Old Jun 09, 2011, 12:50 AM
Glenstr's Avatar
Canada, AB, Lac La Biche
Joined Aug 2010
Just put in digital servos, should I be concerned about squealing?
I just replaced my HXT900 servos with D933MG Digital Metal Gear Servos from HK. The HXT's were working fine, but jittering a tad when my FPV transmitter was powered on, and these servos are supposed to be a lot better for this, indeed there was no jitter at all when I powered them up with the Vtx powered up as well.
However, the first time I powered them up, there was a loud squealing, which I thought at first was from the Corona rx, but listening closer I could tell it was from the servos. It abated some after a minute or so, not seems to only come on when I put the servos full over and hold it there. They chirp a bit but not too bad.
A quick google shows that this is probably something I should not be concerned about, as digital servos can squeal from time to time, I just wanted to make sure, that's all.
Glenstr is online now Find More Posts by Glenstr
Old Jun 09, 2011, 12:56 AM
akschu's Avatar
USA, AK, Houston
Joined Aug 2005
Analog servos buzz (50hz refresh rate) digital servos squeal (100hz+ refresh rate). That is why digitals are better, they are repositioning themselves faster which is why the buzz turns into a squeal.
schu
akschu is offline Find More Posts by akschu
Help! confused, what size should EDF should i put in this plane Fishingfon Electric Ducted Fan Jet Talk 8 May 01, 2011 08:23 PM
Question Help please - question about which servos to put where on a PA Katana Mini? glydr 3D Flying 5 Mar 05, 2011 06:37 PM
Discussion Triton 1 should i be concerned? JustinMoore12 Batteries and Chargers 6 Dec 08, 2007 05:40 PM
Joke Why the U.S. should be very concerned about long-term climate change... Flyingwingbat1 Humor 0 Jan 10, 2007 08:20 PM
Got my Rocket 3600 motor. Almost no cogging, should I be concerned? BING! Power Systems 10 Jun 19, 2005 10:34 AM
