Old Jul 08, 2011, 02:35 PM
giuseppi is offline
Find More Posts by giuseppi
CV-15 VB-16
giuseppi's Avatar
USA, TX, Friendswood
Joined Jul 2007
Originally Posted by Chads View Post
Hey guys,
I have a question. I ordered an F-86 from HobbyKing and got it today. When I fired it up one of the fan blades broke off and flew out the back. I CA'd in on but not sure if this is a good idea. Any Ideas?
Is there a better fan I can get for this thing?
You can get an AEO 35mm housing and 8 blade rotor from HK.
http://www.hobbyking.com/hobbyking/s...fan_rotor.html
http://www.hobbyking.com/hobbyking/s...n_Housing.html
Also, a complete unit is available :
http://www.hobbyking.com/hobbyking/s...ssembled_.html
I don't know if the stock motor and AEO fan fit together w/o some modding.
Be careful!
g
giuseppi is offline Find More Posts by giuseppi
Old Jul 08, 2011, 03:10 PM
Chads is offline
Find More Posts by Chads
Chads's Avatar
Depew, NY
Joined Oct 2003
I contacted Hobby King but it doesnt seem like they are in a hurry to help me out. It looks like the fan housing was out of round and when I fired it up one of the blades caught as there is a scrape mark inside.
I should of checked it before I ran it.
Chads
Chads is offline Find More Posts by Chads
Old Jul 08, 2011, 03:15 PM
edge_pilot is offline
Find More Posts by edge_pilot
From a Different Planet!
edge_pilot's Avatar
Lagrange, Ohio
Joined Jun 2005
mine scraped in a very small smot just because it was out of balance. vribration causes some bad things to happen.
The fans listed above have a current draw much higher than the stock setup. As long as you are aware of this it would cause no harm, but just adding one of these fans you will fry the ESC.
if they wont replace the fan blade or fan for you free, I would buy the original fan or parts to fix it stock.
edge_pilot is offline Find More Posts by edge_pilot
Old Jul 08, 2011, 03:21 PM
Chads is offline
Chads's Avatar
Depew, NY
Joined Oct 2003
I have been looking on there site and dont see any stock replacement fan parts
Chads
Old Jul 08, 2011, 03:31 PM
MegaTesla is offline
Find More Posts by MegaTesla
Team30 Micro EDF
MegaTesla's Avatar
Stellenbosch, South Africa
Joined Apr 2004
I requested spare rotors in the HobbyKing forums, maybe if more people ask there they will list it sooner.
The AEO 35mm rotor fits the stock motor shaft. The shaft is not long enough to go all the way through and use a nut to fix it, so you will have to use a drop of CA. And remember to balance it before glueing.
One way to keep amp draw lower, if needed, is to remove 4 of the blades.
MegaTesla is offline Find More Posts by MegaTesla
Old Jul 08, 2011, 06:47 PM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
Chads, throw it out - it's now useless. CA will never hold it on.
Have you the means to trim a 40mm GWS rotor down to fit the fan?
NitroCharged is offline Find More Posts by NitroCharged
Old Jul 08, 2011, 11:07 PM
Strike3 is offline
Find More Posts by Strike3
I don't want to land yet!
Joined Jan 2010
Good news... micro Mig15 flies well, 4 different batteries through it too...
First flight was a Rhino 460 3s 20c, then 360 3s 20c, then Rhino 610 3s 20c and finally flew it with a Turnigy 500 2s 20c ( although only just )... they behave much better with 3 cell!
Even managed a couple of flights alongside Nitro's Mig... man that thing is nice with the higher rated battery, pity the 65c is $$.
Anyway a success with a few minor bruises, can't wait to get all our micro's up at the same time... Jace with his F86, Ozzi and Odysis with their Migs!
We have proven that the weight of a 610 or even slightly bigger is not an issue...
Strike3 is offline Find More Posts by Strike3
Old Jul 08, 2011, 11:51 PM
Slaanesh is offline
Find More Posts by Slaanesh
Not enough hours in the day
Slaanesh's Avatar
Melbourne
Joined Feb 2009
Stock 35mm rotor available from SydneyRCJets.
Slaanesh is offline Find More Posts by Slaanesh
Old Jul 09, 2011, 12:03 AM
boingk is offline
Find More Posts by boingk
boingk's Avatar
NSW, Australia
Joined Feb 2011
All made possible by me, of course
Hahaha, yeah right... but still its wonderful that it'll cope with such a range of batteries. How did you find it went on the Rhino 3s 360's? Mine are still on order and I'm getting impatient.
Cheers - boingk
boingk is offline Find More Posts by boingk
Old Jul 09, 2011, 12:27 AM
Strike3 is offline
Joined Jan 2010
Cheers - boingk
Yes flew well, just need to get it up front as far as possible
Old Jul 09, 2011, 02:05 AM
Odysis is offline
Find More Posts by Odysis
Life begins at transition
Australia, VIC, Sale
Joined May 2007
how did they hold up, voltage wise? my 360's are sagging down to 3v/cell at WOT, even straight off the charge!
I may need to invest in some more cells. These are probably a year old, and stored at full most of that time
Odysis is offline Find More Posts by Odysis
Old Jul 09, 2011, 02:40 AM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
Strike almost parked his Mig on top of a light pole on the side of the field while trying it on 2S. Got it on video.
Skyangel 35mm EDF Mig 15 Jet just missing flying field light pole! (0 min 59 sec)
I tried mine on a 2S 320mah 25C Hyperion. It flew fine but I was WOT all the time to keep any sort of authoritative speed on it.
Old Jul 09, 2011, 02:46 AM
Strike3 is offline
Joined Jan 2010
The 360 was holding 3.65v per cell even...
Nitro... I can get closer than that!
These batts might be worth using for micro's... http://www.atlantahobby.com/Store/pc...-745p15018.htm
Old Jul 09, 2011, 04:43 AM
boingk is offline
boingk's Avatar
NSW, Australia
Joined Feb 2011
Then chances are they're cactus. A capacity test will return 80% or less of their original capacity I reckon, so yeah most likely time for new cells.
Do yourself a favour - when you get them, store them at around 3.85v/cell. This gives them the best lifespan and if you aren't going to use them at all for a few weeks then put them in an airtight container in your fridge, or at least make sure they're in a cool place.
That was my experience with the NanoTech 2s 370's. No contest once you've tried a 3s pack.
Cheers - boingk
Old Jul 09, 2011, 04:47 AM
Odysis is offline
Joined May 2007
They still return 340mAh, but the IR seems to be through the roof!
I might need to take a soldering iron to some of those TP or Hyperion packs. NC seems to enjoy the extra punch
Discussion Mini Mig-15 EDF from Hobby King Dreamcatcher Foamy EDFs 6 Jan 16, 2012 10:58 AM
New Product JPower/Banana Hobby 40mm Foam Mig-15 and F-86 ducted fan FieldofDreamsFlyer Micro EDF Jets and Power Systems 557 Aug 18, 2011 06:01 PM
Build Log Hobby King Micro A-6 & F-86 Jets tallflyer Foamy EDFs 4 Jun 04, 2011 03:05 PM
New Product J-Power 30mm EDF Jets (F-86 & Mig-15) xplaneguy Foamy EDFs 1 Jan 16, 2011 06:59 AM
Park/indoor EDF F-86 and MiG-15 production news! Thomas B Parkflyers 8 Feb 06, 2002 07:30 PM
