Weekend is looking great here too! Just about finished my T-45 as well. Could be an action packed weekend! HAPPY FLYING! |
Austria, Vienna
Joined Jan 2013
still alive
on saturday i had my next three flights. grey skies are difficult. the sabre is so fast and so small. you definately need to keep here close. the droptank beginner skid works very well. i am thinking about applying some red paint on wingtips to make it easier to spot. i am a beginner with edf so i am allowed to do that. on the last flight i even did the launch by myself. left hand, top grip. i use mode 2 so this is the only way to use controlstick right away.
HAPPY FLYING! |
SkyAngel 35mm F-15 Set-up.
Hi Joe 1320- Question for you...I was reading through your SA 35mm F-15 thread...great info, thanks. I just received one from HobbyB and am curious...what sort of battery setup have you settled on with that bird for best overall performance? I know in your thread you are using the 3s 800 mAh. With your remarks on the draw from the two motors, curious if that is still the way you are going
I have a couple of options on hand, but may decide to purchase additional Batts if needed. I currently have a handful of 3s 450mAh 25-40C Nano techs (45.9g). I know that one in itself would NOT like the load. Of course I also have a bunch of 3s 1300mAh 45-90C Nanos (117.2g) probably way to big! Would you suggest using two of the 3s 460's, or should I just bite the bullet and buy some specifically for the F-15? (I plan on running two Plush 10 amp esc's) Also, using the two esc's should I: 1. use a beefier plug to the batts...XT60 vs the JST? 2. In connecting the Rx power/signal lines from the esc, should I keep one of the positive(+) leads from esc unattached? Your comments would be much appreciated!! Thanks! ABJets |
Test flew the new saber today, and this thing is a rocket. I have my ailerons with too much throw, and the elevator without enough! So I need to do some adjustments, but this will be a fun one. It seems the thrust tube will be a good thing. Totally different animal than stock on 2s. Very nice. ------Metalguy
Now the ESCs..... The turnigy plush 10A have linear BECs so you can just hook them up and they work. The 18A ESCs is where they start using a switching BEC that would require bypassing the BEC on one of the ESCs. |
FYI- the 1300 mAh'ers are for my new Screamer...can't wait!! Got a clean way of removing the water decals? Want to do a bit of customizing in that department. HobbyB was out of the 'white' bird. Cheers! |
Rip it up!! |
Austria, Vienna
Joined Jan 2013
to gear or not to gear
@all: please keep posting your throws and expos. i am still in too much stress so i cannot concentrate on that yet.
i have been thinking about landing. it is really hard on the fuselage and the wings leading edges especially if you do not have the perfect grass landing strip. not to mention all the dirt. i caught the p51 with my hands last time for landing, twice! this is what might be the best solution for the airframe but i am still far away from doing that with the f86. catching is a cool trick but on the other hand the sabre looks so scale and catching just doesn't. ok, you know what i am getting at, i want to develop gears. some thoughts: - retractable, steerable, simple and easy to build. - the front wheel should turn sideways before disappearing so it will not reappear inside the air intake. - i want to use only two more servos. one to retract all three gears and one to steer the front wheel (and the rudder while we are at it. on the other hand, does a steerable frontwheel act as a rudder on the final approach?). - maybe a third servo to retract the main gear. better not. - the retract servo will directly flip the front gear inside. this way i can use the servo as a strong base for the front wheel and i do not need to make a hinge. w. |
The Horizon Hobbies UM Mig 15 has gear and a steerable nose wheel. No retracts tho.
I got my Mig up for a flight Saturday . Launch went nice, power was good but trim was off and it banked around to the left then it got behind some spectators and I struck Earth in a state of confusion and panic. But it is gonna fly again. |
| Thread Tools | |
| Discussion Mini Mig-15 EDF from Hobby King | Dreamcatcher | Foamy EDFs | 6 | Jan 16, 2012 09:58 AM |
| New Product JPower/Banana Hobby 40mm Foam Mig-15 and F-86 ducted fan | Mikemynameis | Micro EDF Jets and Power Systems | 557 | Aug 18, 2011 05:01 PM |
| Build Log Hobby King Micro A-6 & F-86 Jets | tallflyer | Foamy EDFs | 4 | Jun 04, 2011 02:05 PM |
| New Product J-Power 30mm EDF Jets (F-86 & Mig-15) | xplaneguy | Foamy EDFs | 1 | Jan 16, 2011 05:59 AM |
| Park/indoor EDF F-86 and MiG-15 production news! | Thomas B | Parkflyers | 8 | Feb 06, 2002 06:30 PM |
