Old Jul 21, 2011, 04:30 PM
Odysis is offline
Find More Posts by Odysis
Life begins at transition
Australia, VIC, Sale
Joined May 2007
Molex Picoblade? Fancy name, thanks, I didn't know what they were called!
I used the HK 2.6g servos, with the tiny little connectors. As I said, don't know the name of them, but once I pulled them apart, I saw the sockets are actually quite large.
Odysis is offline Find More Posts by Odysis
Old Jul 21, 2011, 05:41 PM
SonicRaT is offline
Find More Posts by SonicRaT
Network Gnome
SonicRaT's Avatar
United States, WI, Dunbar
Joined Jun 2008
Originally Posted by bluemeane View Post
What is a "buddy code"? And how can I get one(some)?? lol
Edit: So i found out what they are... Do you have a buddy code for your order?? I'd love one.
Check out this site:
http://hk.rc-international.info/swarm
Makes it a lot easier! I'll be throwing mine up as soon as it allows me to.
SonicRaT is offline Find More Posts by SonicRaT
Old Jul 21, 2011, 11:00 PM
K9000wner is offline
Find More Posts by K9000wner
Thatsright I drankthe rum
K9000wner's Avatar
USA, MN, Robbinsdale
Joined May 2006
Originally Posted by NitroCharged View Post
Which ever is largest: rotor hub, motor mount, outrunner bell.
technically speaking- you use the "sweep area of the fan"
but the inside dia of the fan shroud is also commonly used.
but this in not rocket science..... its only jet science.
so use what you feel is best.
FYI 35mm-14mm Calc
and the largest part of motor hub assembly
K9000wner is offline Find More Posts by K9000wner
Old Jul 21, 2011, 11:56 PM
kuczy is offline
Find More Posts by kuczy
The Earth got in the way!
kuczy's Avatar
United States, OH, Canal Winchester
Joined Feb 2007
Originally Posted by Richard Cox View Post
My first F-86 is still in the tree. Replacement arrived yesterday.
Removed a little foam to shoehorn in the 460 nanotech battery, and the CG came out
exactly where the original with the 360 battery and 1/4 oz nose weight was.
To use the AR6300, swap the red and brown wires on the servo plugs by carefully
prying up the plastic fingers on the connector while gently pulling on the wire,
then reinsert the brown wire in the middle and the red wire on the end.
Trim off the little bump of plastic on the connector housing and press them into the
AR6300. They are tight, but they fit. I cut a little trough on the right side of the fuse
so the RX fits down flush with the top of the canopy opening, with the connectors
toward the front. Couple drops of hot glue keep it away from the elevator servo arm.
Very clean, and allows room for the battery after trimming the foam bulkhead ahead of
the servo.
Maiden today.
Is yours a HK Saber or a Banana Saber. I ask because my Red Mig from Banana will be here on Monday. I've been reading, trying to figure out what RX to use with my JR x9503. If I can just get the pins out of the keepers and plug each individual into an AR6300 that would be the berries!!!
kuczy is offline Find More Posts by kuczy
Old Jul 22, 2011, 12:19 AM
Slaanesh is offline
Find More Posts by Slaanesh
Not enough hours in the day
Slaanesh's Avatar
Melbourne
Joined Feb 2009
I like the RED Mig! HK won't stock it I imagine. And shipping from Banana to Australia is "forget it" expensive (as much as the model!).
HobbyKing don't stock alternative color schemes of the 50mm series so probably won't do so with the 35mm ones.
My F-86 thrust tube is ready to install. Once it's in and confirmed to be good I'll see if I can make a template for others to use.
Slaanesh is offline Find More Posts by Slaanesh
Old Jul 22, 2011, 01:37 AM
boingk is offline
Find More Posts by boingk
boingk's Avatar
NSW, Australia
Joined Feb 2011
The hell with the red MiG... I mean come on, I get it; they're Communist. Big deal. Maybe its just me but I prefer the at least semi-realistic colour schemes. Mind you I can definitely see why some like the red scheme, it does look sharp.
Anywho my Rhino 3-cell 360's showed up the other week as well as a replacement servo for the one that jammed in flight. I reckon its rebuild and refly time!
Cheers - boingk
boingk is offline Find More Posts by boingk
Old Jul 22, 2011, 07:16 AM
ducatirdr is offline
Find More Posts by ducatirdr
ducatirdr's Avatar
United States, MA, Sutton
Joined Aug 2006
I had the HK Mig. I expect the servo plugs will be the wrong micro connectors for the AR6300. So I used this3" JST Extension Ultra Lightweight [SPMEXJST3UL]
Carefully crush and cut away the female end of the extension to free the pins. Then you simply plug the pins into the male end of the servo and plug the extensions correct connector into the AR6300. Just reverse the positive and negative wires from the extension into the servo. Wrap the connector/pins with some blenderm or shrink wrap to hold the pins in and your ready to go.
ducatirdr is offline Find More Posts by ducatirdr
Old Jul 22, 2011, 07:21 AM
RNAF is offline
Find More Posts by RNAF
RNAF's Avatar
The Netherlands
Joined Dec 2003
85% FSA is 27mm...
(rotor diameter)˛ - (hub diameter or motor diameter :- whichever is larger)˛ = FSA (Fan Swept Area)
√FSA x 0.85 = 85% FSA exit diameter.
e.g.
With the rotor diameter of 35mm and motor bell of 14mm diameter:
35mm˛ - 14mm˛ = 1029mm
√1029mm x .85 = 27.2mm diameter
Aren't you forgetting Pi?
Area of a circle, based on radius: Pi · r˛
When scaling an area I would:
factor˛ · area = scaled area
Then, this scaled area to a radius:
√(area / pi)
Then, the calculated radius time two and you've got yourself a new diameter..
I come to 29.57 mm diameter this way for 85% FSA.
RNAF is offline Find More Posts by RNAF
Old Jul 22, 2011, 07:24 AM
RNAF is offline
RNAF's Avatar
The Netherlands
Joined Dec 2003
Here's some reference btw:
http://www.mathgoodies.com/lessons/v...rcle_area.html
Old Jul 22, 2011, 07:34 AM
RNAF is offline
RNAF's Avatar
The Netherlands
Joined Dec 2003
Excuse me, I might've forgotten about squaring the scale factor in my last calculation
I come to 27.27mm diameter *walks away in shame*
Old Jul 22, 2011, 07:37 AM
MRGTX is offline
Find More Posts by MRGTX
MRGTX's Avatar
United States, CT
Joined Aug 2005
Cheers - boingk
boingk,
1.) Get your panties untwisted
2.) Watch this historical footage from the Soviet Aerobatic team (with their RED Mig 15s.
Soviet MiG-15 Aerobatic Teams - part1 (9 min 55 sec)
3.) Embrace Communism, comrade!
MRGTX is offline Find More Posts by MRGTX
Old Jul 22, 2011, 07:43 AM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
RNAF -
Meanwhile - the front mounting plate of the stock motor is 10.78mm.... Yup! Just a whisker too big to slide into a GWS 30mm shroud. Mounting holes are too close together to use in an AEO 30mm shroud. So, in the lathe it went and I removed the 0.78mm extra so it fits into a GWS shroud. Ooops!... the motors neck is not long enough to reach the front motor mount of the shroud. It's about 2mm short. Out with a 12mm drill bit and take out some of the back of the stator vanes and motor mount.
Why? Odysis ran his on 4S and even though he used saggy lipo's it handled it without incident. Since this is the first 14mm outrunner I have gotten my hands on (with such a low kV), I just have to try it in a 30mm fan unit. On 4S for starters no less.
NitroCharged is offline Find More Posts by NitroCharged
Old Jul 22, 2011, 08:11 AM
kuczy is offline
kuczy's Avatar
Joined Feb 2007
Thank you
Old Jul 22, 2011, 08:27 AM
Slaanesh is offline
Slaanesh's Avatar
Melbourne
Joined Feb 2009
My thrust tube weights 2 grams! Two whole stinking grams! It's too heavy!
2 grams that far back is murder for the CoG and it's all out now.
I need some really light weight plastic .... or maybe paper is lighter? How much does paper weigh?
*grumbles*
Old Jul 22, 2011, 08:30 AM
kuczy is offline
kuczy's Avatar
Joined Feb 2007
*grumbles*
What about tracing paper or news print paper? Should be pretty light.
I've even thought of using the protective clear layer of Monokote. I have some so it'll be pretty cheap.
Discussion Mini Mig-15 EDF from Hobby King Dreamcatcher Foamy EDFs 6 Jan 16, 2012 09:58 AM
New Product JPower/Banana Hobby 40mm Foam Mig-15 and F-86 ducted fan FieldofDreamsFlyer Micro EDF Jets and Power Systems 557 Aug 18, 2011 05:01 PM
Build Log Hobby King Micro A-6 & F-86 Jets tallflyer Foamy EDFs 4 Jun 04, 2011 02:05 PM
New Product J-Power 30mm EDF Jets (F-86 & Mig-15) xplaneguy Foamy EDFs 1 Jan 16, 2011 05:59 AM
Park/indoor EDF F-86 and MiG-15 production news! Thomas B Parkflyers 8 Feb 06, 2002 06:30 PM
