Old Jul 23, 2011, 08:33 PM
BlazingStar is offline
Find More Posts by BlazingStar
-=BS=-
BlazingStar's Avatar
Thousand Oaks, CA
Joined Jul 2009
So the stock ESC can handle a 3S?
I thoughht that was hopeless...
Maybe if I don't go WOT for too long at a time?
BlazingStar is offline Find More Posts by BlazingStar
kuczy is offline
Find More Posts by kuczy
The Earth got in the way!
kuczy's Avatar
United States, OH, Canal Winchester
Joined Feb 2007
What 4s are you using??
kuczy is offline Find More Posts by kuczy
Old Jul 23, 2011, 09:55 PM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
Once again - the stock ESC is for 2S only.
NitroCharged is offline Find More Posts by NitroCharged
Old Jul 23, 2011, 10:32 PM
kuczy is offline
kuczy's Avatar
Joined Feb 2007
Who keeps anything stock??
I plan to fly it on 2s for a while IF HK will ever ship my batteries
I've already got my 3s batteries from Horizon so I may be going that route first. I guess I do have a Hyperion 2s 450 25c.
I have a AR6300 and I just ordered some connectors for it. I also have an Orange Rx that I trust if needed.
My Red Mig will be here on Monday, sadly though I'll be roughing it at the beach for 6days. By the time I get back everything should be here. Minus my EMS order for HK China.
Old Jul 23, 2011, 10:34 PM
Odysis is offline
Find More Posts by Odysis
Life begins at transition
Australia, VIC, Sale
Joined May 2007
Yes, as NC said, don't try this at home! (I mean on the stock ESC)
I'm using a Turnigy Plush 10A. I got the kit version, so all I got was a fan and motor, the rest is out of my parts bin.
I'm using a 4s 360. The jet can definately handle more, I've seen it fly, stock, on 3s 610, so a 4s 400-420 would still work.
Odysis is offline Find More Posts by Odysis
kuczy is offline
kuczy's Avatar
Joined Feb 2007
I have a Dualsky 12amp if needed
Old Jul 23, 2011, 11:07 PM
Bajora is offline
Find More Posts by Bajora
KA6KHM
Bajora's Avatar
Joined Sep 2004
I flew my little MIg on 3S for the first time today. MUCH better!! I dorked it on the first launch but absolutely no damage. Gotta love these super light airframes.
Bajora is offline Find More Posts by Bajora
Old Jul 24, 2011, 05:02 AM
Slaanesh is offline
Find More Posts by Slaanesh
Not enough hours in the day
Slaanesh's Avatar
Melbourne
Joined Feb 2009
Originally Posted by speedy01 View Post
Huh?
Gene K
My test results were badly worded.
Basically my test setup changed so I couldn't make a direct before and after comparison of adding a thrust tube.
My flights post thrust tube fitted have certainly seemed faster.
Slaanesh is offline Find More Posts by Slaanesh
Old Jul 24, 2011, 05:58 PM
mcross is offline
Find More Posts by mcross
For Sale-everything over 250 g
Souderton Pa. USA
Joined Mar 2002
Originally Posted by corsair nut View Post
hey mcross..is that brets pylon edf back there??? lucky!
Yup, that's the Blowdart. It's ready to fly if/when I get a day below 100 and 20 mph.
My Sabre threw the fan. I must have stripped the nut putting it on after balancing and it finally let loose. It's pretty tough plastic, didn't break any blades bouncing around when it came off. But it's about 5mm smaller from rubbing before it came off.
mcross is offline Find More Posts by mcross
Old Jul 25, 2011, 01:20 AM
Odysis is offline
Joined May 2007
Yup, mine's thrown the nut too. Loktite'd on now...
Old Jul 25, 2011, 09:38 AM
boingk is offline
Find More Posts by boingk
boingk's Avatar
NSW, Australia
Joined Feb 2011
Also threw the fan. Simply superglued back on for the next flight after checking for balance and damage. No worries after that, I'd recommend it for anyone putting one of these together.
Cheers - boingk
boingk is offline Find More Posts by boingk
Old Jul 25, 2011, 02:10 PM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Flew mine again today, with the CG further forward. Much easier to fly, but I ended up with a pretty nasty crash... Got a bit cocky with rolling it, and ended up too close to some trees. In an attempt to not hit them, I ended up stalling it behind them.
It made a good solid thump, and I had to climb a couple fences to get to it. Luckily the battery was still connected, so I could rev it up a bit and walk toward the sound.
After I lost sight of it, I hit a tree right against a solid fence. Luckily I hit below the top of the fence and could get it easily. Total damage was a lost aileron linkage (really need to make a better system, hoping my second new revision stays on better) and the wing popped off the fuselage. No damage to the fuse or wing, just a bad glue joint let go.
I've got it all back together now, but the winds are way too high now.
Next flight will be at a bigger park, a small softball diamond is just a bit too small for it and my reflexes just yet. A full soccer/football field should be much better.
wparsons is offline Find More Posts by wparsons
Old Jul 25, 2011, 02:33 PM
Richard Cox is offline
Find More Posts by Richard Cox
Richard Cox
Thousand Oaks, CA
Joined Dec 2003
You don't need to change the connectors to fit the AR6300, just swap the brown and orange wires and cut off the little bump on the plastic housing, then press into the RX.
Richard Cox is offline Find More Posts by Richard Cox
Old Jul 25, 2011, 08:51 PM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
hmmm.,... it appears my new little power system I made up last night for my Mig requires 19A on 3S....
Old Jul 25, 2011, 09:04 PM
52Sabre is offline
Find More Posts by 52Sabre
Avionics tech
52Sabre's Avatar
United States, MI, Grand Rapids
Joined Jun 2011
Mig CG (arf w/tanks mounted) - I've epoxied 7g of lead under the nose behind the intake. With stock setup this puts it at right on the manual's CG if not slightly ahead. Where/how is everyone mounting their balance weight? Haven't flown it yet but it doesn't feel like it has much power. Another brick? Is the F-86 a better flyer?
52Sabre is offline Find More Posts by 52Sabre
Discussion Mini Mig-15 EDF from Hobby King Dreamcatcher Foamy EDFs 6 Jan 16, 2012 09:58 AM
New Product JPower/Banana Hobby 40mm Foam Mig-15 and F-86 ducted fan FieldofDreamsFlyer Micro EDF Jets and Power Systems 557 Aug 18, 2011 05:01 PM
Build Log Hobby King Micro A-6 & F-86 Jets tallflyer Foamy EDFs 4 Jun 04, 2011 02:05 PM
New Product J-Power 30mm EDF Jets (F-86 & Mig-15) xplaneguy Foamy EDFs 1 Jan 16, 2011 05:59 AM
Park/indoor EDF F-86 and MiG-15 production news! Thomas B Parkflyers 8 Feb 06, 2002 06:30 PM
