Old Aug 24, 2011, 03:28 PM
52Sabre is offline
Find More Posts by 52Sabre
Avionics tech
52Sabre's Avatar
United States, MI, Grand Rapids
Joined Jun 2011
Thank you gentlemen. Box arrived from HK today. Got both the 2S and 3S varieties of the 430mah turnigy battery to play with. And the HK redbrick 10A 2s-3s ESC. Also got that AEO 35mm fan unit that I believe Nitro tested and wasn't happy with. It looks more like 40mm to me. Thought I might try to shoehorn that in sometime. What the heck. See what it does. Maybe I can make it work. Still need some stock impellers. BH is dragging their feet on them. Any help on those as well is appreciated.
52Sabre is offline Find More Posts by 52Sabre
Old Aug 24, 2011, 04:17 PM
MegaTesla is offline
Find More Posts by MegaTesla
Team30 Micro EDF
MegaTesla's Avatar
Stellenbosch, South Africa
Joined Apr 2004
I hope that red brick ESC works.... The other HK brand 10A escs doesn't, thats why I tell everyone to get the Turnigy 10A.
MegaTesla is offline Find More Posts by MegaTesla
Old Aug 24, 2011, 09:18 PM
52Sabre is offline
Avionics tech
52Sabre's Avatar
Joined Jun 2011
MT-turnigy 10a was also ordered. should arrive soon.
Now I need a recommendation and a link for a programmable xmtr with adjustable rates. Nothing too pricey please.
Old Aug 24, 2011, 09:38 PM
52Sabre is offline
Avionics tech
52Sabre's Avatar
Joined Jun 2011
Tylev - You can fry the stock ESC with 3S. Best change it. The ESC wires are soldered to the motor. Wiggle the motor back and forth. It'll break free and then you can get at the ESC.
Old Aug 25, 2011, 03:31 AM
miketre is offline
Find More Posts by miketre
miketre's Avatar
Joined Dec 2010
Gord, please help me to understand. what are the adjustments that you made to have differential with a 1 servo setup? Do you move the servo horn towards and past the hinge line? or do you move it away from the hinge line?
edit: opps, i think it just hit me. the magic is in your plywood!
miketre is offline Find More Posts by miketre
Old Aug 25, 2011, 05:53 AM
flypaper 2 is offline
Find More Posts by flypaper 2
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
You are right though Mike. If you move the horn towards the back of the ail., it would also work. If the setup were on top of the wing, it would also work as is. In fact I have the setup on top of the wing on a Cox P47 Thunderbolt. I also took the mold flashing out of inlet and outlet. It justs adds drag to that 100 MPH velocity that your trying to get through the tube. At this high speed, it makes a big difference. On the MIG, I took the servo horn off and moved it a couple of notches towards the front of the wing to get the differential. Had to make longer pushrod wires for it too. Just need the wind to go down to test fly it again.
Gord.
flypaper 2 is offline Find More Posts by flypaper 2
Old Aug 25, 2011, 08:14 AM
gionir is offline
Find More Posts by gionir
The stalling italian
gionir's Avatar
France, RA, Lyon
Joined Jan 2011
Hi guys, I am quite tired of waiting for the Orange rx R415 from HK to come back in stock and I was thinking to get this combo:
http://www.hobbyking.com/hobbyking/s...Receiver_.html
http://www.hobbyking.com/hobbyking/s...5pcs_bag_.html
It is a 4ch orange rx with standard plugs, and as I think the servos in the MiG won't fit this I was thinking to get that extension, cut the plugs and solder them to the servo wire.
Would that work?
Could you please suggest otherwise a solution that might work for the R410 rx?
Thanks in advance
giovanni
gionir is offline Find More Posts by gionir
Old Aug 25, 2011, 08:47 AM
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Don't see why that wouldn't work. In fact I was going to do the same thing with the bigger, orange 6 ch rcvr, before the weeny one came along.
Gord.
Old Aug 25, 2011, 09:07 AM
karlpenney is offline
Find More Posts by karlpenney
Halifax, NS
Joined Sep 2009
Would that work?
I'm also going to use the R410 in mine. At first, I was planning to cut off the micro servo connectors and crimp on standard servo pins. But, the wires on these servos are pretty small, 30 or maybe 32AWG. What I decided to do was to make up some micro female to standard servo male adapters. I ordered these micro servo extensions from BP Hobbies for making the adapters (still waiting for them). You can cut off the female end and add a standard servo connector to the other side. RC Connectors also sells these adapters already assembled. Not sure if any AUS suppliers might have the same thing.
karlpenney is offline Find More Posts by karlpenney
Old Aug 25, 2011, 09:44 AM
Team30 Micro EDF
MegaTesla's Avatar
Joined Apr 2004
According to a post on HK's Facebook page the R415 receivers will be back in stock within the next week.
Old Aug 25, 2011, 10:36 AM
giuseppi is offline
Find More Posts by giuseppi
CV-15 VB-16
giuseppi's Avatar
USA, TX, Friendswood
Joined Jul 2007
Won't the use of adaptors add unnecessary weight. Can't you just pop the connectors out of the plugs and push them on the RX pins individually. You only need to make sure you orient them correctly. I believe it's been discussed here before.
giuseppi is offline Find More Posts by giuseppi
Old Aug 25, 2011, 11:01 AM
Halifax, NS
Joined Sep 2009
The adapters may add a couple grams, but I like the convenience.
I just pulled one of the micro connectors out of the housing and they are too small to fit on a standard servo pin.
Old Aug 25, 2011, 11:22 AM
giuseppi is offline
CV-15 VB-16
giuseppi's Avatar
Joined Jul 2007
I was just looking at some, too. I'm sure with a bit of gentle persuasion they can be made to fit. And maybe a drop of solder for good measure. But, I do agree. With the plugs attached it is definitely more convenient.
g
Old Aug 25, 2011, 01:27 PM
tylev is offline
Find More Posts by tylev
tylev's Avatar
Finland, Kaarina
Joined Jul 2011
OK. With proper magnification glasses and double checking my order I discovered they are 2S.
So lets hope it flies on 2S. Some here seem skeptic. I got a CC Phoenix 10A ESC today but I won't have to install it then....
tylev is offline Find More Posts by tylev
Old Aug 25, 2011, 03:11 PM
BlazingStar is offline
Find More Posts by BlazingStar
-=BS=-
BlazingStar's Avatar
Thousand Oaks, CA
Joined Jul 2009
I did that and used heat shrink to hold the pins in place.
a little dicey applying a heat gun to your Rx....
if you decide to do this, be smarter than me and start with the connections on the inside and work your way out so you can get good heat to those servo connections more easily....
BlazingStar is offline Find More Posts by BlazingStar
Discussion Mini Mig-15 EDF from Hobby King Dreamcatcher Foamy EDFs 6 Jan 16, 2012 09:58 AM
New Product JPower/Banana Hobby 40mm Foam Mig-15 and F-86 ducted fan Mikey 68 Micro EDF Jets and Power Systems 557 Aug 18, 2011 05:01 PM
Build Log Hobby King Micro A-6 & F-86 Jets tallflyer Foamy EDFs 4 Jun 04, 2011 02:05 PM
New Product J-Power 30mm EDF Jets (F-86 & Mig-15) xplaneguy Foamy EDFs 1 Jan 16, 2011 05:59 AM
Park/indoor EDF F-86 and MiG-15 production news! Thomas B Parkflyers 8 Feb 06, 2002 06:30 PM
