Old Aug 26, 2003, 03:04 AM
Kevin Steele
Kevin Steele
Guest
n/a Posts
Tom Senior For Sale
Due to a forthcoming house move I have decided to sell my Tom Senior M2
milling machine. It is similar in size to the later M1, and I believe that
the same accessories fit. It has the overarm for horizontal milling, and a
replacement arbour has been made at some time. A spacer is required to fit
the arbour into the bearing on the overarm end casting. It is fitted with a
vertical head, with 2MT taper. This is the standard type of Tom Senior
vertical head that can be rotated to any angle. It has a single phase
motor, with reversing switch. It has three direct speeds and three further
lower speeds via a back gear on the main spindle. There is a power traverse
with four speeds, which is not currently connected. There is also a Tom
Senior slotting head, which I will give first option on to whoever buys the
machine -although I have already had other interest in this item. If
required I could throw in a Clarkson chuck and some collets, and maybe a
couple of cutters. There may be some other bits that I've forgotten. If
anyone is interested drop me an e-mail. I can send digital pics if
required. This is a heavy machine, but it splits into a base casting, main
body casting and table assembly very easily which would then fit into a
trailer (I carried the table assembly in the back of a Peugeot 205). It can
be re-assembled by 3 people (that's how I did it last time). If no one here
is interested it will go on e-bay.
Senior Telemaster Kit - NIB FOR SALE uniquewon Aircraft - Electric - Airplanes (FS/W) 2 Feb 01, 2003 11:15 PM
For Sale RTF Tom Hunts Tumble Watt RCFLYER0001 Aircraft - Electric - Airplanes (FS/W) 1 Oct 01, 2002 05:57 AM
Sig Senior and Edge 540 for sale at Triad fly in Steve H. Aircraft - Electric - Airplanes (FS/W) 8 Apr 28, 2002 11:09 PM
