WBA- I just measured my elevator throws and I am at 5mm...that is PLENTY when flying fast...you may want to get to 5mm for normal rates(slow flight might require it?) and see where you end up on dual rate. with the four servos and a bit more weight required for cg...you may need the throw??
Austria, Vienna
Joined Jan 2013
@abjets: thanks for the detailed information. i will adjust the throws and add some expo to the ailerons. i suppose too much aileron input is the cause of many launch troubles.
yesterday my esc (HobbyKing 10A ESC 1A UBEC) exploded on me so i am looking for a replacement. i am using the nano-tech 3s 350mah 65-130C battery. the TURNIGY Plush 10amp 9gram works well so far? thrust tube? do you have a picture? i don't understand the concept. w. |
If you notice the stock exit has an irregular shape and a lot of drag causing imperfections...the tube simply smooths all of this out so that there is minimal loss of thrust/efflux(speed). I simply slid the tube in the airframe, from the intake towards the rear(with the edf removed) installed the motor so that the tube just slides onto the edf shroud(small cut out for motor wires in tube and removed a small bit of foam from the aft portion of the fan seating area and hatch) and taped the tube in place being careful to keep the alignment of the edf and tube straight out the back. Once the motor was secure and glue dry...I secured the aft end of the tube with a small bit of foam...to minimize any wiggle. The thrust tube makes a huge difference! There are some great threads in this forum on it for further explanation. As for the ESC...I am using the Nano tech 3s 460 mHa 25-40C batts and the plush 10 amp with the shrink wrap removed and seated just in the airflow forward of the fan...absolutely no issues and barely gets warm. Hope this helps! Cheers!
![]() The thrust tube makes a huge difference! If you have to solder in a new esc...might be a good time. You won't be disappointed!!! It will leap out of your hand for the launch Also: FYI not sure about your last ESC...but make sure you set your timing to low.
Just picked up my second F-86 Saber today. I plan on 3s immediately, and will strip it apart to do some mods. I found that some of our welding wire for T.I.G. comes in clear plastic tubes that are exactly 35mm. I will be making a thrust tube out of one of those! My other one needs a new motor. ----Metalguy
Austria, Vienna
Joined Jan 2013
@abjets: thanks for the many advices! i ordered two 460 mah batts along with the new esc. i love long flights. i also endet up using 2s 300 mah batts with my p51 um brushless converted.
@metalguy: way to go! consider the direct aileron servo mount. i have not testet em yet but they look very promising. wba |
@ Sky Captain...Hmmm. I'll PM it to you too. The Thrust tube is actually 125mm in length ( I think I mentioned 120mm to WBA earlier. Still at 85% FSA for the 35mm EDF's). I have been using the STAPLES Document sleeves as material....not too heavy, yet they maintain their shape even after some abuse.
Cheers |
The only problem with the 35mm tube is that you need a 37mm to fit around the outside of the exit of the Fan shroud...and to make it an actual thrust tube vs. just added weight with minimal benefits, it needs to have a taper to it. Ideally that taper should be 85% Fan Shroud Area (FSA) So the easiest is to make a template for a 37mm neck tapered to a 30.32mm exit and somewhere around 120-130mmm long depending on your preference. There is free software on the internet that you can load these figures into and it will then print you out a template...Cone Layout is the one I use for various EDF's. FYI- There is a 125mm long template(PDF) in my above thread for the F-86. |
Folks, a moment of your time......
Actually, it's Fan Swept Area. The measurement will be different for each fan depending on the impeller's area, not just the total area of the shroud. You guys might want to read up on the calculations. By not plugging the correct numbers into formulas, you are not getting the correct results.. http://hdflyer.com/how-to-calculate-...rea-of-an-edf/ Let's say you have a small fan of XX diameter and the 12mm inrunner that you are using sure seems to be about the same size diameter as the hub of the impeller. Figure the area of the circle using: Area = Pi x Radiusē That Area result gets subtracted from your total shroud area for your further calculations.
| Thread Tools | |
| Discussion Mini Mig-15 EDF from Hobby King | Dreamcatcher | Foamy EDFs | 6 | Jan 16, 2012 09:58 AM |
| New Product JPower/Banana Hobby 40mm Foam Mig-15 and F-86 ducted fan | Mikemynameis | Micro EDF Jets and Power Systems | 557 | Aug 18, 2011 05:01 PM |
| Build Log Hobby King Micro A-6 & F-86 Jets | tallflyer | Foamy EDFs | 4 | Jun 04, 2011 02:05 PM |
| New Product J-Power 30mm EDF Jets (F-86 & Mig-15) | xplaneguy | Foamy EDFs | 1 | Jan 16, 2011 05:59 AM |
| Park/indoor EDF F-86 and MiG-15 production news! | Thomas B | Parkflyers | 8 | Feb 06, 2002 06:30 PM |
