!'s Avatar
Joined May 2007
BTW Jacko, this is how I did setup my A9 BODA antenna on the X-Plane. Over 30 flights rock solid signal. The antenna wire sits in a teflon tube provided by Richard (la528it) which makes the antenna wire a bit stiffer.
Old Jun 29, 2011, 01:17 AM
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
Totally awesome! Thanks a bunch! PM sent...
Arcteryxxx is offline Find More Posts by Arcteryxxx
Old Jun 29, 2011, 01:34 AM
200mph club.
Auckland NZ
Joined Aug 2007
Sweet as, PM me your address as well and Ill see if I get time tomorrow.
Is that an Rx pack I can see through the cooling hole?
I have a hyperion life 850 2S here, was gonna use that but its a bit big, might be able to jam it in though
Old Jun 29, 2011, 01:43 AM
Highfly!'s Avatar
Joined May 2007
I like to make my own RX packs using AAA Eneloops NiMh. I know its 1G technology but it works and I have a lot of flexibility with how I layout the cells. I have the RX pack and Optima 7 taped together.
Thanks for the goodies and PM sent.
Old Jun 29, 2011, 04:00 AM
sebbe's Avatar
Sweden
Joined Feb 2006
Yuri, only titanium
I was thinking Kryponit ...
Im sure you will make the motormount strong to handle all the power I will ever put in my 68 racer
Sebbe
sebbe is offline Find More Posts by sebbe
Old Jun 29, 2011, 07:54 AM
sebbe's Avatar
Sweden
Joined Feb 2006
Now Im strating to eat again......
I can feel my X-plane getting close
Yuri, dont work to much and make mistake
This will be my plane number 1, and it will hang in livingroom, I will take away my VIPER and put the X-plane there instead, The VIPER will get the second best place
Old Jun 29, 2011, 08:59 AM
Arcteryxxx's Avatar
Joined Feb 2010
Wouldn't it be better to fly it than hanging if from the ceiling?
Old Jun 29, 2011, 01:02 PM
sebbe's Avatar
Sweden
Joined Feb 2006
Nope, better look at it more often, and fly sometimes, its a special plane, I can fly the Viper, if I crasch it, then I can order the same one, with the X-plane, its so custum made, even if I ask yuri to make one more, it will not be the same, like a custom car , the first is the original ..
Old Jun 29, 2011, 01:38 PM
Sure it'll work
Flyextreme's Avatar
United States, CA, Torrance
Joined Nov 2005
My thoughts about my X-plane are simular. However, a thoroughbred like the X-plane will not do very well being corraled for very long. Not being able to stretch her legs and run in wide open spaces may likely cause her severe depression, and she may run away when turned loose. Besides, you can get spare parts from Yuri
After you get'er dialed in and fly her a few times...then see if you can keep from flying more than keeping it static
We used to tease our buddies that had really nice planes that they never, or rarely flew...you don't want to be "that guy"
Bill
Flyextreme is offline Find More Posts by Flyextreme
Old Jun 29, 2011, 01:50 PM
sebbe's Avatar
Sweden
Joined Feb 2006
Bill, I am that guy
The planes I fly mostly is the ones I dont care so much about, the easier flyers with the cheapest setups..
my funjet ultra @ 1750 watts just hangs on the wall, my original 1000watt funjet I fly all the time..
I guess we are all different.
But of course, I WILL fly it, more then once
Discussion Blade MCP X - owner's thread rchelijc Micro Helis 12008 Yesterday 05:00 PM
Discussion MCP-X thread for people that dont have a MCP-x axelen Micro Helis 186 Apr 01, 2011 01:17 AM
Data mCP X (non chat) setup and tips owners thread Cable Guy Micro Helis 9 Mar 12, 2011 11:50 AM
Build Log Build Log - ARK X-500 series build thread cfrank2005 Electric Heli Talk 30 Jun 29, 2009 12:27 PM
RBC A-4 Skyhawk build thread X.X Willmsy Electric Ducted Fan Jet Talk 6 Nov 22, 2005 10:01 PM
