Old Jun 08, 2011, 12:36 PM
2dogrc is offline
Find More Posts by 2dogrc
2dogrc's Avatar
United States, NC, Vass
Joined Apr 2005
New Product
New 20mm EPP WWII Series, ME-109 and P-51
We have just received in a new shipment of Techone planes, a Me-109 and P-51. These 2 planes both have a wingspan of 33" and a length of of about 27". The best part about these planes are that they are easy to build and can take alot of abuse. The 20mm thick EPP is reinforced by carbon fiber for extra strength.
Warbirds!!
Each plane is controlled by ailerons, rudder and elevator for a fully maneuverable flying machine! These would make perfect combat planes! Each plane also comes fully painted with a standoff scale scheme.
You will need to purchase electronics separate or use any 370 equivalent (150 Watt) motor for power. You will need 3 9 gram servos, or 2 6 and 1 9 gram depending on the torque of the servos. The holes are pre cut for mounting the servos. The battery bay is cut in the nose to help keep the CG right down the fuselage without any tendencies to pull one way or another.
I listed some specs below. The T-2208 motor is the same as the Tiger Motors sold by others and a decent stock setup. If you wanted some extra speed, but shorted flight try the Dualsky 2826-10 pusher jet motor or similar!
Specs:
  • Wingspan: 840mm (33.0in)
  • Fuselage length: 680mm (26.8n)
  • Flying weight: 320-350 g (11-12.3)
  • Motor: T-2208 or XM2826-10
  • Propeller: HD8040 or APC 7x5E
  • ESC: Dualsky 18A
  • Battery: Dualsky 800-1000 mAh 11.1V Li-Poly
  • Servo: 9 gram servo, 3 pcs
2dogrc is offline Find More Posts by 2dogrc
Site Sponsor
Latest blog entry: How to braid motor wires!
New Product Techone Nearly Indestructibly 33" EPP Me-109 Foam RC Airplane 2dogrc 2DogRC 6 Sep 08, 2014 08:33 AM
Sold Gws p-51 mustang and me-109 pulsery2k1 Aircraft - Electric - Airplanes (FS/W) 8 Apr 13, 2011 04:02 PM
Wanted CF UM Project: Sell me your UM Sukhoi and P-51 airframes, wings, etc! S.R.G. Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Mar 06, 2011 09:33 AM
Discussion Ripmax New ME-109 and P-51 Speed 600 Tommy D Electric Warbirds 54 Apr 05, 2007 10:06 PM
Help! FS: Miniblade, ME-109, P-51, P-40 (ie sucks to be me) McGrrr Aircraft - Sailplanes (FS/W) 21 Jun 19, 2005 04:34 PM
