United States, TN, Jackson
Joined Mar 2007
As for weight---All I gained was 3/4 ounce by adding the extra cell...There are many guys flying this plane on 4S but with 650mAh packs that only weigh a few grams less than my pack... Performance---I flew my MiG 15 on 3S and it was "OK"...When I went to 4S the plane performed like a jet SHOULD!!!... ...Loops as large as you want with plenty of vertical...Here's an old vid that I did with my cellphone...I didn't have anyone to hold the camera so it is a stationary vid...I posted it a while back to get someone to Dopler it for me...This flight was before I did a "nip/tuck" on the exhaust...You can hear the difference in RPM on mine vs those that have posted 3S vids...As fast as this hotrod is flying straight and level you can imagine how much vertical it has... The flying starts about 1:10... Kevin
Joined Oct 2011
Just dusted off a few of my 35's today and I put a small 4S pack in my T45 and all I can say is WOW. This is the first time I have put a 4S in my 35's. This is how they should have come. I thought the step-up to 3S was fun, 4S is great. I read about KG running his Mig on 4S so I had to go for it. Total Blast!
Joined Mar 2007
... ... ...The motor in these planes is very under-rated kv-wise...They are advertised as 9000kv but test out to being between 5500-6000 kv...Hence, the reason they perform so well on 4S without burning up...I have run my MiG 15 on 240mAh Hyperions to 350mAh ThunderPower packs...I'm thinking that the best pack would be the Babbel Batt 325mAh TP 65C 4S packs...Running larger packs will require you to modify the battery compartment to accept larger packs...The Dremel is your friend!!!... ...Kevin |
Joined Oct 2011
Yeah I put together 2 nano-tech 360 2S packs. Stripped'em down and wrapped them once in alumi tape and added a 4S balance tab. I could hear the ESC hitting a few "hiccups" at the top end. I have a 30mm inrunner/fan from my Arttech F86 that I have been fiddling with. The fan seems to be put together well, I just don't know if it will outperform the SA fan/motor on 4S.
| Thread Tools | |
| Discussion Mini Mig-15 EDF from Hobby King | Dreamcatcher | Foamy EDFs | 6 | Jan 16, 2012 09:58 AM |
| New Product JPower/Banana Hobby 40mm Foam Mig-15 and F-86 ducted fan | Mikemynameis | Micro EDF Jets and Power Systems | 557 | Aug 18, 2011 05:01 PM |
| Build Log Hobby King Micro A-6 & F-86 Jets | tallflyer | Foamy EDFs | 4 | Jun 04, 2011 02:05 PM |
| New Product J-Power 30mm EDF Jets (F-86 & Mig-15) | xplaneguy | Foamy EDFs | 1 | Jan 16, 2011 05:59 AM |
| Park/indoor EDF F-86 and MiG-15 production news! | Thomas B | Parkflyers | 8 | Feb 06, 2002 06:30 PM |
