Old Dec 27, 2012, 10:41 PM
SPEED-E-FLYER is offline
Find More Posts by SPEED-E-FLYER
INDORUS EXPARAMINTO
SPEED-E-FLYER's Avatar
Springfield, Missouri, United States
Joined Jul 2002
Got my Mig-29 today.
Will look it over later tonight
Fan units a bit off.
Is it enough to fool with ?
Larry
SPEED-E-FLYER is offline Find More Posts by SPEED-E-FLYER
Old Dec 28, 2012, 10:46 AM
IronRotor is offline
Find More Posts by IronRotor
Try Try and Try Again
IronRotor's Avatar
Florida
Joined Feb 2011
F-86 Fan Trouble
Looking for advice:
Spooled up for a flight this morning and the fan spun off of the motor shaft and is resting in the intake tube. There does not seem to be any damage to the blades or housing.
Has this happened to anyone else? It appears the fan housing is glued in place and I am not sure how the fan is attached to the shaft on this model. Before I attempt a repair I was hoping to get some insight on the "surgery".
IronRotor is offline Find More Posts by IronRotor
Old Dec 28, 2012, 12:00 PM
IronRotor's Avatar
Florida
Joined Feb 2011
F-86 Fan Trouble
Got it, just removed the fan housing by gentle rocking back and forth and threaded the fan back on and hot glued the housing back...simple.
Now for a test flight.
Old Dec 28, 2012, 02:41 PM
Sky_Captain is offline
Find More Posts by Sky_Captain
Flying is Freedom
Sky_Captain's Avatar
Annandale, VA
Joined Jul 2007
Very cool, I didn't know the motors had magnetized hatch covers. That is awesome!
I just ordered mine from Bananahobby. I can't believe Bananahobby had Hobbyking beat by about $15 and that was ordering from the Hobbyking USA warehouse.
Sky_Captain is offline Find More Posts by Sky_Captain
Old Dec 28, 2012, 03:06 PM
IronRotor's Avatar
Florida
Joined Feb 2011
Strong magnets at that! BH is limited but I check them first as it is US stock and pretty darn cheap.
Old Dec 28, 2012, 05:40 PM
IronRotor's Avatar
Florida
Joined Feb 2011
F-86 Fan Problem
My fan keeps spinning off the shaft. The nut is reversed threaded so I am not sure why it keeps happening. The threads look ok. Do I use some CA?
Old Dec 28, 2012, 06:29 PM
giuseppi is offline
Find More Posts by giuseppi
CV-15 VB-16
giuseppi's Avatar
USA, TX, Friendswood
Joined Jul 2007
I thought they were designed so the rotor tightens as the motor spins. So, I gotta ask. Is it spinning in the correct direction? You can try double nutting it. If all else fails, use CA.
g
giuseppi is offline Find More Posts by giuseppi
Old Dec 28, 2012, 06:32 PM
KCinNC is offline
Find More Posts by KCinNC
that's gonna leave a scar
United States, NC, Mooresville
Joined Aug 2007
have you flown it yet ? make sure the air is forced out the back of the jet...quite possible the motor was connected to the esc wrong...and is running in reverse !
if so...switch any two wires, then try again
KCinNC is offline Find More Posts by KCinNC
Old Dec 29, 2012, 12:06 AM
IronRotor's Avatar
Florida
Joined Feb 2011
Thanks everyone, I've got nearly a couple dozen flights on it now and it blows air out the back like crazy, for about 3 seconds then the fan comes off. I cleaned the threads and nut and they appear to be a little stripped, gotta be from the factory as I haven't touched it until now. I cleaned them up and used heavy duty thread locker. I will try again tomorrow and then CA.
Old Dec 30, 2012, 03:17 PM
Kevin Greene is offline
Find More Posts by Kevin Greene
United States, TN, Jackson
Joined Mar 2007
Earlier I stated that Hobby B was DA BOMB!!!...Still holds true---I opened up my plane (F-15 kit) and everything was nicely packed...But I noticed that the motor that was sent to me was one for a 50mm plane instead of the 35mm one that I ordered...I contacted Hobby B via email about the error---And in LESS THAN 24 hours I not only had a reply from them but the correct motor shipped with a tracking #!!!
Listen---If you guys are tired of shipping hastles and being "run around the block" several times before you get satisfaction for a damaged or incorrectly shipped part---Give Hobby B a try...I'm happy!!!...And no---I'm not a rep, shill, or in any way connected to Hobby B...Just a guy like you all that wants service after the sale if needed without all of the hoops (crap) other stores make you jump through...
Additionally, Hobby B ships VERY fast as compared to others that hold your order for over a week in their warehouse---The JIT truck must travel at the same pace the Shuttle hauler travels at Cape Kennedy---Second thought, the JIT truck must be slower!!!
Kevin
Kevin Greene is offline Find More Posts by Kevin Greene
Old Dec 30, 2012, 03:20 PM
Joe 1320 is offline
Find More Posts by Joe 1320
Joe 1320's Avatar
United States, FL, Sebring
Joined Feb 2006
Kevin
+1. Had nothing but great service from Hobbyb.
Joe 1320 is offline Find More Posts by Joe 1320
Old Dec 30, 2012, 03:29 PM
FireHawx is offline
Find More Posts by FireHawx
FireHawx
FireHawx's Avatar
United States, NV, Reno
Joined Oct 2011
++1 HobbyB has always come through with great service!!
FireHawx is offline Find More Posts by FireHawx
Old Dec 30, 2012, 03:39 PM
Joe 1320 is offline
Joe 1320's Avatar
Joined Feb 2006
Larry
Personally, I would make sure the fans sit perfectly oriented in the fuse and the thrust line slightly up. I believe the foam is contoured correct, sometimes the fans get installed a bit sloppy.
http://www.rcgroups.com/forums/showp...postcount=3402
Old Dec 30, 2012, 05:16 PM
Flying is Freedom
Annandale, VA
Joined Jul 2007
Who is HobbyB?
Old Dec 30, 2012, 05:30 PM
giuseppi is offline
CV-15 VB-16
giuseppi's Avatar
Joined Jul 2007
Who is HobbyB?
Google is your friend.
g
Discussion Mini Mig-15 EDF from Hobby King Dreamcatcher Foamy EDFs 6 Jan 16, 2012 09:58 AM
New Product JPower/Banana Hobby 40mm Foam Mig-15 and F-86 ducted fan Mikey 68 Micro EDF Jets and Power Systems 557 Aug 18, 2011 05:01 PM
Build Log Hobby King Micro A-6 & F-86 Jets tallflyer Foamy EDFs 4 Jun 04, 2011 02:05 PM
New Product J-Power 30mm EDF Jets (F-86 & Mig-15) xplaneguy Foamy EDFs 1 Jan 16, 2011 05:59 AM
Park/indoor EDF F-86 and MiG-15 production news! Thomas B Parkflyers 8 Feb 06, 2002 06:30 PM
