Old Oct 18, 2001, 08:25 PM
Travis is offline
Find More Posts by Travis
Master of disaster
Travis's Avatar
Northern Virginia
Joined May 2000
How to find the C/G of a delta wing?
Does anyone know a formula to find the C/G of a "typical"
delta wing aircraft?
Travis is offline Find More Posts by Travis
Old Oct 18, 2001, 10:26 PM
DaveW is offline
Find More Posts by DaveW
Folsom,Ca,USA
Joined Apr 2001
I've made some "test gliders" for " future projects" ( that haven't happened yet ) and found that finding the point on the wing where 25% of the area is ahead of the cg and 75% behind is close. Thats what the 1/4 size all sheet balsa glider was for, to refine this starting point.
Turned out not to be a big issue, just like any other plane.
Easy to play with cg on those. Just a little bit of "up" elevator is needed with the nose weight to balance it out in flight for free flight.
BTW, the gliders flew very well and were really stable.
Seeing the glider fly gives confidence on the first flight of the real thing.
Hope this helps,
Dave
DaveW is offline Find More Posts by DaveW
Old Oct 19, 2001, 12:42 AM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
The c.g. on a flying wing can vary depending on which type of airfoil is used... a reflex or symmetrical. The reflexed type likes a forward position.. abt 12-15%.. the symm type can fly at 25%.
Most c.g. programs presume you know where you want it in terms of the m.a.c., and find the m.a.c., and if you can input a number, give you the location at the root.
Sparky Paul is offline Find More Posts by Sparky Paul
What method to find C of G? FEARLESS FLY Electric Plane Talk 5 Oct 30, 2003 09:15 PM
Easy way to find C.G. thor4944 Foamies (Kits) 31 Jun 07, 2002 04:26 PM
How to get CG for a delta wing? (Mirage) GregG Power Systems 12 Dec 23, 2001 12:29 AM
How to estimate CG on a Delta wing leftysdeceiver Electric Plane Talk 4 Oct 07, 2001 08:10 AM
