Old Jun 08, 2011, 11:57 AM
KAW_Concours is offline
Find More Posts by KAW_Concours
Joined Mar 2009
Dell PE6800 Power Supply’s powers 2 FMA Powerlab 8’s.Completed
They are the JD200 model
I got info on how to set them up from this post.
http://www.rcgroups.com/forums/showt...0#post18035251
The second power supply has the DC isolated by taking out the 2 screws that are close to the DC output. I ground down the studs on the case and put a piece of fiberglass in.
In the test I have both chargers outputting 40 amps into 4S battery’s.
Charger 1 is charging 4 4S5000 packs. Charger2 is charging 2 4S5000, 4S3250 and a 4S3000 pack.
I have the power supply’s hooked to different 120 volt circuit breakers.
The Kill a Watt meter said the power supply is using 910 watts, PF .99, 115.5 Volts, 7.8 amps.
The second power supply I just had an amp meter on it and got 8.3 amps.
The input side of the chargers is 25.4 Volts 28 amps (That is 711 watts per charger).
The negative side of the Powerlab is hooked to the DC that is grounded. I am not sure if the matters.
The DC power distribution buss was made by:
http://www.helifreak.com/private.php...m&pmid=1420996
I could not have done it without xandrios help from RC Groups.
KAW_Concours is offline Find More Posts by KAW_Concours
Old Jun 08, 2011, 08:41 PM
KiloOne is offline
Find More Posts by KiloOne
Dale
KiloOne's Avatar
Joined Jul 2004
Your 4s5000 packs look like they have 16 cells each in them and it looks like maybe that is your main pack that you fly.
Have you thought of setting 1 charger up to charge them in an 8s configuration so you can get the full potential watts through that PL8?
You could probably charge all 3 4s5000 packs at once like that at over 1400 watts input.
Dale
KiloOne is offline Find More Posts by KiloOne
Old Jun 09, 2011, 07:07 AM
Joined Mar 2009
The "parallel safe adaptors" only go to 6S.
I like the poly-fused connections. I have hooked up stuff wrong and have had the poly-fuses save me. If you plug in a 3 cell and a 4 cell pack on different parallel boards at the same time you don't melt anything.
The max charge rate for the 8S5000 TP V2 is 4C. I don't want to go over 3C with these expensive batteries. I can do 2C if I charge 2 at a time and when I do 1 at a time I do 3C.
I would like FMA to make 8S "parallel safe adaptors".
Thunder Power split the discharge leads into 2 4S packs anyhow. They split the balance leads into 3S and 5S. Then they hooked one balance wire to the wrong side of the jumper discharge wire so I had to tear down the packs to rewire them.
Before I rewired them I was thinking about not using the "parallel safe adaptors". I wanted to keep them and all of my other packs are 4S or less. This way my balance boards work with all of my batteries.
At the field I only have 12 volts so I could not charge any faster anyway.
Old Jul 18, 2011, 12:58 PM
Oreo is offline
Find More Posts by Oreo
Gliding like a rock!
Oreo's Avatar
Baltimore, MD
Joined Apr 2007
KAW,
After you isolated the 12v return, which pins did you have to connect to get your 6800 to power up? Was it any different from the other non-isolated 6800?
I'm having some trouble getting mine to power up correctly.
Oreo is offline Find More Posts by Oreo
Old Jul 18, 2011, 06:34 PM
Oreo is offline
Oreo's Avatar
Baltimore, MD
Joined Apr 2007
OK, I think I found the answer to my own question. I'd still like to know if this is how you did it though KAW...
Pins A1 & B6 normally go to ground but when you isolate the DC return from ground A1 & B6 to ground will not start up the JD200 power supply because it's not ground they're looking for. Connect A1 & B6 to the main DC return & the power supply powers up like it should.
That sound about right to you?
Old Sep 18, 2011, 08:00 AM
Ohmic is offline
Find More Posts by Ohmic
USA
Joined Jan 2002
Nice work, KAW!
Ohmic is offline Find More Posts by Ohmic
Question iCharger 3010B vs FMA PowerLab 8? Brill 1 Batteries and Chargers 188 Sep 07, 2014 07:40 AM
Alert Power to the People! FMA Cellpro POWERLAB 8 everydayflyer Batteries and Chargers 356 Apr 17, 2012 07:01 PM
Discussion Powerlab 8 power input connection chipp Batteries and Chargers 15 Oct 09, 2011 12:24 PM
For Sale FMA Cellpro 4S charger and power supply combo jetfixrguy Aircraft - Electric - Batteries & Chargers (FS/W) 1 Apr 11, 2011 08:39 PM
Discussion FMA PowerLab 8 connection to PS q's dan1942 Batteries and Chargers 15 Oct 08, 2010 06:59 PM
