United States, NJ, Rockaway
Joined Feb 2011
recommended?
http://www.horizonhobby.com/Products...610#reviewsTab or is there one from HK most of you prefer?
I also think that you can get it cheaper from someone on this forum? It is becoming quite an old radio and in my opinion is not worth to buy new. For those who complain about the poor illumination of the screen, following this thread: http://www.helifreak.com/showthread.php?t=172436 I now got myself an awesome green display. Cheers |
They had the DX6i at my local hobby shop for same price. So I grabbed one. Hoping it binds ok with stock blitz/skyangel rcvr and the starmax one I have.
I could take it back. Is there a newer better model that is preferred? I'm also thinking it might be a good idea for us EDF novices to play with a EDF trainer for a while such as the Syncro as featured in the Nov. issue of electric flight. http://www.electrifly.com/ductedfans/gpma1581.html Then come back and have a blast with our little Migs and Sabres when we're a bit more proficient. |
Just cut away the plastic plugs leaving the pins from a JR extension lead and cut the micro connector which leaves a hollow sleeve for the pins to go into, once pushed together put some epoxy on them... that will serve 2 purposes, stops the wires touching each other and retains the pins from coming apart.
Yeah I found that with the Mig I needed extra length in the servo leads that I used for the ARF version, so it worked out much more convenient to do it like I described.
I used this rx... http://www.hobbyking.com/hobbyking/s...FReceiver.html and a Y harness... |
That is/was my point exactly, Slaanesh. Thanks.
http://www.rcgroups.com/forums/showp...&postcount=956 g |
| Thread Tools | |
| Discussion Mini Mig-15 EDF from Hobby King | Dreamcatcher | Foamy EDFs | 6 | Jan 16, 2012 09:58 AM |
| New Product JPower/Banana Hobby 40mm Foam Mig-15 and F-86 ducted fan | Mikemynameis | Micro EDF Jets and Power Systems | 557 | Aug 18, 2011 05:01 PM |
| Build Log Hobby King Micro A-6 & F-86 Jets | tallflyer | Foamy EDFs | 4 | Jun 04, 2011 02:05 PM |
| New Product J-Power 30mm EDF Jets (F-86 & Mig-15) | xplaneguy | Foamy EDFs | 1 | Jan 16, 2011 05:59 AM |
| Park/indoor EDF F-86 and MiG-15 production news! | Thomas B | Parkflyers | 8 | Feb 06, 2002 06:30 PM |
