Old Dec 22, 2012, 11:09 PM
Kevin Greene is offline
Find More Posts by Kevin Greene
United States, TN, Jackson
Joined Mar 2007
Originally Posted by NitroCharged View Post
Yes, it's best to get high C lipo's for them. Although the fan unit is of exceptional quality for what it is and so is not an amp hog - higher C lipo's won't puff and will deliver more amps.
I know this is a long thread but way back, I got my Mig15 up to around 82mph on 3S. I had an 850 TP G6 rammed in there. It weighed a ton but was a rocket!
Wooooo!!!...An 850!!!...WOW!!!...I had a 400 4S crammed in the nose and thought mine was fast but nose heavy!!!...I did a nip/tuck for grins and giggles on my MiG 15 but haven't tried it out yet...The nip/tuck was only 1/8"...
Kevin
Kevin Greene is offline Find More Posts by Kevin Greene
Old Dec 22, 2012, 11:33 PM
SPEED-E-FLYER is offline
Find More Posts by SPEED-E-FLYER
INDORUS EXPARAMINTO
SPEED-E-FLYER's Avatar
Springfield, Missouri, United States
Joined Jul 2002
I had to rework my A-10's elev. control surface.
Re-bent the torque rod and added a small bit-o-tubing to help
securer it.
The maiden on my A-10 was a bit harsh.
Not sure about that 20mm CG.
My launch just arched like a lawn dart.
Moved it back to 23-24ish and it flew but did not have as much elev. as I needed to keep from hitting the wall.
Going to add some extension to all the control surfaces to help with the Hinking & Jinking
Got a Mig 29 coming for Christmas.
Larry.
SPEED-E-FLYER is offline Find More Posts by SPEED-E-FLYER
Old Dec 23, 2012, 06:44 AM
Joe 1320 is offline
Find More Posts by Joe 1320
Joe 1320's Avatar
United States, FL, Sebring
Joined Feb 2006
securer it.
Larry.
It takes lots of elevator throw as well as a firm hand toss with full throttle. You also can't cut power on A-10s without them dropping like a rock. It's a short tail moment, small surfaces and the elevators are blocked by the nacelles at power off. Start with a fair amount of up reflex, it won't do well startng at neutral. The full scale A-10 uses a bit of up thrust built into the thrust line, these don't so it takes a bit more elevator.
You can try 25mm back, but I think you'll find it extremely pitchy due to being tail heavy. That's where I started at it took everything I had to bring it down in one piece.
Joe 1320 is offline Find More Posts by Joe 1320
Old Dec 23, 2012, 02:21 PM
Jacques.Eloff is offline
Find More Posts by Jacques.Eloff
Jacques.Eloff's Avatar
United Kingdom, England, Cobham
Joined Oct 2007
Originally Posted by Sky_Captain View Post
I'm really hoping to get a link for a recommended 3s esc here soon. Thanks
Turnigy Plush 10A or 12A will do. Else go for Hobbywing 10A or 12A. They are exactly the same as Turnigy. You will struggle to fit anything bigger and you won't need anything bigger, anyway. You will be around 9A on 3S with the stock motor and fan.
Turnigy 18A ESC.
Nitro - assume this is a typo?
Jacques
Jacques.Eloff is offline Find More Posts by Jacques.Eloff
Old Dec 23, 2012, 02:31 PM
INDORUS EXPARAMINTO
Joined Jul 2002
Will try again as soon as I get it back together
I did not give it full throttle on the launch, so my bad!
Larry
Old Dec 24, 2012, 04:07 PM
Scamp73 is offline
Find More Posts by Scamp73
Scamp73's Avatar
United States, NC, Autryville
Joined Jan 2012
Guys, I just got the Mini Mig-15 from Banana in the door. What reciever do I need to use with this jet? I use a Spectrum DX7
Anything else I should know?
Scamp73 is offline Find More Posts by Scamp73
Old Dec 24, 2012, 04:41 PM
Joined Mar 2007
You can use the Orange RX 4 channel rx for light weight and is inexpensive...I used an Orange RX 6 channel rx in mine with the case removed to save weight...The 6 channel RX weighs only a couple of grams more than the 4 channel with the case removed...I bought about 6 of these 6 channel rx's to fill in an order...If ya need one in a hurry I could sell one for $12 shipped...
Kevin
Old Dec 24, 2012, 04:44 PM
Scamp73 is offline
Scamp73's Avatar
Joined Jan 2012
Kevin
Kevin, I have some Orange 4ch's but they will not work with these plugs. It has micro plugs on it and I am not sure what kind of plugs they are???
Old Dec 24, 2012, 05:00 PM
giuseppi is offline
Find More Posts by giuseppi
CV-15 VB-16
giuseppi's Avatar
USA, TX, Friendswood
Joined Jul 2007
Which Orange Rx do you have? The R610 or the R415? I think this one is the correct one: http://www.hobbyking.com/hobbyking/s..._Receiver.html
g
giuseppi is offline Find More Posts by giuseppi
Old Dec 24, 2012, 05:04 PM
Scamp73 is offline
Scamp73's Avatar
Joined Jan 2012
g
I have 410's and 610's. The 415 looks like it is correct but I am not sure. There are several different ends that look very close to this.
Old Dec 24, 2012, 06:01 PM
giuseppi is offline
CV-15 VB-16
giuseppi's Avatar
Joined Jul 2007
Someone here will eventually confirm that the R415 has the correct Molex connector. In the mean time you could try typing R415 in the "Search this Thread" search box above and you'll find the answer.
Old Dec 24, 2012, 07:55 PM
Joe 1320 is offline
Joe 1320's Avatar
Joined Feb 2006
g
That is the correct receiver for use with the micro plugs. This is not correct for spektrum plugs.
Old Dec 24, 2012, 08:11 PM
INDORUS EXPARAMINTO
Joined Jul 2002
That is the correct receiver for use with the micro plugs. This is not correct for spectrum plugs.
WHAT?
Larry
Old Dec 24, 2012, 08:19 PM
Joe 1320 is offline
Joe 1320's Avatar
Joined Feb 2006
The spektrum plugs are smaller. 1mm vs 1.25mm I think? That's the 6400 brick size, which is not the same as the 6310 series. Yikes.
Old Dec 24, 2012, 08:36 PM
INDORUS EXPARAMINTO
Joined Jul 2002
Thanks for the heads up.
Will check it out
Thanks guys
Merry Christmas
Larry
Discussion Mini Mig-15 EDF from Hobby King Dreamcatcher Foamy EDFs 6 Jan 16, 2012 09:58 AM
New Product JPower/Banana Hobby 40mm Foam Mig-15 and F-86 ducted fan FieldofDreamsFlyer Micro EDF Jets and Power Systems 557 Aug 18, 2011 05:01 PM
Build Log Hobby King Micro A-6 & F-86 Jets tallflyer Foamy EDFs 4 Jun 04, 2011 02:05 PM
New Product J-Power 30mm EDF Jets (F-86 & Mig-15) xplaneguy Foamy EDFs 1 Jan 16, 2011 05:59 AM
Park/indoor EDF F-86 and MiG-15 production news! Thomas B Parkflyers 8 Feb 06, 2002 06:30 PM
