Old Jun 09, 2011, 02:21 AM
timmybeetle is offline
Find More Posts by timmybeetle
No Guts, No Glory
timmybeetle's Avatar
Nederland, LI, Helden
Joined Sep 2010
HobbyKing P51D 1.2M KIT VERSION
Hi Flying guys
I ordered me this KIT from Hobbyking Germany and want to share my findings with you all.
First off all the KIT is very well packed and was very quick delivered at home.
The manual which is included is really a shame to put in such a box.
Most of all it talked about the RTF version but it says P-51 KIT quick Flight Manual.
For someone how never build such a plane together it will be very difficult to perform but for more experience guys it will be no problem.
Also I read at Hobbyking forum not too use included glue, instead use 5 min. epoxy.
And make the parts which will be glued together clean with sanding paper.
See also pictures
Will be updated.
Greets Timmybeetle
timmybeetle is offline Find More Posts by timmybeetle
Old Jun 09, 2011, 03:27 AM
No Guts, No Glory
Joined Sep 2010
First update servo control problems
09-06-2011
SERVO CONTROL ISSUES
Well I tested servo control and smoke came out if it.....
Removed servo control form fuselage and I noticed that power lines are wrongly connected in factory...what the F&^%^$&$*
So Servo control is useless, I mailed Hobbyking about this issue and will see how they handle this I keep you informed.
Today 11-06-2011 i received mail from HK to fill in RMA form and send it back for warranty claim.
update 24-06-2011 HK informed me they received my defective Unit and gonna test it so......!?
update 30-07-2011 HK informed me that part is at supplier and waiting for replacement................
Last edited by timmybeetle; Jul 30, 2011 at 01:31 AM. Reason: update servo unit problem
Old Jun 15, 2011, 02:32 AM
No Guts, No Glory
Joined Sep 2010
Great review of this KIT
thanks to 1111mavrick
http://www.hobbyking.com/hobbyking/s...1ee5c08a3b60fa
also you can find here
P-51d mustang 1.2m from HobbyKing build and review Part 1 (14 min 46 sec)
P-51d mustang 1.2m from HobbyKing build and review Part 2 (6 min 51 sec)
greets Hans
Old Jun 17, 2011, 03:22 PM
No Guts, No Glory
Joined Sep 2010
HobbyKing Mustang 1.2m building
Hoi flying guys
Building Mustang P51D.
Placed metal servo's for Rudder and Elevator.
Also for me plastic plate broke so I removed it and used wood instead.
I 'm sanding all parts that should be glued together.
And also I noticed that rear steering wheel will not fit easily in rudder so I replaced tube by a bigger one so its fits really nice.
Main wing I noticed that in one wing hole is missing for stabilization rod.....
So I have to make it perfectly aligning with rod.....
After that I will glue wing together with 5 min Epoxy.
enough for today.
greets Hans
Old Jun 18, 2011, 01:43 AM
1111Mavrick is online now
Find More Posts by 1111Mavrick
1111Mavrick's Avatar
Canada, BC, Gibsons
Joined Apr 2011
Good job Timmy!!!!...... too bad about only one hole in your wing half....nice quality control hey!.... Oh well its cheap and HK even sells spare parts for this plane.
I have about 10 flights on mine so far.... what a joy to fly... very smooth and stable...
I did manage to brake the plastic piece on one landing gear,so for now i pulled both landing gear off and just hand launch it and belly land.... I also removed all the sliding canopy components which totaled 50grams in weight...
Good luck with the rest of your build!
1111Mavrick is online now Find More Posts by 1111Mavrick
Old Jun 18, 2011, 03:31 AM
No Guts, No Glory
Joined Sep 2010
Hi Flying guys
When making hole for rod in main wing I used a bore to make it and when I gently drilled it with hand because of foam I found that tube was installed in wing?????
Anyway after doing this I glued wing together wit 5 min Epoxy and it looks great.
After that I started for my aileron servo's and with my xmtr setup which I also use for my other planes I noticed that servo's are going wrong way haha.
So I reversed both servo's internal and now they work as they supposed to do.
The main connector for wing is easy to use, both aileron and landing gear cables are conncted with this.
Installed in wing and tested them and its OK
glued plastic plate for main wing bolt and now I have to wait for my motor and servo control unit.
Probably I will fly Mustang with gear up and hand launch it like Mavrick1111 is doing because grass field where I'm flying will not work for this plane....!
greets Hans
Old Jun 18, 2011, 10:50 AM
No Guts, No Glory
Joined Sep 2010
Hi flying guys
I couldn't wait for my new motor so I used my 3536-910KV for testing.
For people looking for right motor for this plane it should be this size..
I ordered me also one with 1000KV because of prop adapter I hope it will fit on that one?????
Wanted too know power settings.....
Well first of all I used a
11E8,5 prop.
2200/3s zippy LIPO
40A Turnigy Plush ECS
So my static trust was 1220 Gram, weight of plane is around 1320 Gram.
For me personaly I like static trust at least the same reading as weight of plane.
With watt meter I got around 240 Watt.
As you can see on pictures below.
greetings Hans
Old Jun 18, 2011, 03:13 PM
Canada, BC, Gibsons
Joined Apr 2011
I decided to lighten the load on her and removed the sliding canopy components.
It shaved off 50grams.
http://www.rcgroups.com/forums/attac...mentid=4088465
Old Jun 18, 2011, 04:35 PM
No Guts, No Glory
Joined Sep 2010
Hi flying guys
Aslo here
http://www.rcgroups.com/forums/showthread.php?t=1355856
you can find information about this plane good luck..
http://www.uniquemodelrc.com/proshow.asp?id=432
greets Hans
Old Jun 19, 2011, 07:29 AM
No Guts, No Glory
Joined Sep 2010
HobbyKing Mustang 1.2m building battery compartment modification
Hi flying guys
I decided this morning to modify my battery compartment to be able to put in 4s2650LIPO also
I found that power with 3s2200LIPO isn't enough ore just good for cruising.
So I started to cut foam away and after I fitted in LIPO I tested CG.
CG wasn't at 90mm and I find P51 nose heavy.
So I had to remove foam towards canopy to get CG right.
Reglued foam front of battery compartment and battery hatch.
After that I checked CG and it right on the 90mm point which I think will be the exact CG point.
Also I measured static trust with my 4S2650LIPO, prop 11E8,5
1630 gram of trust flying weight 1430 gram
with watt meter I got 455 watts ( 30A, 15,16V )
Motor is rated for max 470 watt so within spec.
Battery hatch I strengthen with 5 min epoxy.
So when weather and time is there I will perform my first test flight.
Keep you up to date.
greets Hans
Old Jun 19, 2011, 07:44 AM
No Guts, No Glory
Joined Sep 2010
HobbyKing Mustang 1.2m building almost done
Hi flying guys
Well my P51d Mustang almost is ready to fly.
I have to wait for my servo control unit which burned out when testing it and hopefully HK will replaced this by a new one?!?!?!?
Just some pics form P51 before first flight haha.
Maybe someone else also noticed that markers on top of wings are at bode sides and normaly it should be on at top and one at bottom...............
anyway we will see how this bird will fly finally.
greets Hans
Old Jun 20, 2011, 02:55 PM
No Guts, No Glory
Joined Sep 2010
20-06-2011 first flight with P51D 1200mm
Hi Flying guys
Today 20-06-2011 was a perfect day for test flying.
First I flew with 2200/3S Lipo 11E8.5 prop and 3536/910KV motor.
Well as I suspected she flies with this setup but only very slow and at full throttle.
CG is around 90mm and she is very stable and easy to fly.
Second I flew with my 2650/4S Lipo and this is a real joy for flying this plane.
Cruising at 60% full throttle and enough power for flying this bird .
Only at full power my spinner left the plane, probably with one landing it got a bit broken because spinner is of plastic and holes for screws are very thin....
So spinner needs an update haha
CG is also around 90mm and I found Mustang flying really well and with landing very smooth and stable.
HobbyKing P51D 1.2M Mustang (5 min 9 sec)
My landing gear is not working because of servo control unit burned out, is at HobbyKing for warranty claim.
Also motor I ordered at RCTimer arrived today but prop adapter doesn't fit and needs an modification also.
greets Hans
Old Jun 23, 2011, 09:56 AM
No Guts, No Glory
Joined Sep 2010
HobbyKing Mustang 1.2m static trust
Hi all
If you are wondering how I know static trust of my planes......
This is how I do it
Very simple and easy to do and a helpfull information about flight peformance!
Enjoy flying this bird, I do
greets Hans
Static trust setup P51-D HobbyKing Mustang 1200mm (1 min 2 sec)
Old Jul 02, 2011, 06:36 PM
ViperZ is offline
Find More Posts by ViperZ
This is my Nemesis....
ViperZ's Avatar
Canada, SK, Saskatoon
Joined Jan 2011
Great to find this thread Timmybeetle! Thanks!
ViperZ is offline Find More Posts by ViperZ
Old Jul 25, 2011, 06:25 PM
earaoz is offline
Find More Posts by earaoz
Winnipeg, Canada
Joined Apr 2007
Hi Timmy,
I have the same problem as you with the servo control board. I did make it work right and when I wanted to fly the plane, after 3 weeks, it burned out. What a piece of crap!
Tell me, have you been able to get from HK the replacement part as warranty?
Do you know any other way to make the landing gear work?
There is a motor near each wheel and I tried to make them work applying some voltage (from 5 to 12V CC) but the did not move. Maybe they are using more voltage.
If we can not get any satisfactory answer from HK then we will have to finbd our way to make them work. Canopy: I will leave it fixed, not movable.
Please let me know.
Ernesto
Originally Posted by timmybeetle View Post
09-06-2011
earaoz is offline Find More Posts by earaoz
Discussion HobbyKing 1.2m Wingspan P-51D Mustang Ultra_Spitfire Electric Warbirds 4 Jun 09, 2011 06:48 AM
Sold Speedo 1.2m Slope Glider Kit **NEW** SOS-TopGunsBro Aircraft - Sailplanes (FS/W) 0 May 20, 2011 04:44 PM
Sold Speedo 1.2m Slope Glider Kit **NEW** SOS-TopGunsBro Aircraft - Sailplanes (FS/W) 1 May 08, 2011 10:25 AM
Sold Speedo 1.2m Slope Glider Kit **NEW** SOS-TopGunsBro Aircraft - Sailplanes (FS/W) 6 Apr 16, 2011 02:24 PM
Sold Vintage Top Flight P51D 1/7th Sport Scale Kit Gold Edition RMac Aircraft - Electric - Airplanes (FS/W) 1 Apr 16, 2011 01:30 PM
