Latest blog entry: AR6400 guillows Space Shuttle
Success!!
Both the F-86 and the red Mig-15 flew nicely on stock 350mah 2S w/o thrust tube. My first r/c flights since '92!
78deg. F, dead calm, sunset. Launched from a spot about 20' above a soccer field. Both Jets had aileron throws set to minimum.Mig is balanced spot on & flew w/drop tanks. Required no trim adjustments. Has 7g of lead epoxied under nose. Climbed quickly and once at a safe altitude it was brought back to <1/2 throttle. Cruised around nicely allowing me to get a pretty good feel of the ship. Turns were smooth as silk and easy without much perceptible loss of altitude. Very pleasant fun flyer. To cut weight and drag, the F-86 was flown w/o tanks. Again backed off on the gas at altitude. It was bit more tricky to fly. It did not have the 7g of lead in the nose relying instead on battery location. Although balanced to spec she still appeared slightly tail heavy in the air. She also required full left aileron trim. Even though ailerons did appear to be perfectly level prior to flight. But she did finally trim out ok. Turns were not as nice as the Mig, wanting to drop altitude with every aileron input. My conclusion is the Mig has much more available surface area to fly on. A mid wing design vs. the Sabre's low wing may be a factor. The wings also seem to be a bit larger as is the fuselage. Aileron servo input was reversed between the two planes. I had to throw the switch on the transmitter. But, I like the Mig's smaller outboard ailerons vs. the Sabre's more sensitive larger inboard ones. The Mig would fly easily on less throttle than the Sabre. So for folks getting frustrated with the F-86, try the Mig. Regardless, you'll be flying soon. The secret of course is in the throw. Getting this is essential. Get a few meters above your field if possible, keep the wings level, nose slightly up and give it a good toss. And don't give it too harsh a control input too soon. You'll soon come back from the field with a big grin and renewed confidence.
flypaper 2 & UNGN
Thanks for the info. I feel a bit more educated. Still lots to learn. Wasn't flying r/c back then only working on full scale military stuff. Didn't get the r/c aircraft bug until '87 and then was only in it until '92. Just flew high wings and stiks. Never learned any aerobatics. Guess I will now.
Pyrmont, Sydney, Australia
Joined Jun 2000
I did the same trick to my first and last nitro engine -an ASP .15. I could never start the bugger easily and couldn't afford an electric starter back then (I was just a pup but I had a shoelaces). Luckily electric came along for me
I posted this in the other thread but I'm not sure folks are reading both... so if I may, I'd like to repost my question:
| Thread Tools | |
| Discussion Mini Mig-15 EDF from Hobby King | Dreamcatcher | Foamy EDFs | 6 | Jan 16, 2012 09:58 AM |
| New Product JPower/Banana Hobby 40mm Foam Mig-15 and F-86 ducted fan | Mikemynameis | Micro EDF Jets and Power Systems | 557 | Aug 18, 2011 05:01 PM |
| Build Log Hobby King Micro A-6 & F-86 Jets | tallflyer | Foamy EDFs | 4 | Jun 04, 2011 02:05 PM |
| New Product J-Power 30mm EDF Jets (F-86 & Mig-15) | xplaneguy | Foamy EDFs | 1 | Jan 16, 2011 05:59 AM |
| Park/indoor EDF F-86 and MiG-15 production news! | Thomas B | Parkflyers | 8 | Feb 06, 2002 06:30 PM |
