Old Jul 27, 2011, 10:42 AM
e_lm_70 is offline
Find More Posts by e_lm_70
Austria
Joined Jan 2004
Originally Posted by Slaanesh View Post
However all this 'C' rating stuff is also a lot of marketing hype. Marketers love putting big numbers on their products!
A batteries REAL performance is given by it's internal resistance - which is seldom stated - however can be easily measured with a multimeter. Some LiPO chargers also have it notably the iCharger series.
C rating is somehow marketing .. but as well ... is the outcome of quality test as well ...
The battery is not a passive resistor, where internal resistance is constant (or function of the temperature) ... in a battery the load condition change the internal resistance.
The internal resistance measured by a charger can't be very accurate .. since measure the resistance for charge the battery ... while the C rating is based normally for the discharge.
If you see how the battery are tested, you will see that IR is not so relevant ... you will see that it will be mainly shown the voltage kept by the battery at different constant discharge ... for the full battery discharge time ... on top ... the measurement of the temperature of the battery is always reported by proper battery testing.
LiPo battery should never get more hot then ~60 deg ... so .. often the C rating is mainly due not only by the voltage drop, but the limit of overheat the battery during a discharge.
Anyhow ... the C rating in these days is relative accurate from the producers ... clearly they tend to be a bit optimistic on it, since the C rating measure also the quality of the battery on keep voltage under load.
Tchuss
e_lm_70
e_lm_70 is offline Find More Posts by e_lm_70
Old Jul 27, 2011, 10:54 AM
bluemeane is offline
Find More Posts by bluemeane
bluemeane's Avatar
Joined Apr 2007
Originally Posted by MegaTesla View Post
The stock motor can handle 4s. So, no need to upgrade the motor.
If you want to use a different motor, the only one that I think will fit is the 1015 which is always out of stock and not nearly as powerful.
What 4s battery will fit in this little guy??? I can barely fit the stock 2s in there lol
Do you have links to any batteries that fit/work? ( I hate the HK search feature lol)
bluemeane is offline Find More Posts by bluemeane
Old Jul 27, 2011, 11:03 AM
boingk is offline
Find More Posts by boingk
boingk's Avatar
NSW, Australia
Joined Feb 2011
Rhino 3s 610mAh will fit and fly well with a tad of uptrim... I imagine a 400~500mAh 4-cell pack would be the order of the day for this little fellow.
Hobbyking don't stock 4-cell packs under about 800mAh so I'd recommend running series with two packs or soldering your own from single cells. Of course, if somone could give a link to something premade that'd be top!
Cheers - boingk
boingk is offline Find More Posts by boingk
Old Jul 27, 2011, 12:42 PM
bluemeane's Avatar
Joined Apr 2007
Cheers - boingk
Is the "Rhino 3s 610mAh" available at HK?
Old Jul 27, 2011, 12:44 PM
bluemeane's Avatar
Joined Apr 2007
All I can find is the 2s and 4s 610mAH no 3s
Well they have a 3s 610 mAH... BUT it is a 11.1 and I don't think that would work would it?
Old Jul 27, 2011, 01:25 PM
DESIGN ENGNR is offline
Find More Posts by DESIGN ENGNR
Smyrna, TN
Joined Jan 2005
Blue,
11.1 volts is the nominal voltage for a 3 cell pack.
DESIGN ENGNR is offline Find More Posts by DESIGN ENGNR
Old Jul 27, 2011, 02:11 PM
bluemeane's Avatar
Joined Apr 2007
Originally Posted by DESIGN ENGNR View Post
Blue,
D'oh!
That's right lol
Old Jul 27, 2011, 02:12 PM
bluemeane's Avatar
Joined Apr 2007
So would a 3s 11.1 610 be good for this?
what would I get out of it? More speed? Longer flight times? If both what are the increases?
Old Jul 27, 2011, 05:26 PM
Odysis is offline
Find More Posts by Odysis
Life begins at transition
Australia, VIC, Sale
Joined May 2007
I use a 4s 350 and 360. Weighs in at 38 grams.
It's by no means the heaviest pack flown.
A bigger capacity pack will give you slightly more speed, as the battery won't sag as much because it's not working as hard. The extended flight time is the big one. If you go from a 400 up to a 600, you'll get just under 50% more flight time.
Odysis is offline Find More Posts by Odysis
Old Jul 27, 2011, 06:02 PM
Strike3 is offline
Find More Posts by Strike3
I don't want to land yet!
Joined Jan 2010
This is with a 610mAh, fits in under the canopy alright with a slight removal of foam on the side... it is flying well apart from a few silly moves it does... must keep plenty of speed through loops and rolls, drops a wing real easy and if you have no altitude the ground is where it's headed... lucky they weigh next to nothing and damage is limited.
Skyangel Hobbyking Micro Mig15 (1 min 57 sec)
Strike3 is offline Find More Posts by Strike3
Old Jul 27, 2011, 06:31 PM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
185W power system is installed and ready to go..... just have to wait for my new Thunder Power 65C lipo to arrive.
NitroCharged is offline Find More Posts by NitroCharged
Old Jul 28, 2011, 02:59 AM
e_lm_70 is offline
Austria
Joined Jan 2004
So ... 1 minutes of fly time ?
I mean .. there are hobby racket engine (same chemical stuff used in some "toy bomb" for Silvester), that last longer
Tchuss
e_lm_70
Old Jul 28, 2011, 03:44 AM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
Close... 2:15min if I fly WOT all the time and stop when I have used 80% of the lipo.
Old Jul 28, 2011, 04:18 AM
Strike3 is offline
Joined Jan 2010
But it will be an intense 2:15... can't wait to see it!
Old Jul 28, 2011, 04:33 PM
trust416 is offline
Find More Posts by trust416
Toronto, Canada
Joined Jan 2005
any word on new models? these were the same initial ones they came out with in the 50mm series if i remember correctly, so im guessing its just a matter of time before we see the other ones?
Dnt get me wrong I like these and have been fighting clicking that order now button since day one - but I just know if i buy one by the time i get it all sorted out and flying some new ones will come out that i like the styling of much better
trust416 is offline Find More Posts by trust416
Discussion Mini Mig-15 EDF from Hobby King Dreamcatcher Foamy EDFs 6 Jan 16, 2012 10:58 AM
New Product JPower/Banana Hobby 40mm Foam Mig-15 and F-86 ducted fan FieldofDreamsFlyer Micro EDF Jets and Power Systems 557 Aug 18, 2011 06:01 PM
Build Log Hobby King Micro A-6 & F-86 Jets tallflyer Foamy EDFs 4 Jun 04, 2011 03:05 PM
New Product J-Power 30mm EDF Jets (F-86 & Mig-15) xplaneguy Foamy EDFs 1 Jan 16, 2011 06:59 AM
Park/indoor EDF F-86 and MiG-15 production news! Thomas B Parkflyers 8 Feb 06, 2002 07:30 PM
