Old Jun 08, 2011, 01:58 PM
cgbillb is offline
Find More Posts by cgbillb
cgbillb's Avatar
USA, GA, Athens
Joined Jan 2011
How to install brushless motors
I received my brushless motors today and am not 100% sure how to install them (Optima 400 2220-1200KV Brushless Motor) There are going in a 40" S-Boat.
Thanks for any help you can give me
Bill
Athens Ga.
cgbillb is offline Find More Posts by cgbillb
Old Jun 08, 2011, 03:27 PM
GILL RC is offline
Find More Posts by GILL RC
GILL
GILL RC's Avatar
United States, NJ, Hopatcong
Joined Aug 2005
I think that we will need a bit more info.
I have no idea what an S boat is. So the hull configuation, the beam, what type of drive. Is the motor an out runner or can type.
GILL RC is offline Find More Posts by GILL RC
Old Jun 08, 2011, 04:04 PM
cgbillb is offline
cgbillb's Avatar
USA, GA, Athens
Joined Jan 2011
They are out riggers
guess what I am asking is how to mount the motors to the hull
Make a L bracket and bolt the motor to it then glue it to the hull
See the start of my build log S 38
Bill
Old Jun 08, 2011, 04:53 PM
mfr02 is offline
Find More Posts by mfr02
Blackpool, Lancs
Joined Feb 2006
Bill
Athens Ga.
Good job you asked, my first thought on seeing "s boat" was what others would have thought -
http://en.wikipedia.org/wiki/Schnellboot
and that would have wanted three.
mfr02 is offline Find More Posts by mfr02
Old Jun 08, 2011, 04:56 PM
lslewis is offline
Find More Posts by lslewis
Stilwell Shipyard
lslewis's Avatar
United States, FL, Cape Coral
Joined Nov 2003
Installing motors in a boat is a bit more complex than you might think. Thru hull integrity, that is keep the water out, must be considered. Boats hulls more and a direct shift may not be cool. All I am saying is that we would need to know a lot more about your application to provide real help. I will say making an L bracket and bolting the bracket to the hull is a start but you will want to make to precise location of the motor shaft and coupling adjustable.
Hurricane Larry
lslewis is offline Find More Posts by lslewis
Old Jun 08, 2011, 07:02 PM
cgbillb is offline
cgbillb's Avatar
USA, GA, Athens
Joined Jan 2011
Larry
Yes you are right I have build several boats but with the big motors
Brush type, Thats how I did it with them, The brushless mortors seem
small to me.
Thanks for the help
Bill
Old Jun 08, 2011, 07:06 PM
cgbillb is offline
cgbillb's Avatar
USA, GA, Athens
Joined Jan 2011
MFr02
Yes there will be 3 motors,rudders ect.
See the start of my build log of the S 38 in Scale boats
Bill
PS making rudders now
Old Jun 08, 2011, 11:23 PM
CG Bob is offline
Find More Posts by CG Bob
KC8WPF
CG Bob's Avatar
Euclid, Ohio, United States
Joined Sep 2004
Cut a plywood frame to hold the motors, with appropriate holes for the mounting screws and shafts. You can glue the frame into the hull, and reinforce the joint with some fiberglass.
CG Bob is offline Find More Posts by CG Bob
Old Jun 09, 2011, 03:00 AM
pkboo is offline
Find More Posts by pkboo
Is life for real?
pkboo's Avatar
Almere The Netherlands
Joined Sep 2006
Outriggers?
Hi Bill, Do I gather correctly that you're using brushless outrunner motors? If that is correct I just converted one of my PT's to brushless using outrunners. The L brackett came to mind and should be a plausible solution however I made a firewall to attach all three motors to. Unlike your brushed or inrunner motor the outrunner is attached from behind instead of being bolted from the front ....alignment is a huge keyword here I hope it works for you Boo
pkboo is offline Find More Posts by pkboo
Old Jun 09, 2011, 06:11 AM
cgbillb is offline
cgbillb's Avatar
USA, GA, Athens
Joined Jan 2011
CGBOB and PKBOO
Thank you very much that is what i needed.
I am going to try both ways today,may have some sthing on my build log in the next day or so
Again thanks
Bill
Old Jun 10, 2011, 02:28 AM
nick_75au is offline
Find More Posts by nick_75au
NeverAgainVolunteerYourse lf
nick_75au's Avatar
Australia, QLD, Regents Park
Joined Mar 2007
I've taken to mounting mine directly on the shaft, so the out-runner bell is driving the prop shaft, I remove the original motor shaft and use an extended drive shaft.
http://www.rcgroups.com/forums/showp...7&postcount=36
The motor has to be balanced as any vibration transfers to the hull. the top bearing of the shaft is removed and the motor bearings become the top bearing.
Of course they can be mounted the same as a traditional brushed motor.
Nick
nick_75au is offline Find More Posts by nick_75au
Old Jun 10, 2011, 04:54 AM
cgbillb is offline
cgbillb's Avatar
USA, GA, Athens
Joined Jan 2011
Nick
thanks for the pictures on your build do you have any history on her?
This is what I came up with,just a test when I get the tubes installed will refine it
Again thanks
Bill
Old Jun 10, 2011, 07:25 AM
pkboo is offline
Is life for real?
pkboo's Avatar
Joined Sep 2006
Nice!
"Cool" setup indeed on you're single post Nick...a lot less of the lesser things to deal with. Boo
Old Jun 10, 2011, 04:42 PM
lslewis is offline
Stilwell Shipyard
lslewis's Avatar
Joined Nov 2003
Keep us informed as how it works out. Brushless motors are here to stay and scale boats will eventually switch. I have only one boat and I used a 2S Lipo battery I had. It works fine but I had to add ballast to make up for the weight of the lead acid batteries normally used. What motors are you using?
Old Jun 10, 2011, 05:16 PM
cgbillb is offline
cgbillb's Avatar
USA, GA, Athens
Joined Jan 2011
Islewis
GO to scale boats and you will see my build log S 38
Working on my radio F-14 now
I think the brushless motors are the way to go
Bill
Discussion How to install a 3-pos switch on DX6? HelgeBe Radios 5 Oct 12, 2011 04:55 PM
Discussion How to install twin motors rhamz Power Systems 5 Dec 02, 2009 05:19 PM
How do I install new pinon gear on EPS350 and 400 motors. Brownwood Power Systems 4 Sep 08, 2005 08:11 AM
How To Install Different Motors in the Kyosho and Mini Fan Joe Elston Electric Plane Talk 4 May 31, 2001 10:40 AM
How to install different motors in fans Joe Elston Electric Ducted Fan Jet Talk 0 May 30, 2001 12:10 AM
