http://www.rcgroups.com/forums/showp...&postcount=549 maybe I can get the link to work |
Thanks. I had forgotten that useful post.
Nitro, Ody, Slaan, [insert expert name here], what would your recommendation be for the stock motor and fan on 2S and 3S for the percentage? Thanks again. Quote:
I was using the values from here:
http://www.rcgroups.com/forums/showp...&postcount=549 This spreadsheet uses a motor with a 15mm diameter - thus the differences between the figures I've given and NCs. So... is the motor 14mm or 15mm? |
Thousand Oaks, CA
Joined Dec 2003
My first F-86 is still in the tree. Replacement arrived yesterday.
Removed a little foam to shoehorn in the 460 nanotech battery, and the CG came out exactly where the original with the 360 battery and 1/4 oz nose weight was. To use the AR6300, swap the red and brown wires on the servo plugs by carefully prying up the plastic fingers on the connector while gently pulling on the wire, then reinsert the brown wire in the middle and the red wire on the end. Trim off the little bump of plastic on the connector housing and press them into the AR6300. They are tight, but they fit. I cut a little trough on the right side of the fuse so the RX fits down flush with the top of the canopy opening, with the connectors toward the front. Couple drops of hot glue keep it away from the elevator servo arm. Very clean, and allows room for the battery after trimming the foam bulkhead ahead of the servo. Maiden today. |
United States, CA, San Diego
Joined May 2004
scott. |
Halifax, NS
Joined Sep 2009
| Thread Tools | |
| Discussion Mini Mig-15 EDF from Hobby King | Dreamcatcher | Foamy EDFs | 6 | Jan 16, 2012 09:58 AM |
| New Product JPower/Banana Hobby 40mm Foam Mig-15 and F-86 ducted fan | Mikemynameis | Micro EDF Jets and Power Systems | 557 | Aug 18, 2011 05:01 PM |
| Build Log Hobby King Micro A-6 & F-86 Jets | tallflyer | Foamy EDFs | 4 | Jun 04, 2011 02:05 PM |
| New Product J-Power 30mm EDF Jets (F-86 & Mig-15) | xplaneguy | Foamy EDFs | 1 | Jan 16, 2011 05:59 AM |
| Park/indoor EDF F-86 and MiG-15 production news! | Thomas B | Parkflyers | 8 | Feb 06, 2002 06:30 PM |
