Old Dec 09, 2012, 06:05 AM
bps is offline
bps
Find More Posts by bps
bps
bps's Avatar
Indianapolis, IN
Joined Apr 2001
Originally Posted by IronRotor View Post
BH Pocket Nano F-86 is ordered, anybody have some starting settings for Throws or Expo for DX6i?
Did you get the 35mm or the 30mm? Also what battery are you going to use?
I have the 30mm using ThunderPower 325 3 s lipo. Flies great. Out of all my jets mostly 64mm I like this one the best.
Tks
bps is offline Find More Posts by bps
Old Dec 09, 2012, 07:38 PM
IronRotor is offline
Find More Posts by IronRotor
Try Try and Try Again
IronRotor's Avatar
Florida
Joined Feb 2011
Bh f-86
Originally Posted by KCinNC View Post
i have the nano f-86....well i use a DX7, i fly mine on low rates 70% and +25 expo
not really twitchy, but it still turns pretty quick & easy
if you got a BIG area to fly....you could go as low as 50% low rates , +35 expo until you get used to it
Great, thanks for the tip. I will probably start with the 70%, +25 and go from there.
IronRotor is offline Find More Posts by IronRotor
Old Dec 09, 2012, 07:44 PM
IronRotor's Avatar
Florida
Joined Feb 2011
Tks
I keep hearing good things about these little jets, I cant wait to get my hands on it.
I really dont know if it is a 30mm or 35mm; the specification sheet did not say, I think the BH video said it was a 35mm. I guess I will be surprised.
I have the several 2S 15C 450mAh and 2S 25C 450 mAh batteries from another plane that I plan to use. Maybe 3S in the future.
Old Dec 09, 2012, 09:13 PM
Kevin Greene is offline
Find More Posts by Kevin Greene
United States, TN, Jackson
Joined Mar 2007
With my MiG-15 I'm running 4S and 250-350mAh batts...It is BALLISTIC!!!...I now have the new Turnigy NanoTech 300mAh 35C batts wired for 4S...Can't wait to try them!!!...Stock motor and 5 blade rotor but with a 12 amp Turnigy ESC rated for 4S....
Kevin
Kevin Greene is offline Find More Posts by Kevin Greene
Old Dec 10, 2012, 06:01 AM
bps is offline
bps
bps
bps's Avatar
Indianapolis, IN
Joined Apr 2001
The 30mm is set up for 3 cell and the 35mm is set up for 2 cell. Easiest way to tell is aileron servo. One in the center for 2 cell and two servos on the 3 cell 30mm bird. Using three cells on the 35mm jet will most likely require replacement of the ESC.
Old Dec 10, 2012, 07:16 AM
Sky_Captain is online now
Find More Posts by Sky_Captain
Flying is Freedom
Sky_Captain's Avatar
Annandale, VA
Joined Jul 2007
BPS, that was very good info.
I now know I have the 35mm because of the single aileron servo.
Where can you get the 30mm planes? I'm thinking of ordering a Mig-15 and want to get the 30mm version. I will upgrade my current 35mm F-86 to a better esc and run 3s on it. 2s is just too sluggish for an F-86
Sky_Captain is online now Find More Posts by Sky_Captain
Old Dec 10, 2012, 02:16 PM
IronRotor's Avatar
Florida
Joined Feb 2011
Nano F-86
I think I have a problem..................with self control!
I haven't even recieved the stock plane yet and all I can think about are upgrades
Thanks for the info BPS, I have a few 3s ESC's from past projects, maybe there is a holiday sale on some Lipo's..........somewhere................
Old Dec 11, 2012, 05:23 AM
bps is offline
bps
bps
bps's Avatar
Indianapolis, IN
Joined Apr 2001
Banana Hobbies has the 30mm F86 for a good price. They only offer this plane in American and German markings. No 30mm Mig. Most are just changing the ESC to handle 3 cells
Here are the 30mm F86
http://www.bananahobby.com/rc-edf-fi...id_55_58=55|58
Here are the 35mm Migs
http://www.bananahobby.com/rc-edf-fi...id_55_59=55|59
Old Dec 12, 2012, 07:28 PM
KCinNC is offline
Find More Posts by KCinNC
that's gonna leave a scar
United States, NC, Mooresville
Joined Aug 2007
i have a 50mm kit...and i noticed it only uses one servo for ailerons ? kinda find that weird
KCinNC is offline Find More Posts by KCinNC
Old Dec 12, 2012, 07:29 PM
IronRotor's Avatar
Florida
Joined Feb 2011
Bh f-86
UPS Tracking says the BH F-86 will be delivered Friday.
BPS- I am sure its the 35mm version.
Old Dec 12, 2012, 08:20 PM
bps is offline
bps
bps
bps's Avatar
Indianapolis, IN
Joined Apr 2001
Long ago when I started planes only had one aileron servo, even the large planes! I do prefer two servos for ailerons even on the smaller planes.
Old Dec 13, 2012, 06:14 AM
Flying is Freedom
Annandale, VA
Joined Jul 2007
I think the extra servo would help in the event if one goes out. But with my slow reaction time trying to figure out what happened, it would be too late by the time I figured it out
Old Dec 14, 2012, 09:35 PM
IronRotor's Avatar
Florida
Joined Feb 2011
Bh f-86 35mm
The F-86 arrived today. Assembled and set it up. I changed the connectors on the servos to standard type to fit an Orange Micro 4CH, work well on the bench. Hope to Maiden tomorrow weather pending..............
Old Dec 15, 2012, 06:23 AM
bps is offline
bps
bps
bps's Avatar
Indianapolis, IN
Joined Apr 2001
Good luck with the first flight. Advice if your interested...launch slightly nose up wings level or right wing slightly low, full throttle. Let the speed build up before adding much control input, remember you have no prop wash over wings or control surfaces. The nose likes to drop in a tight turn, best bet is to level wings before applying elevator. Not much mass here so it looses speed quickly. Those are my impressions, looking forward to reading yours. Enjoy!
Old Dec 15, 2012, 08:30 AM
Flying is Freedom
Annandale, VA
Joined Jul 2007
All good tips by BPS, I would like to add that you should take the fuel tanks off if you have installed them. This will get rid of some unnecessary weight.
Discussion Mini Mig-15 EDF from Hobby King Dreamcatcher Foamy EDFs 6 Jan 16, 2012 09:58 AM
New Product JPower/Banana Hobby 40mm Foam Mig-15 and F-86 ducted fan Mikey 68 Micro EDF Jets and Power Systems 557 Aug 18, 2011 05:01 PM
Build Log Hobby King Micro A-6 & F-86 Jets tallflyer Foamy EDFs 4 Jun 04, 2011 02:05 PM
New Product J-Power 30mm EDF Jets (F-86 & Mig-15) xplaneguy Foamy EDFs 1 Jan 16, 2011 05:59 AM
Park/indoor EDF F-86 and MiG-15 production news! Thomas B Parkflyers 8 Feb 06, 2002 06:30 PM
