Old Jul 15, 2011, 06:52 PM
Odysis is offline
Find More Posts by Odysis
Life begins at transition
Australia, VIC, Sale
Joined May 2007
Originally Posted by speedy01 View Post
HUH?
Gene K
Longitudinal and manoeuvre stability. Long stab is speed/pitch coupling, man stab is the amount of elevator per 'g' required.
Odysis is offline Find More Posts by Odysis
Old Jul 15, 2011, 07:10 PM
mcross is offline
Find More Posts by mcross
For Sale-everything over 250 g
Souderton Pa. USA
Joined Mar 2002
Originally Posted by Odysis View Post
Slick. I might have to 'borrow' your solution
I did notice the pitch up under power you spoke of. Made launches interesting! It's probably responsible for a fair amount of the long stab problem. Man stab's hidden to an extent by those bits of spaghetti connected to the elevator.
What ESC are you using?
I'm using a CC T-Bird 9 ESC.
I have the most nose down thrust I can do without resorting to a curved thrust tube or a deflector. It's enough to make it easily launchable, as long as your below half throttle. Above half and it'll nose up and spin.
mcross is offline Find More Posts by mcross
Old Jul 15, 2011, 08:10 PM
Lberry.88 is offline
Find More Posts by Lberry.88
If in doubt, add accelerant
Lberry.88's Avatar
United Kingdom, England, Stansted Mountfitchet
Joined May 2007
Originally Posted by MRGTX View Post
How big of a problem is this death-spiral issue? L.Berry88: You gave up on the plane because of this?!
Well yes and no - yes because it was the annoyingly random spiralling that pretty much wrote off the airframe: I was determined at first to get it flying with just a 2S - but that meant adding lots of weight to the nose, so she was terribly underpowered, so crashed :P so i added the 3s and got into 2 death spirals, properly finishing her off. I'm not sure i have ever so comprehensively written off an airframe in such a short period of time! I haven't given up on it - but i do need a new airframe, too much glue and damage to the old one. Anyway atm my plane time is taken up with developing retracts for the micro mossie
Lberry.88 is offline Find More Posts by Lberry.88
Old Jul 15, 2011, 10:08 PM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
Hey Gene - we gave Ody stick this morning down the field about the lingo he's using on the boards....
NitroCharged is offline Find More Posts by NitroCharged
Old Jul 15, 2011, 10:30 PM
Odysis is offline
Joined May 2007
Wha'eva. Y'all be hatin!
Ran a few laps on the mig again today. Needs a thrust tube, bad. The low speed, high power thing makes launching a little less than relaxed.
I did mcross's pushrod keeper trick. Much better feel.
Dorked it flying too low, snapped a wing outboard of the servo clean off. It'll buff right out
Old Jul 16, 2011, 08:30 PM
speedy01 is online now
Find More Posts by speedy01
Gulf Breeze, FL
Joined Jul 2006
Originally Posted by NitroCharged View Post
... we gave Ody stick this morning down the field about the lingo he's using on the boards....
Since I didn't think you had flogged him, I had to look up "stick" in Australian/British (Noun. 1. Hassle, excessive criticism, trouble). Thank you.
Dorked it flying too low....
Hmmmm wonder if it was caused by man stab, long stab or thumb stab?
Gene K
speedy01 is online now Find More Posts by speedy01
Old Jul 16, 2011, 09:24 PM
Odysis is offline
Joined May 2007
Excessive manlyness (i.e. balls bigger than brain )
Old Jul 16, 2011, 09:38 PM
giuseppi is offline
Find More Posts by giuseppi
CV-15 VB-16
giuseppi's Avatar
USA, TX, Friendswood
Joined Jul 2007
Crikey!
g
giuseppi is offline Find More Posts by giuseppi
Old Jul 16, 2011, 09:43 PM
Odysis is offline
Joined May 2007
Yeah, once I'd stiffened up the elevator stab (as per mcross's method), it felt much much better. Started doing laps at head height and below.
Apparently at head height's cool. 6 feet below head height's not!
While I was repairing the wing, I also gave it a bit of liposuction. Not so much junk in the trunk any more. Think Cameron Diaz, as opposed to Beyonce Thanks Strike for that suggestion!
Old Jul 16, 2011, 09:46 PM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
You're lucky its raining this morning Ody - I was ready to give your Mig a run for it's money.
Old Jul 16, 2011, 09:48 PM
Odysis is offline
Joined May 2007
He he, now with my new, improved exhaust, it'll move out quicker than yesterday!
Gone with the same batteries as me, or still the old plan?
(hang on, you're not running the stock fan are you... That's cheating! until i get a better one that is)
Old Jul 16, 2011, 10:02 PM
MegaTesla is offline
Find More Posts by MegaTesla
Team30 Micro EDF
MegaTesla's Avatar
Stellenbosch, South Africa
Joined Apr 2004
I got a duration flight in on the Sabre today. I wanted to see what all this 2s complaining was about, so I put a 2s 800mAh nano in there. Same size as the 460mAh 3s. I had to fly almost WOT most of the time to keep it in the air. It was a very boring flight that lasted nearly 10 minutes!
MegaTesla is offline Find More Posts by MegaTesla
Old Jul 16, 2011, 10:35 PM
Odysis is offline
Joined May 2007
Wow, 10 min! That's impressive, even if it is just circuits.
How much does that batt weigh? I was a 3s 610 go in one yesterday, so I'm thinking it can handle a fair lump of lithium.
Hmm, 6s 360...
Old Jul 16, 2011, 10:52 PM
Strike3 is offline
Find More Posts by Strike3
I don't want to land yet!
Joined Jan 2010
Oh no, here we go again... you speed freaks! I'll stay on my stock unit and have an extra 2 minutes of flying... hehehe
Strike3 is offline Find More Posts by Strike3
Old Jul 16, 2011, 11:08 PM
giuseppi is offline
CV-15 VB-16
giuseppi's Avatar
Joined Jul 2007
Originally Posted by giuseppi View Post
Crikey!
g
You know, it just doesn't sound right when I say it!
Discussion Mini Mig-15 EDF from Hobby King Dreamcatcher Foamy EDFs 6 Jan 16, 2012 10:58 AM
New Product JPower/Banana Hobby 40mm Foam Mig-15 and F-86 ducted fan FieldofDreamsFlyer Micro EDF Jets and Power Systems 557 Aug 18, 2011 06:01 PM
Build Log Hobby King Micro A-6 & F-86 Jets tallflyer Foamy EDFs 4 Jun 04, 2011 03:05 PM
New Product J-Power 30mm EDF Jets (F-86 & Mig-15) xplaneguy Foamy EDFs 1 Jan 16, 2011 06:59 AM
Park/indoor EDF F-86 and MiG-15 production news! Thomas B Parkflyers 8 Feb 06, 2002 07:30 PM
